Dakar leaf pack w/ king suspension?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thunderhope, Aug 12, 2019.
  1. Aug 12, 2019 at 2:30 PM
    thunderhope
    thunderhope [OP] Well-Known Member
    2019 Tacoma OffRoad 4x4
    Im getting kings front and back with a dakar leaf pack and spc uca's next week. I see the Dakar gives a 2 inch lift. I don't want my rear higher then front at all. My question is will I be able to level the truck out and set the front coilovers to the proper height.
    if it helps this is the setup
    front- king 2.5 standard length (600)
    rear- king 2.5 standard length
    SPC UCAs
    Dakar leaf pack (medium)
    Gunshot-6A likes this.
  2. Aug 12, 2019 at 2:32 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Yes. Keep in mind the leafs will settle a skooch, so if you crank the fronts up to match the rears fresh off the lift, you'll end up nose high after a couple weeks.
    llibrm likes this.
  3. Aug 12, 2019 at 2:32 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    @Rome604 has this set up. He loves the ride.
    Rome604 likes this.
  4. Aug 12, 2019 at 2:46 PM
    thunderhope
    oh damn great to hear and I was thinking of just doing a 1.5 lift in the rear
  5. Aug 12, 2019 at 2:46 PM
    thunderhope
    glad to hear!
  6. Aug 12, 2019 at 4:02 PM
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    I do. @EatSleepTacos is a truth teller.
  7. Aug 12, 2019 at 4:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    But not a lawn maintainer
  8. Aug 12, 2019 at 4:06 PM
    Rome604
    Dave
    Alexandria, VA
    Or a barrel chested freedom fighter.
  9. Aug 12, 2019 at 8:57 PM
    thunderhope
    Why does your truck look way higher in the rear?
    m603holden likes this.
  10. Aug 12, 2019 at 9:20 PM
    spudboy82
    spudboy82 Weekend Warrior looking forward to Utah getaways!
    Sean
    Logan, Ut
    Blazin Blue DCLB
    2017
    I want this set up where do I get it. How much are we looking?
  11. Aug 12, 2019 at 9:21 PM
    thunderhope
    Headstrong offroad!
    About 3.5k
  12. Aug 13, 2019 at 5:03 AM
    Rome604
    Dave
    Alexandria, VA
    Depends on what pictures you're looking at. Some of my Instagram pics were before I got the Kings adjusted and my new tires. Right now I'm set to 2" front and rear. I wanted to keep the natural rake of the truck.
  13. Aug 13, 2019 at 6:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Or when you had a rear lift but no front lift.....
    Rome604[QUOTED] likes this.
  14. Aug 13, 2019 at 6:49 AM
    Gunshot-6A
    Conner
    Everett, WA
    Just a regular cabron trying to evade the federales like the rest of us...
  15. Aug 13, 2019 at 6:58 AM
    rideawalrus
    rideawalrus Well-Known Member
    Four Corners area
    '16 TRD OR 4x4 Prem Tech/JBL Blazing Blue, King coils/shocks, deaver leafs
    King coils/shocks, deaver leafs Pelfrey skid soft topper Nalgene holder
    When I did my King and deaver leaf upgrade i got about 2 inches in the back from the leafs and was able to match that in the front with the shocks. However when off road the shocks had the tendency to top out much more easily since they were sitting higher in the travel because of the preload. If you don't do much offroad than that won't really be a problem. But since I do I lowered the front preload so the shock sits more in the middle of the travel at the King recommended height. Now they feel perfect offroad, and there is about a 1.25 inch rake between front and back of the truck.
    Rome604 likes this.
  16. Aug 13, 2019 at 7:24 AM
    thunderhope
    but if you wanted to you could raise the front coils to level out the truck right? I was just worried the Dakar would leave my rear higher then the front.
  17. Aug 13, 2019 at 7:32 AM
    Rome604
    Dave
    Alexandria, VA
    Correct. See @rideawalrus response above.
  18. Aug 13, 2019 at 5:04 PM
    thunderhope
    any issues running standard length rear king shocks with the dakars?
  19. Aug 13, 2019 at 5:07 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    That’s what I was going to say. If you are running Dakar’s you should get extended travel to take advantage of the extra droop you’ll get.
  20. Aug 13, 2019 at 5:11 PM
    SpeySquatch
    2016 TRD OR DCSB
    600# coil? You know the 3rd gen stock coil is 700# right? You want those 700# coils if you want to avoid sagging. Dakars should be fine...
    Also, rake is good. Helps with stopping and carrying loads better
