dakar leaf pack install question
Discussion in 'Suspension' started by mightytacoman, Oct 23, 2013.
  1. Oct 23, 2013 at 11:26 AM
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    quick question, do you have to purchase bushings for an OME dakar leaf pack install or can you reuse the factory oem bushings?. :notsure: I looked around for a couple weeks now in my spare time and wasnt able to find a deffinative answer. thanks guys
  2. Oct 23, 2013 at 11:30 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    EITHER OR. JUST GET NEW ONES. THEY'RE CHEAP ($15-20).
  3. Oct 23, 2013 at 11:35 AM
    mightytacoman
    Kel
    4.5L 1grfe
    I totally forgot about getting them up front. Doing the install this weekend. Just making sure I would be able to get away with oem ones if I needed to. Then again I might try and rush order them too. I've already spent this much 15-20$ is pretty petty at this point. thanks man
  4. Oct 23, 2013 at 11:49 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The front Spring Eyes on the Dakars already have Factory Style Bushings installed. But you will need to get some for the rear spring eyes. We have a bushing kit for those springs that covers both springs for $15.69
