Dakota Digital install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by finecamaro69, Nov 2, 2009.
  1. Nov 2, 2009 at 10:39 AM
    finecamaro69
    finecamaro69 [OP] Member
    Charlotte, NC
    06 TRD sport 4WD
    2" spacer Suspension lift, Dakar Leafs
    Ok since I could only find one write up on this and it was for an automatic I thought that I would help anyone else out there that was planning on installing one of these in a manual. When I bought my truck the speedometer was about 15-20 mph off at higher speeds (I was going 55 speedo said 70). So I picked up the Dakota on ebay for $75 and free shipping. My truck is a 2006 Access cab TRD sport V6 w/ manual transmission.
    First step find the speed sensor wire. I actually tied into the speed sensor wire going directly into the guages so I wouldn't mess up ABS or anything.
    I tapped into the red wire w/ a yellow stripefor the speed info.
    The side of the wire going into the plug is the output from the module and the the other end is the input.
    I used the purple wire in the same location for ACC power. That way its the same power as the gauges anyway.
    This is the module, I connected the output wire to the out 4 slot. Also switches 1 and 4 are in the on position.
    For a ground I just tapped into one of the ground wires (white w/ Black stripe) at the kick panel on the drivers side.
    I just installed it on the back of the change drawer with double sided tape for easy access to calibrate it.
    As for calibration just look at the instructions that come with it. I found it easiest to use the calibrate in park method. Hope this helps for someone. Let me know of any questions there still are.
  2. Nov 2, 2009 at 11:49 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    great job!
  3. Nov 5, 2009 at 10:49 AM
    finecamaro69
    Charlotte, NC
    06 TRD sport 4WD
    The dakota digital also fixed the odometer when I installed it this way so now my mileage won't be too high.:D
  4. Nov 17, 2009 at 11:26 PM
    randy69
    randy69 Member
    Weed, Ca
    05 Tacoma 6" pro comp w/35's
    I was looking at buying the dakota digital. How is it working? I have an 05 Access Cab 4 cyl with a manual transmission. I wonder if the wires will be the same? how did you determine which wires to use?
  5. Nov 18, 2009 at 5:23 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    You were 15MPH off? That's crazy. Are all Gen2 years like that?
  6. Nov 18, 2009 at 5:29 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    x2 how in the world was your speedo that far off?? my gen 2 was/is not off like that. and it looks like you may still have 265 size tires on there :confused:
  7. Nov 18, 2009 at 6:52 AM
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
    Nice work, but why all the hassle? Take it to the dealer and tell them to program it right like it should have been from day one when you bought the truck!
  8. Nov 19, 2009 at 1:38 PM
    finecamaro69
    Charlotte, NC
    06 TRD sport 4WD
    When I bought the truck it was used with the lift and tires all on there. The reason why the speedo was that far off was the previous owner put new gears on there. I think they are 4.10's. The dealership said that they couldn't reprogram a speedo after they said that they could at the time of sale. So this was the cheapest option that I could find. Also it is still working perfectly.
    To determine which wire to use I looked in the pdf manual I found online, and found the schematic for the combination meter(guage cluster). Found the speed sensor wire and a power wire and went from there. The 05' should be similar, but just check the schematic to be sure.
    Also my tires are LT285/60R18, so they are only about an inch bigger than stock.
  9. Nov 19, 2009 at 2:58 PM
    dktaco
    Josh
    ^ Makes sense thanks for clarifying.
  10. Aug 14, 2012 at 6:02 AM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    I really need to calibrate my speedometer. Where is the install for an automatic?
  11. Aug 14, 2012 at 10:56 AM
    finecamaro69
    Charlotte, NC
    06 TRD sport 4WD
    It's basically the same install. The only difference would be the wiring harness. Others have tapped into the speed sensor wires near the glove box. I would check out schematic for the automatic and find where the best tap in location would be. I couldn't find the install that I had seen before. It has been 3 years since I installed this and it still works great.
  12. Aug 14, 2012 at 12:38 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Nice write up! I thought about going with a Dakota digital but decided not to for various reasons. I decided to go with a more plug and play type option and went with hypertech's speedometer calibrator. Super easy to install and works perfectly.
    A little bit more $$ but does the same thing. Perfect for simple minded ppl like me :D
  13. Aug 14, 2012 at 4:51 PM
    MrGrimm
    Dean
    Wisconsin
    See build page
    Did you get the "In-Line Speedometer Calibrator Module"? or the "Speedometer Calibrator"?
  14. Aug 14, 2012 at 4:55 PM
    DueNorth
    Sorry, I should clarify...
    It would be the "in-line speedometer calibrator module"
  15. Aug 14, 2012 at 5:00 PM
    MrGrimm
    Dean
    Wisconsin
    See build page
    Cool, I will have to check that out.
  16. Aug 14, 2012 at 9:54 PM
    badger
    badger Well-Known Member
    07 SR5
  17. Aug 15, 2012 at 5:16 AM
    Hubs
    Hubs Well-Known Member
    I have noticed that my speedo is 5-7 mph offset from my GPS at hiway speeds also. Truck is all stock.
