Dakar buzzing noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by w8tdstrgecube, Apr 20, 2024.
  1. Apr 20, 2024 at 10:42 AM
    w8tdstrgecube
    w8tdstrgecube [OP] Well-Known Member
    Brian
    Wisconsin
    2004 Gold Regular Cab 2.7L Manual 4x4
    Just wanted to post this up to help anybody else chasing rattles in their truck.
    For the past six months I've had a metallic rattle/buzz that sounded like it was coming from the driver's side wheel well. Sounded like a bolt with a washer was loose. I chased all over the front for months and found nothing.
    I was tightening my muffler clamp and greasing the driveline the other day and happened to bump my leaf pack and heard the noise! Turns out the bolts holding the spring keepers together have a sleeve riding over the bolt. The bolts loosen over time and let the sleeves rattle.
    Check your spring keepers if you have a buzzing metallic rattle! And sound travels weird in these trucks.
    Tuluk and Area51Runner like this.
  2. Apr 20, 2024 at 11:37 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Fair warning, don't over tighten them. If you do, you'll end up with strange "clunks" when transitioning over driveways, speed bumps, etc.
    I found that the metal sleeve needs to be just slightly snug where it can move slightly. If you start getting clunks, look at these as a probable cause.
  3. Apr 20, 2024 at 11:53 AM
    w8tdstrgecube
    Brian
    Wisconsin
    Good to know, thanks!
  4. Apr 20, 2024 at 11:56 AM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    I 2nd this
