Dakar leaf pack squeak is ruining my life. Anyone have a solution ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by El Terrible, Sep 15, 2016.
  1. Oct 13, 2016 at 7:07 AM
    #61
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I agree that in theory the pack should flex a little better. The spring shop owner stated that the spring rate remains unchanged with the isolators. I'll report back in my build after next major wheeling trip if any detectable difference. The main reason i took the pack out was to add the second overload back in. I had declined it to install it from the beginning. Ran it that way for 1.5 years. I'm changing some things about my rig and wanted it in there for the future.
  2. Apr 7, 2017 at 8:03 AM
    #62
    rpeazy808
    rpeazy808
    Tucson, AZ
    08 DCSB TRD OR 4x4
    //Icon//ADS//Avid//Pelfreybilt//Falken//
    Sorry to bring up an old thread but I just bought a set of Dakars and was wondering how the fluid film is holding up for the guys that used it?
  3. Apr 9, 2017 at 11:49 AM
    #63
    El Terrible
    El Terrible [OP] Well-Known Member
    I've applied it twice since I used it first. It's been raining a lot where I'm at so I'm sure that's affected it. Some of the squeak is back but not as bad as it was without it
  4. Sep 2, 2018 at 7:59 PM
    #64
    CO90Taco
    CO90Taco Member
    Tucson AZ
    2014 Toyota Tacoma DCSB TRD OR
    Pelfreybilt Front and Rear Hi-Clearance Bumper, Baja Designs Sport Fog Lights, Smittybilt winch, 285/75R16 BFG KO2, 3rd gen off road wheels, OME 2.5” lift w/Dakar springs, RCI Offroad sliders, ECGS bushing, spidertrax wheel spacers, remote start, vantrue dash camera
    So I have been trying to follow all the solutions for squeaky springs here and other threads for months now after installing the Dakar’s as part of a OME lift and had a squeak immediately. Greased the pads, fluid film, re-torque everything, WD40... you name it!
    Anyway, today I had a friend jump on my bed so I could isolate where the noise was coming from. Being the first time under the truck, while the suspension was moving, I realized the spare tire was moving just a little bit. I figured I’d tighten that up first and then get back to those springs. Well guess where my squeak was coming from? I forgot I dropped the spare when I did the lift, and apparently didn’t tighten the spare enough when I was done.
    Check your spare to see if it’s loose if you think your suspension is squeaking.
    I’m so mad at myself for not finding such a simple solution months ago, but glad it’s over and can enjoy my truck again!
    b_r_o likes this.
  5. Mar 25, 2020 at 12:21 PM
    #65
    DrRoboto
    DrRoboto Well-Known Member
    David
    Salt Lake City, UT
    <s>2017 AC Off-Road</s>
    GoFastCamper. OME 886. Medium Dakars. SSO slimline bumper + Warn VR10-S. OGE dual battery system. Mobtown skids.
    I will be giving prothane super grease a try. I've found the silicone grease I currently use (super lube with ptfe) is getting washed off. My dakar bushings just started squeaking again, same time as last year, after the frequent car washes through the winter.
    Crom[QUOTED] likes this.
