Dakars + (...Shocks?...)
Discussion in 'Suspension' started by Red October, Jan 21, 2017.
  1. Jan 21, 2017 at 3:20 PM
    Red October
    Red October [OP] Well-Known Member
    2013 DCSB
    So, lotsa guys running Dakars out there I see. But what shocks?
    Do the standard lift (1-2" lift) shocks from the normal manufacturers work well? I would think they are very limiting to the travel potential of these springs.
    Using the stock shock mounts, what is a good shock that wont limit the springs too much?
  2. Jan 21, 2017 at 3:27 PM
    DrFunker
    DrFunker Well-Known Member
    I have Dakars, top overload leaf removed, with Bilstein 5125s. Stock shock mount.
    Am very happy with the set up.
    Sna and ChadsPride like this.
  3. Jan 21, 2017 at 3:28 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    RCD Extended Length Bilsteins
  4. Jan 21, 2017 at 3:29 PM
    DrFunker
    Those are B110s, right Chad? Could be wrong.
    ChadsPride[QUOTED] likes this.
  5. Jan 21, 2017 at 3:29 PM
    ChadsPride
    That, is a wonderful questions sir!!
    :anonymous:
    @HeadStrong Off-Road
  6. Jan 21, 2017 at 3:30 PM
    DrFunker
    hahah
    I am on their site right now.
  7. Jan 21, 2017 at 3:30 PM
    DrFunker
    http://www.headstrongoffroad.com/store/p86/RCD/Bilstein_5100_Extended_Length_Rear_Shock_(PAIR)_-_B110.html
    RCD/Bilstein 5100 Extended Length Rear Shock (PAIR) - B110
    SKU: F4-BE5-B110-T5
    $206.50
    The Toyota Tacoma Bilstein 5100 Series Shocks are designed specifically for your lifted vehicle. These shock absorbers feature a corrosion resistant zinc finish and vehicle specific valving. 5100 Series shocks use Bilstein's superior single tube high gas pressure design for consistent fade-free performance and long life. Bilstein's patented Digressive self-adjusting valving delivers improved damping control and a smooth ride for your truck on all road surfaces at any speed.
    Shock Specifications:
    - Can support, not provide 3"-4" of lift
    - Collapsed: 16.34"
    - Extended = 27.28"
    - Travel = 10.94"
    ChadsPride likes this.
  8. Jan 21, 2017 at 3:31 PM
    ChadsPride
    Yessir!!! Those are them, I can even see the Race Car Dynamics decal on there.
    DrFunker[QUOTED] likes this.
  9. Jan 21, 2017 at 3:32 PM
    DrFunker
    5125
    "The 5125 Series offers Bilstein technology for custom applications. 5125 Series shocks feature Bilstein's superior single tube high gas pressure design for the up most in consistent fade-free performance and long life. Bilstein's patented Deflective self-adjusting valving delivers improved damping control and a smooth ride on all road surfaces at any speed."
  10. Jan 21, 2017 at 3:33 PM
    DrFunker
    How are we doing OP? :rolleyes:
  11. Jan 21, 2017 at 3:35 PM
    DrFunker
    @Red October Make contact with Marie from HS. She will help ya out. :thumbsup:
  12. Jan 21, 2017 at 6:48 PM
    Red October
    2013 DCSB
    Thanks for the Quick replies guys!
    From what I have read the RCD B110's are a little bit long, and so the bump stops need to be adjusted. Is that right?
  13. Jan 21, 2017 at 6:58 PM
    ChadsPride
    Been running em with a full Dakar leaf packs for over 6 months now with zero issues
    ready6delta likes this.
  14. Jan 21, 2017 at 7:03 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    Andrew H and ChadsPride like this.
  15. Jan 23, 2017 at 1:36 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    I am a little late to the party but yes those are the shocks. They go by many names...extended Bilsteins, RCD Bilsteins, longer 5100's, B110's and their official part # F4-BE5-B110-T5.
    Good job guys!
  16. Jan 23, 2017 at 1:37 PM
    HeadStrong Off-Road
    There are quite a few options of rear shocks to run with the OME Dakar. You can run the OME nitrocharger sport rear shocks. They were designed to be used with the OME Dakar pack but have a conservative extended length so will limit the droop of the pack. The upside of that is, since they are the limiting factor, longer brake lines are not necessary. Other than that you can run the RCD/Bilstein extended length 5100's, the extended length Fox's and Icon rear shocks each have a longer extended and collapsed length, since that is the case you will have to run longer rear brake lines and may have to modify your factory bump stops in order to hit those before you fully collapse the shock. There are also the Bilstein 5160's which have an extended length as well and come with their own brake line extension brackets. You could also run the Bilstein 5125's but since those are a universal shock you would have to look at the extended and collapsed lengths and see which ones you prefer. Also, since those are universal, they would not have vehicle specific valving.
    Rear shocks work a little differently. When sourcing rear shocks it is recommended to know what the extended and collapsed length of the shock is and how that works with the rear lift you are going with.
    The biggest things to take into consideration are making sure you cycle the suspension to ensure that you are hitting the factory bump stops before you fully collapse the shock and that when the shock is fully extended your brake lines are not taut.
  17. Jan 23, 2017 at 2:11 PM
    DrFunker
    :D
  18. Jan 23, 2017 at 2:12 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I use skyjacker hydro 7000s on the rear right now (budget) and 5100s up front. Want to get 5100s for the rear soon tho, but i cant complain about the 7000s especially for the price point.
  19. Jan 23, 2017 at 5:17 PM
    Red October
    2013 DCSB
    Thank you @HeadStrong Off-Road for your responses and supporting our habits, Great info!
    Right now I'm in the research stages of a new build. I'm getting ready to make some hopefully educated purchases that won't need to be made over again too many times. My trucks goals are to be a true Jack-of-all-trades. I don't really crawl, but I do run into the odd rock garden. To be honest most of what my truck will see is pretty mild, dirt roads and desert trails, nothing insane, and a good bit of highway driving to get there, along with daily driver duties, hardware store and lumber yard runs with a few trailer pulls mixed in for good measure.
    I'm aiming at a nice mid-travel front end. I have some Icon 2.5 non-res extended travel CO's for the front that I will run with some type of UCA. Im pretty sure on Dakars in the back. Im wondering if the B110/Dakar combo would complement that front end setup for "all around truck" duties?
    Or one of the other mentioned shocks?
  20. Jan 24, 2017 at 3:13 PM
    HeadStrong Off-Road
    IMO, the B110's seem to hold their own. I personally had them on my truck with the Dakar pack for quite a while. I use my truck in a similar way as you. I will haul stuff from time to time, I do have consistent weight in the bed of the truck, I will crawl (some), and desert run. The travel seemed to work really well for most things but the one thing that I did notice was the shock did heat up quite a bit when I was desert running. This is really common of non-resi shocks so I did eventually upgrade to a 2.5" resi rear shock.
