Dakar leafs install question
Discussion in 'Suspension' started by iJDub, Jul 13, 2013.
  1. Jul 13, 2013 at 11:27 AM
    iJDub
    iJDub [OP] Well-Known Member
    Do I need to remove the shackle to take the leafs out? About to throw it on the lift soon to do this. Seems straight forward...any tips advice?
  2. Jul 13, 2013 at 12:05 PM
    smd3
    smd3 Well-Known Member
    You're swapping the factory springs for the Dakars, right?
    You'll need to unbolt the shackle from the frame/mount, the bolt heads on the shackle are inboard. you won't be able to remove the spring from the shackle, because the bolts won't pull out.
    The bolt heads must be inboard, they're too long to swap them around, I tried. :cool:
  3. Jul 13, 2013 at 12:09 PM
    smd3
    The entire swap is pretty straight forward. Just watch your rear brake lines, they're pretty much maxed out with the full droop on the stock suspension.
    Do one side at a time if you can, I'm not sure if that's possible with the Dakars. (Perhaps they're too big?) Make sure the axle is supported, including the driveshaft if you remove both springs at once. Otherwise it'll go nose down quick, because the springs/perches keep the axle from rotating.
  4. Jul 13, 2013 at 12:09 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
  5. Jul 13, 2013 at 12:10 PM
    bjboucher
    Brad
    San Antonio, Texas
    I did one side at a time, was simple.
