Dakar leaf springs squeaking
Discussion in 'Suspension' started by tacotruck93, Jan 22, 2018.
  1. Jan 22, 2018 at 4:48 AM
    tacotruck93
    tacotruck93 [OP] Well-Known Member
    Zach
    Akron,Ohio
    2012 TACOMA TRD OFF ROAD
    I have recently put dakar leaf springs on my truck (about 2 months ago). Out of nowhere they started to squeak and it is getting really annoying. I thought that they added the yellow spacers to help prevent that?? If anyone has a solution for this annoying problem the help would be much appreciated. Thank you!
  2. Jan 22, 2018 at 5:10 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    turn up the stereo......they'll just keep doing it, you can spray them with lube, it'll still happen eventually
    m603holden and gunn_runner like this.
  3. Jan 22, 2018 at 5:11 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Spray them with this stuff. You can thank me later. :D http://amzn.to/2DpAufX
  4. Jan 22, 2018 at 5:12 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Best thing you can do is hit them with Boeing T9, whenever my start squeaking I douche them with it. Usually lasts several months.
    gunn_runner likes this.
  5. Jan 22, 2018 at 5:15 AM
    Key-Rei
    Key
    Florida
    That stuff work pretty good, but I don't like how it attracts dirt and grit.
    I started using this after it was recommended to me as a good lube for Uniball uppers. It doesn't attract dirt like FF and last quite a bit longer. It's also thinner and less waxy so it gets in der mo deep like.
    https://www.amazon.com/gp/aw/d/B001...eshield+t9&dpPl=1&dpID=417rK6tOOoL&ref=plSrch
  6. Jan 22, 2018 at 5:30 AM
    badger
    badger Well-Known Member
    07 SR5
    Another option is this stuff: https://www.amazon.com/LPS-Premier-...?ie=UTF8&qid=1516627464&sr=8-1&keywords=lps-3
    It is a waxy lubricant suspended in a very light solvent. It penetrates into fine cracks, then the solvent evaporates leaving the wax. I have used this for over 10 years for all kinds of rust proofing and lubricating.
    Having said that, why would anyone build springs without squeak shims?? Aftermarket springs need them more than OEM because they articulate farther. I'd be pissed too.
  7. Jan 22, 2018 at 5:31 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Change the front bushing on them.​
  8. Jan 22, 2018 at 5:32 AM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    I have the Dakars and no squeaks for almost 50,000 miles. One thing I did is used synthetic grease at all pivot points during installation. I also used a torque wrench to torque at the correct values.
    tacotruck93[OP], Raincity and Key-Rei like this.
  9. Jan 22, 2018 at 5:35 AM
    Raincity
    Raincity Half man, half amazing.
    Lowermainland, B.C.
    '13 Mica Spruce DC.
    '12 DC TRD-RIP
    Did this as well. No squeaks and it's been a couple years.
  10. Jan 22, 2018 at 9:20 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    I replaced the front bushings when I installed them. No squeeks in almost a year.
    tacotruck93[OP] and ChadsPride like this.
  11. Jan 22, 2018 at 9:23 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
  12. Jan 23, 2018 at 9:35 PM
    tacotruck93
    Zach
    Akron,Ohio
    Thanks for all the help guys ill go get the front bushing tighten down to specs and ill also use some T9.
  13. Jan 23, 2018 at 10:36 PM
    tacotruck93
    Zach
    Akron,Ohio
    do you know off the top of your head the torque values ??
  14. Jan 23, 2018 at 11:14 PM
    tcjacado
    tcjacado Well-Known Member
  15. Feb 2, 2018 at 11:10 PM
    tacotruck93
    Zach
    Akron,Ohio
    Well after new bushings, new shackles and sprayed the hell out of the leaf springs I still have the annoying squeak!
  16. Feb 3, 2018 at 5:29 AM
    sgtnewundies
    Eric
    14 trd sport red
    Did you grease up the pivot point with synthetic grease?
  17. Feb 3, 2018 at 6:59 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I Hear you. It’s almost as annoying as one word, non-descriptive, thread titles.:boink:
    ABNFDC, Tatts521 and Rexfordian13 like this.
  18. Jun 7, 2020 at 9:21 PM
    JimEh
    JimEh New Member
    Jim
    2007 toyota tacoma DCLB
  19. Jun 9, 2020 at 4:23 PM
    jayway
    jayway Well-Known Member
    Josh
    Nevada City CA
    13 SR5 4x4 DCLB
  20. Jun 10, 2020 at 6:16 AM
    JimEh
    JimEh New Member
    Jim
    Awesome, figured there would be a better solution to the problem then fluid film or something
    jayway[QUOTED] likes this.
