Dakar Leaf Pack vs Firestone Air Bags
Discussion in 'Suspension' started by phatso, May 27, 2013.
  1. May 27, 2013 at 11:43 AM
    phatso
    phatso [OP] Well-Known Member
    Eastern Washington
    2017 Cement Pro
    I've searched for and read a lot of material on each of these, but I've had a hard time finding anything that compares both. I have an '08 TRD OR DCSB with an OME 3" lift with the aal. I tow a boat often during the summer months...with that and the camping gear I have quite a bit of sag. I have been debating whether to get the Firestone Ride Rites or a Dakar Leaf Pack.
    What are the pros and cons to each? Will the Dakars eliminate sagging?
    Currently I do not do any real off-roading, but I would like to in the future. If it matters I'm running 265/75/16 Duratracs.
    Thanks in advance.
  2. May 28, 2013 at 9:28 PM
    Kahunabert1
    Kahunabert1 Kahunaman
    Bert
    Hawaii
    99 Tacoma 4x4
    King coil overs, piaa, K\N filter
    I run air bags because I have heavy lumber rack and toolbox for the last ten years and they work fine and you can always air them down for softer ride. I don't know about the leaf springs.
  3. May 28, 2013 at 11:42 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    The Dakars can handle a surprising amount of weight without sagging, would be a major upgrade over your existing and obviously match well with your OMEs. They would perform much better offroad than the air bags. I've loaded 1500lbs of pavers in the back and was shocked how little sagging I saw. Having said that, they are more of a wear item than the Firestones.
    I would personally get the Dakars since I'm guessing your rear suspension can probably use a freshening up.
  4. May 29, 2013 at 12:01 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Check out timbrens... less "parts" to need to go wrong. I am currently running a 2"aal with the time's, an have the OME leaf pack on order as the aal is starting to sag after 3 years.
  5. May 29, 2013 at 12:06 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Dakars
  6. May 31, 2013 at 12:04 AM
    Series1000
    Series1000 Gots a Taco!
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    3" Redi-lift (spacer lift) up front
    I was just there, asking that same question. I bought the firestones, they work amazing for my needs and I dont regret it. They ride awesome no sag and a bit of lift at 30 psi empty, most that I have had to put in is 40 and I was still above stock height in the rear. Daystar makes an airbag saddle that the bottom of the air bag rests in, that will be my next buy.
  7. May 31, 2013 at 12:13 AM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    This.
  8. May 31, 2013 at 6:06 AM
    ATHiker
    ATHiker Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    Do we have a fix for the squeaking Dakars?
  9. May 31, 2013 at 6:12 AM
    vicali
    vicali tirekicker
    mike
    Kam,BC
    2005 TRD Sport 1E7
    Got up bright and early to look for info on this same topic, I tip my coffee to you OP.
    My initial impressions are that the Dakars are a suspension upgrade that has a bunch of benefits including helping with towing; where the Air-bags are a solution exclusively for towing..
  10. May 31, 2013 at 6:31 AM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    I have a pic somewhere to show you. Let me see if I can find it..
    edit: can't find the pic. I had the truck loaded with 2 160 qt coolers fully loaded, gear for 5 guys for the weekend, 5 guys in the truck, and a ranger bass boat hitched up and the truck was sitting level and road like a dream. you can't beat the Dakars.
  11. Jun 4, 2013 at 10:31 PM
    phatso
    Eastern Washington
    2017 Cement Pro
    I've been hella busy the last few days, but I appreciate the replies.
    I've been leaning towards the Dakars since I first started looking into this and I think I'm still leaning that way. I guess I was wondering if someone would make an overwhelming case for the air bags. I see the benefits of both, but I think the Dakars fit my needs more-so than the airbags.
    Do the Dakars really have a squeaking problem? That would be a huge problem for me. That could sway my decision. Is the squeak something that goes away with time, like the squeak from my aal?
  12. Jun 5, 2013 at 6:00 AM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Western Washington
    BSP 4x4 TRD Sport DCSB
    Not enough
    I've had my Dakars for a few months now and they've been squeak free. I soaked them in PB Blaster(as discribed by someone on here) before install, seems to have done the trick. Time will tell. One thing to consider is vibrations though. I'm fighting a take off shudder since install and may end up with a custom double cardon drive shaft to solve this...
    Refer to: http://www.tacomaworld.com/forum/2nd-gen-tacomas/244535-drive-shaft-vibrations-solved-step-step.html
    I've towed 2000lbs with loaded truck bed about 800 miles and the Dakars may have dropped and inch or so. Note:I have the Dakar's w/D29xl
