Dakar installation
Discussion in 'Suspension' started by CrustyComa, Feb 23, 2020.
  1. Feb 23, 2020 at 3:25 PM
    CrustyComa
    CrustyComa [OP] Well-Known Member
    Michigan
    2020 SR SX TRD Sport love child
    Hey fellas, need help real quick. Just installed medium duty dakars, should both leaves have the same symbol by the arrow? I have one plus and one O....these are the newer model EL095R.
  2. Feb 23, 2020 at 4:04 PM
    Reddy
    Reddy Well-Known Member
    Scott
    Ohio
    '11 TRD OR AC
    OME 885's/Dakars/265's/belly skid
    If I remember right, + for drivers side, o for passenger side. The + is a little taller, to correct for Taco lean.
    lynyrd3 likes this.
  3. Feb 24, 2020 at 5:00 PM
    BuildbyBarz
    BuildbyBarz Well-Known Member
    Johnny
    SrQ 941
    14 MGM DCSB
    Friends don’t let friends drive stock
    I asked the same question and this is the answer I got from Marie @ headstrong off road.
    “ The Dakars for the 05+ Tacomas are not left/right side specific. 95-04 is and has an A and a B side.
    The yellow markings on each of the leafs indicate where the leafs fell during their testing process. A 0 indicates in spec, the + is slightly above spec, and the – is slightly below spec. There are varying degrees within each + and – category. Since this is something that is internal with ARB they do not label their leafs left/right side specific nor can we order the 0’s, +’s, or –‘s specifically. Since this is the case we usually recommend our customers to place the higher of the ratings on the driver’s side. This can help toaccommodate for the additional weight that is on that side of the truck.“
    lynyrd3 likes this.
  4. Feb 24, 2020 at 6:05 PM
    CrustyComa
    Michigan
    Thanks guys, I got lucky and put the plus on the drivers side. It does sit a little higher but nothing too drastic.
