Dakars not quite enough for armor
Discussion in 'Suspension' started by I3uller, Sep 23, 2016.
  1. Sep 23, 2016 at 8:17 AM
    I3uller
    I3uller [OP] Well-Known Member
    Too far South
    I'm running Icons all around with Dakars in the back which put it just how I wanted...until I went and put all my trail armor on. Running the Pelfrybilt HC with swing out and everything so it's gotten pretty heavy back there and I'm looking to get a little more lift back. My immediate thought was to just do an add a leaf to them but the incessant squeaking from them combined with the effort to actually add the extra leaf makes me open to just getting a different leaf pack. Long story short I'm just wondering if anyone has experience swapping Dakars to another leaf pack and if it gave you a little extra lift. Maybe just to add another inch or two. Thanks for the help as usual!
  2. Sep 23, 2016 at 10:56 AM
    GreenMtnTaco
    GreenMtnTaco Well-Known Member
    Adam
    Montana
    05 Access Cab
    Suspension: Icon & OME Armor: Budbuilt Skids, CBI Sliders Drive Train: 4.56 gears & ARB Rear Locker Misc: ARE MX Series, Sleeping platform
    There really aren't a lot of options out there. Pretty much Dakar with AAL, All Pro Expedition, or I've heard people ordering custom deavers.
    Of the three I'd personally just add the AAL, but if you have the money all Pro expeditions are supposed to be stiffer and provide more lift than the dakars without AAL.
    DustStorm4x4 likes this.
  3. Sep 23, 2016 at 11:02 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
  4. Sep 23, 2016 at 8:30 PM
    I3uller
    Too far South
  5. Sep 24, 2016 at 12:53 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    rstuart likes this.
  6. Sep 24, 2016 at 1:04 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    They don't replace the leafs at all, or anything else.
    They work fine for off-roading with Daystar cradles.
  7. Sep 24, 2016 at 1:10 PM
    I3uller
    Too far South
  8. Sep 24, 2016 at 1:11 PM
    T4RFTMFW
    Shackle flips are no good.
  9. Sep 24, 2016 at 1:14 PM
    T4RFTMFW
  10. Sep 24, 2016 at 2:22 PM
    I3uller
    Too far South
    Thanks for the info. It seemed like something that would completely change the suspension in ways that could make things go bad. So those bags just inflate up and you can set the rear independent of the leafs? Sorry I'm totally dumb on bags. Also you just set them to a pressure how exactly?
  11. Sep 24, 2016 at 2:29 PM
    T4RFTMFW
    All they do is restore your height when carrying a load.
    They have a Schraeder valve like a bike tire. Inflate it to your needs for each load or run at minimum PSI when not needed.
  12. Sep 24, 2016 at 2:37 PM
    I3uller
    Too far South
    Awesome. Can I keep it filled up full time to restore the height pre armor?
  13. Sep 24, 2016 at 2:44 PM
    T4RFTMFW
    Yup. Totally adjustable.
    Just make sure they're long enough when inflated for your particular setup.
  14. Sep 25, 2016 at 2:02 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Why are shackle flips no good? I did one along with dakars and I've got all kinds of rake even with my swing out plate bumper holding a 35 and rtt on the back.
  15. Sep 29, 2016 at 11:45 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Curious myself....?
  16. Sep 29, 2016 at 11:46 AM
    T4RFTMFW
  17. Sep 29, 2016 at 11:52 AM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Good to know if you use a shackle flip no more warranty on the leaf pack and the bit about bending or cracking the C-channel is concerning.
    Thanks for the info :thumbsup:
    T4RFTMFW likes this.
  18. Sep 29, 2016 at 12:01 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    I also would prefer to avoid FOTFUSE!
