Dakar pack
Discussion in '1st Gen. Tacomas (1995-2004)' started by 07toyota1991, Feb 9, 2020.
  1. Feb 9, 2020 at 6:07 PM
    eon_blue
    Azusa, CA
    A couple hundred pounds in the rear would bring it down I bet, Dakars aren't a heavy duty pack so it won't take a big load to make them sag. Mine used to ride the bump stops with a full bed of camping gear and my RTT, and that was with the AALs
    You can test it out by getting a few 50lb sand bags and see how much weight it takes to make it go down 1". Then depending on the weight of the bumper you'll know if that will work or not
    I would try and do it that way rather than removing leafs if it were me, since removing leafs makes the weight carrying capacity go down
    07toyota1991[OP] and Kwikvette like this.
  2. Feb 9, 2020 at 6:10 PM
    07toyota1991
    07toyota1991 [OP] Well-Known Member
    1999 Toyota Tacoma Regular Cab 2.7 5spd
    5100's with OME 883, Dakar's, SCS Ray 10, 285/75/16 Cooper STT Pro, LCE header, Magnaflow exhaust, ARE shell, Addicted offroad front plate bumper with Warn VR8S
    Thank you everyone!!
  3. Feb 9, 2020 at 6:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You could go outside and take a side picture...takes 5 seconds to figure out the difference you're trying to point out.
    I say that because I think I've seen that picture posted multiple times before already.
  4. Feb 9, 2020 at 6:17 PM
    07toyota1991
    I dropped the truck off for alignment early this morning. I will get an updated picture tomorrow evening when I have the truck back.
  5. Feb 11, 2020 at 2:48 PM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    I’ve only ever seen 883s recommended for V6 extra cabs or double cabs. How’s the ride so far?
    I’ve been running 880s, Dakars, and Nitrochargers all around since July 2018. Still a good amount of rake, so I’m in the same boat and starting to consider my options to bring the back end down.
  6. Feb 11, 2020 at 2:57 PM
    07toyota1991
    my ride is really good. I have an aftermarket plate bumper with winch, that’s why wheelers recommended the 883
    lukester78[QUOTED] likes this.
