Dakar springs worn out?
Discussion in 'Suspension' started by Voodoo Rufus, Apr 6, 2017.
  1. Apr 6, 2017 at 2:35 PM
    Voodoo Rufus
    Voodoo Rufus [OP] Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    When I was installing my traction bar for my Tacoma to kill axle wrap, it was noted that my Dakar springs are kind of 'flat'. The center part over the axle is in mild reverse arch, and the ends are still bowed correctly. So they're kind of in a "W" shape. I am not using the overload leafs, and the standard bed load is the rubber mat and a hard retract tonneau cover, adding 150-200lbs to the rear.
    The question is, are these worn out?
    If so, I think I'll try different springs next time, as these have always ridden pretty hard.
    Options if worn out, and looking for opinions on:
    1. Put overload leaf back in to see if it helps.
    2. Replace with other springs. Thinking Wheeler's 5-leaf HD.
    3. Total Chaos spring under conversion.
    I have access to a welder, and I'm keeping the truck until it falls apart so I don't mind a little more modding without going full crazy on long travel.
    What say ye?
  2. Apr 6, 2017 at 2:51 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    I would try #1 first, since you have it, and the only cost is time. #3 has me thinking bad thoughts about spending money, that Im trying to suppress. :frusty:
  3. Apr 6, 2017 at 2:53 PM
    DrFunker
    DrFunker Well-Known Member
    How old are they?
    Miles on them?
    How long ago installed?
  4. Apr 6, 2017 at 2:53 PM
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
  5. Apr 6, 2017 at 2:54 PM
    Voodoo Rufus
    Bakersfield, CA
    Age....6-7 years.
    Miles: ~45k.
  6. Apr 12, 2017 at 7:49 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    get the Wheelers HD set... so you can come back here and do a compare/contrast between them and the OME ones... because I have the OME ones and I want someone to try out the Wheelers ones before I swap.
    Do It For Science
  7. Apr 12, 2017 at 8:11 AM
    Voodoo Rufus
    Bakersfield, CA
    If the overload doesn't work....but....but...SUA! :burp:
  8. Apr 12, 2017 at 8:25 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    this is a side effect of removing the overload spring. with out it they allow the springs to reverse arc easier which is what kills springs faster.
    you can try putting it back in but not sure how much it will help. is the current setup not enough lift for you? if its fine, then just leave it.
  9. Apr 12, 2017 at 8:30 AM
    Voodoo Rufus
    Bakersfield, CA
    I'm not really after more lift. The duty my truck sees doesn't require it, nor am I trying to fit bigger tires.
    I originally took out the overloads to lower the truck a bit and try to get rid of axle wrap. Didn't know I might kill the springs faster.
  10. Apr 12, 2017 at 9:13 AM
    paranoid56
    San Diego
    14 double cab taco
    keeping the overload would have helped a bit with axle wrap also. but a good anti wrap bar is the best setup. if the hight is fine for you, just keep running them unless you just want to change something :D (which is totally ok too :D )
  11. Apr 12, 2017 at 9:25 AM
    Voodoo Rufus
    Bakersfield, CA
    Yeah, removing the overload didn't help with the wrap at all, but required less cranking down on the front coils to keep it somewhat level.
    Trac bar ftw.
