Dakar Add-A-Leaf Installation?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gunn_runner, Jan 25, 2018.
  1. Aug 28, 2021 at 1:49 PM
    DrFunker
    DrFunker Well-Known Member
    They do not. I had some installed at my local spring place.
    They did a great job and cost me like 20 bucks.
  2. Oct 27, 2021 at 6:47 PM
    Zingsauce
    Zingsauce Active Member
    Brian
    San Deigo CA
    2019 tacoma DCSB
    Kings 2.5 with adjusters Built right UCA DAKAR medium leaf pack Wheelers U-bolt flip kit with timbrens Method 315 wrapped in Falken wildpeaks AT3W 285/75/16
    Where did you ended up placing the AAL?
  3. Dec 4, 2021 at 7:58 PM
    TheGreatWhiteBuffalo
    TheGreatWhiteBuffalo Well-Known Member
    2016 Tacoma TRD Off-Road
    This may be a dumb question… but which direction does the AAL go? It seems that one end is longer that the other. I’m seeing conflicting info online, one thread said long towards rear, another said to match the tips, but those are completely opposite.
  4. Dec 4, 2021 at 8:56 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Check the diamond cut end and match up, I believe that goes towards the rear. Match with existing leaves. One end is square cut and the other is diamond.
  5. Dec 5, 2021 at 5:14 PM
    If I match the cuts, long end goes towards front.
    I ended up doing it both ways. Long end towards rear causes weird gaps in the leafs. So I guess it’s decided… match the ends, long end to front.
    6 gearT444E[QUOTED] likes this.
  6. Jul 11, 2022 at 4:46 PM
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    Getting ready to install these this weekend. All this info is great. From what i can tell the add a leaf gets installed in the 3rd leaf position down from the top, is this correct?
  7. Jul 15, 2022 at 9:01 AM
    giebelhaus
    giebelhaus Well-Known Member
    Bellingham
    2020 SR5 DCLB Cement
    Did you ever figure this out? I'm adding an aal to the dakar pack and wasn't sure where to add?
  8. Jul 15, 2022 at 9:28 AM
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    Headed to the shop right now to do this install. I'm pretty sure from research it's the 3rd from the top I should know for sure soon.
  9. Jul 16, 2022 at 9:51 AM
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    It's deff the third from the top. It was sort of a pain in the but on the first leaf pack but the second one went much quicker. I ended up disassembling the pack in place on the truck. Pulled the lower leafs out left the upper most leaf in place and re assembled the pack with c clamp it took a while but got it done.
  10. Sep 28, 2022 at 8:20 PM
    3g.cement.19
    3g.cement.19 New Member
    Port coquitlam
    Did you guys have to get new centering pins?
  11. Sep 28, 2022 at 9:57 PM
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    I was able to re use the ones I had. Threads are about even at the nut
    3g.cement.19[QUOTED] likes this.
  12. Sep 29, 2022 at 6:22 AM
    3g.cement.19
    Port coquitlam
    Thank you very much
