Dakar leafs with one removed review?
Discussion in 'Suspension' started by TacoBrah, Jan 29, 2014.
  1. Mar 16, 2015 at 7:12 AM
    #41
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    Here's mine with icon stage 1 and Dakar in the rear. It rides a bit stiff but idk if it broken in a bit or I'm used to it already. My mom has a '15 stock Tacoma and they drive about the same if not mine feels a bit smoother.
    Details: icon stage 1 with extended travel coilovers, icon tubular UCAS, Dakar leaf springs, extended rear brake line, 17x8.5 SCS wheels, LT285/70/17 toyo at2 tires. The rear is a bit higher but it doesn't bother me. I could raise the front a bit but I like how the icons ride and feel.
    PreTaco170 likes this.
  2. Apr 4, 2015 at 8:30 PM
    #42
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    I need to put back the top overload leaf into the pack, you guys think I can do it without unbolting the entire leaf pack from the frame?
    I'm thinking of just unbolting the rear shock, the u-bolts, the retainer clips, let the lower leafs fall down, slide in the additional leaf, then use the jack to lift everything in place. The centering pin may cause some issues though.
    Anyone done this?
  3. Apr 5, 2015 at 10:32 PM
    #43
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    That's really good info. I want a suspension upgrade but don't want a lot of lift. I would like 2" front and not much more than 2.5 rear. I have been considering 884's for my DCLB but wonder which configuration of Dakars would work best.
    OZ do you have measurements (sag) with 700 - 1000 lbs on a dakar pack? I didn't think they would drop much more than 1.5" but could be wrong.
    Also I wonder if it would look goofy unloaded; 884's up front on a dclb (~2" lift or just less I guess) and full dakar pack in the rear (closer to 2.5-3").
  4. Apr 5, 2015 at 10:41 PM
    #44
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    No measurements but with 1200 lbs of timbers and my cap onboard I was just contacting the upper overload
    Dakars return 2 3/4" of rear lift on average
    Crom likes this.
  5. Apr 6, 2015 at 7:35 AM
    #45
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    You can do this.
    I recently removed the overload and added a progressive AAL while leaving the springs attached at the spring hangers.
    Large vice grips came in handy keeping everything together :)
  6. Apr 6, 2015 at 8:02 AM
    #46
    OZ-T
    Peter North
    British Columbia
    You added a progressive AAL to the Dakar pack ?
  7. Apr 8, 2016 at 9:29 AM
    #47
    virvak2
    virvak2 Well-Known Member
    Kyle
    Castle Rock
    '13 TRD Off-Road
  8. Jan 27, 2017 at 7:20 PM
    #48
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Did you do this to the Dakar?
  9. Jan 28, 2017 at 4:36 PM
    #49
    mistermanny
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    Above activity was performed on stock springs.
    While removing overload from stock springs, and adding AAL.
  10. Jan 28, 2017 at 4:42 PM
    #50
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    Hi Oz!:bowdown:
    I have the full pack with extra leaf, and it was a bit jouncy but I dialed my compression on my shocks back some and left the rebound alone ( BP51s) and it's much more compliant. Have about 350 lbs extra in back with bumper tire gas and recovery box just inside the tailgate. Put the whole stack in because otherwise with all my camping gear it looks like a prohibition bootlegger with all the bro droop.
