Dakars and Squeaking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ejewels, Apr 17, 2020.
  1. Apr 17, 2020 at 9:19 AM
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    I've had mine for 2 years now with no noise at all and I live in Colorado. Have they ever been greased? The anti friction pads are greasable and should be greased like any other routine maintenance. A lot of people install them and never grease them then complain about the noise. Once the pads wear thru since they have no grease it's metal on metal. There is a video some where that shows how to do this. They do sell new anti friction pads if they are worn out too. The bushing could be worn out too if they weren't greased when installed. I have some OCD when it comes to maintenance just that I know if I'm on a trail in the middle of no where I can count on things not to prematurely fail.
  2. Apr 17, 2020 at 9:24 AM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    It’s a feature, adjustable suspension.
    mine squeak. Not enough to annoy me. But plenty of solutions mentioned here already. Also doesn’t matter if you are medium or HD Dakar’s.
    Twizted[QUOTED] likes this.
  3. Apr 17, 2020 at 12:53 PM
    ejewels
    ejewels [OP] Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Yeah not sure to be honest. The guys who did it know their stuff so i'm assuming they lubed it. Can I do everything you explained without taking the leafs apart?
  4. Apr 17, 2020 at 3:53 PM
    Age315
    AJ
    Castle Rock, CO
    Yes they were designed to be greased with out taking them apart. There are 2 on each pack I believe that you can't get to from the bottom so you have to spread the leafs. Look at post 4 he used a screw driver to spread the leafs but I've used a pry bar. It is much easier and safer if you do it with back end in the air and no weight on the springs. Found the video it's worth a watch and how I do mine minus the lift.
    https://m.youtube.com/watch?v=yPp9X4JdwHI
    Rick111 likes this.
  5. Apr 17, 2020 at 3:58 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I have the new “squeak-free” version and they still squeak like a MFer. Actually mine creak now and sound like they are falling off.
    ejewels[OP], Twizted and LostHusker like this.
  6. Apr 17, 2020 at 3:59 PM
    jowybyo
    Joe
    Baltimore, MD
    I need to grease mine like every week and a half to keep them squeak free. It’s a waste of time.
    Twizted likes this.
  7. May 10, 2020 at 5:36 PM
    ejewels
    CT
    How are you guys jacking the rear up without pressure on the pumpkin?
