Dakars Leaf Pack Question
Discussion in 'Suspension' started by JW87, Mar 17, 2018.
  1. Mar 17, 2018 at 3:41 PM
    JW87
    JW87 [OP] Well-Known Member
    JW
    Richmond,VA
    2015 TRD Sport 4x4 DCLB
    American Racing black bajas with Cooper RTXs 265/70/17. Black Depo tail lights. LED interior, license plate and reverse lights.Debadged. OME 885 coils and Dakar leaf packs. OME Nitros front and back.
    So I just order Dakars el095r leaf packs. I have a toolbox and pull a trailer from time to time. It says the are medium duty from 0 lbs to gvw. My question is am I going to have the dreaded bro lean? Anyone out there running them your feedback is much appreciated.
  2. Mar 17, 2018 at 3:42 PM
    JW87
    JW
    Richmond,VA
    I forgot to mention it is a dclb with ome nitrochargers front and back and 885 springs.
  3. Mar 17, 2018 at 3:51 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You should be good. I have 886s on the front and the 95r pack on the rear. It has a slight rake and still sits pretty level when towing.
  4. Mar 17, 2018 at 3:52 PM
    JW87
    JW
    Richmond,VA
    Awesome. Do yours squeak alot. I’ve heard the 95s were suppose to have improved from the previous leaf packs.
  5. Mar 17, 2018 at 3:54 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    They still squeak and it gets worse when they get mud and grime in them. After a good pressure wash they stay fairly quiet until the next time you get them dirty.
  6. Mar 17, 2018 at 3:57 PM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    You'll be absolutely fine. I run them with nitro's in the rear as well. I've towed quite a bit and have had a toolbox in there for the past 8 months since Ive had them on. No bro lean. They squeak when dirt/sand get in them. Theres products you can spray in there to prevent or eliminate the squeak. I literally just bought the AAL for them because I'm going to put my CBI rack back on for the summer. It's only $70. I'll let you know how my ride changes when I throw it on.
  7. Mar 17, 2018 at 4:03 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Mine squeek when it gets cold out. Tried putting in leafsprings liners and they still squeek.
  8. Mar 17, 2018 at 4:14 PM
    JW87
    JW
    Richmond,VA
    Thnks for the feedback fellas.
  9. Mar 17, 2018 at 8:48 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Mine are only about 2,500 miles old but they don't squeak. Also, they are very firm since I have no weight so I'm sure you'll be just fine with the tool box and trailer as the medium are pretty stiff. I'm actually contemplating putting a few bags of concrete in the bed to May them not busy my kidneys! I'm running Fox 2.0 RR rear shocks.
