Dakar Leaf Pack versus Toytec Boss
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trucko, Mar 1, 2017.
  1. Mar 1, 2017 at 7:08 AM
    Trucko
    Trucko [OP] Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    I currently have the toytec boss rear leaf springs on my 05 dcsb. I just built an expo style trailer and my rear springs sag bad. I can bottom out on the interstate. I am looking at OME Dakar leaf pack and not sure on if i need the overload spring or not. What do you all think. 1. Think the Dakar will fix my problem 2. Should i get the overload leaf as well. Lastly i have no idea on how much the trailer weighs. Thanks for all the help TW.
  2. Mar 1, 2017 at 8:15 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    the dakar pack without over load aal will give you about 2.5" of lift and will take any load you put on them. I would buy the dakar pack w/out the aal and see if it works out you can always add it later if it doesnt
  3. Mar 1, 2017 at 8:20 AM
    Trucko
    2005 Tacoma
    That was my plan so thanks for verifying it. Anybody else want to chime in. Just curious on the overall TW opinion on these leafs.
  4. Mar 1, 2017 at 9:24 AM
    44357 Whithersoever...
    Eric
    Desert RATS
    2017 T4R ORP MF
    I haul a leer DCC and weatherguard packrat with my Dakar set and the weight helps. As mentioned above, try Dakar without add a leaf then add/subtract leaf as needed.
    I wish that replacing front factory bushing with poly prior to install was done by me. Going to be doing this once stealership returns my truck. There is a thread about lack of OME bushing lube I just found last week ... pending link found: https://www.tacomaworld.com/threads/ome-dakar-front-bushings-everything-you-need-to-know.474030/
    Also search some of the forum suspension section for pro/cons of various brand leaf springs and for common combo parts added with each set up...Brake lines, wheelers bump stop, OME/Energy suspension bushings, u-bolt flip kits etc.
  5. Mar 1, 2017 at 9:25 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    @ToyTec Lifts has been super helpful to me. I'd let them chime in also.
  6. Mar 1, 2017 at 10:38 AM
    Trucko
    2005 Tacoma
    toytec your thought on weight capacity from the boss leaf packs to the dakars leaf pack
  7. Mar 1, 2017 at 11:57 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    you can also check out the deaver expo pack.
  8. Mar 1, 2017 at 4:03 PM
    Trucko
    2005 Tacoma
    Thanks for all the input everyone
  9. Apr 26, 2017 at 9:25 AM
    Trucko
    2005 Tacoma
    dakars are awesome. worked perfectly
