daisy chain usb connections
Discussion in 'Audio & Video' started by 07TacoRidah, Mar 25, 2011.
  1. Mar 25, 2011 at 7:50 AM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    I asked something like this a while back to some guy who I used to work with that was into computers. I asked if it were ok to daisy chain some usb cables together, he said no, something about the signal being lost along the way. I am going to be putting in a aftermarket deck soon that has a usb cable at the back, not sure how long it is but I want to run it all the way to where I have a bunch of delete panels. If the deck usb doesn't make it, say a bit far, would I run into problems if I daisy chain the usb cable to another one to compensate for the missing length?
  2. Mar 25, 2011 at 8:24 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    It's fine man. I have an extender on mine.
  3. Mar 25, 2011 at 1:16 PM
    07TacoRidah
    cool thanks :cool:
  4. Mar 28, 2011 at 12:28 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Depends on how much length you need and how much power you need on the other end. The USB spec only delivers the 0.5 amp (I think that's the amount) over a specific length. This is usullly not an issue unless you are trying to hook up something power-hungry, like a USB hard disk drive.
  5. Mar 28, 2011 at 4:19 PM
    07TacoRidah
    not too far, since I have a base model I am going to be using the deleted panel spots for the usb connection. just need the socket or what have you to make it look OE or close to it. The usb extention that came with the h.u. is plenty enough to make it over to the side where I need it. Thought I was going to have to need more or something.
  6. Mar 28, 2011 at 7:42 PM
    Toby
    Toby Servant of Ninkasi
    Prairieville, LA
    17 Black TRD Off Road 4x4
    None yet.
    Yes, technically the spec is only 500 milliamps (0.5 amps), but generally most extension cables won't lose much power if you don't use more than one. The HU may deliver more than that anyway. Check the specs for how much power it delivers in the first place.
  7. Mar 28, 2011 at 8:29 PM
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    In general, anything over 10 feet is not recommended for a USB 2.0 cable...but many USB devices (like a thumb drive) don't need the full power and will run. You might have a problem running an external HDD, using a webcam, or charging an Ipod while playing music off of it. Luckily for you, I don't think it's really an issue because I don't think that you would need anything longer than 10 feet within the cabin of our trucks.
  8. Mar 29, 2011 at 6:04 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just fyi, I had a 2.5" external usb disk drive that would not spin up on 2 3' usb cables together. Connected it via one cable and it would work. So, YMMV, just wanted to let the OP know there may be an issue depending on the power needs of the usb device.
  9. Mar 29, 2011 at 8:14 AM
    Toby
    Prairieville, LA
    None yet.
    That's why I said 'generally' and not 'universally' and to check how much power the HU supplies. ;)
  10. Mar 29, 2011 at 8:59 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Nope, all good, I wasn't dis'n your post, I just added my actual experience for the OP and anyone else looking.
