Dakota lithium 135AH lipo4 Dual Purpose Battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrSomis805, Jul 24, 2023.
  1. Jul 24, 2023 at 7:00 AM
    MrSomis805
    MrSomis805 [OP] Member
    Andrew
    2018 Cavalry Blue Tacoma TRD Pro 3.5L
    https://dakotalithium.com/product/d...ar-truck-battery-plus-deep-cycle-performance/
    Is anyone familiar with swapping out to the Dakota lithium lipo4 135AH Dual Purpose Battery? I have limited space and want to prevent needing a separate house battery. I just got a 12v fridge freezer and need a way to keep constant power to the unit when the truck is off. I have an OTT tune so I can just increase the charging voltage to 14.4 in the systems computer. The recommended charge for longevity is 70 amps. What does the stock 2018 pro alternator output? Would I need a bigger alternator to reduce strain. No accessory lights just bright ass lumenex led headlights. Is it best to run a dedicated wire from the block for continuous power or tap into a fuse box? The cooler has a removable fuse, do I need an inline fuse?
    Fridge/freezer specs in included image
    I know I have a lot of questions in this post so thank you in advance for any insight you can lend
    GilbertOz likes this.
  2. Jul 24, 2023 at 7:11 AM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    Why not just get a Jackery or Bluetti? A lot less trouble and expense, and more versatile.
    Chew and golfindia like this.
  3. Jul 24, 2023 at 7:15 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    No idea about your questions but I just started working on a Duramax van that has that battery, well two of them, there's another one under the van. Yesterday I extended the battery cables for the primary battery.
    Sorry I'm of no help. I never heard of this brand battery before but damn they are expensive! $1200 ea! I had no idea.
    MrSomis805[OP] likes this.
  4. Jul 24, 2023 at 7:45 AM
    MrSomis805
    Andrew
    I honestly care less about the cost than having the convenience of a single battery system with these specs and an 11yr warranty. I'm from the mindset "it's cheaper and more convenient to do it once the right way and forget about it"
  5. Jul 24, 2023 at 7:54 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Or until the battery explodes and melts your truck.
  6. Jul 24, 2023 at 8:22 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    You might want to check out this video. I found it rather interesting. The conclusion is that using a standard automotive alternator to charge a lithium battery could cause the alternator to overheat and burn out. Doesn't mean it can't be done, you just have to have the right equipment to do it.
    https://youtu.be/jgoIocPgOug
  7. Jul 24, 2023 at 8:44 AM
    2019 TRD Off Road
  8. Jul 24, 2023 at 8:49 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Correct. It's not the battery itself that would be the problem, it's the OEM alternator. It would need to be swapped out for something similar to what's in the video. The OP did say that money was no object. :)
  9. Jul 24, 2023 at 9:12 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Doing it once the right way is a dual battery setup with an automatic charging relay
    MR E30 and Chew like this.
  10. Jul 24, 2023 at 9:23 AM
    MrSomis805
    Andrew
    Has anyone actually researched this specific battery before replying to this post? These batteries are specially made for this and made to charge from your alternator. Please don't give me your unwarranted and fear based OPINIONS
  11. Jul 24, 2023 at 9:35 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    I do not have the dakota battery but it looks like a good setup. Looking through the specs I did not see any major red flags and it has built in battery monitoring so you should be pretty protected. 3rd gen alternator size is 130 amp so you should be fine on that end.
    Is there any reason why you are not going with a Northstar/X2 power 27f AGM? Thats what I and many others on this site have and they seem to do the job well.
  12. Jul 24, 2023 at 9:36 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    You are new here so you may not realize it yet, but when you post and ask for opinions you are going to get them regardless of what you perceive their value to be. If you ask, be ready to get all kinds of answers. If that bothers you, you might want to reconsider asking. FWIW, you asked about the alternator, I gave you some info on it. Do with it as you will.
  13. Jul 24, 2023 at 9:56 AM
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    Oops, per OP's wish, I deleted my post as I am not using a Dakota Battery.
  14. Jul 24, 2023 at 12:10 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Yeah you want to tone down the attitude a bit, 3-post bro. Welcome to TacoWorld!
    Malvolio, roundrocktom and RIX TUX like this.
  15. Jul 24, 2023 at 3:30 PM
    MrSomis805
    Andrew
    I liked your video on the alternator but the batteries used in it are completely different so it doesn't really apply to my question
  16. Jul 24, 2023 at 3:43 PM
    MrSomis805
    Andrew
    Because these new batteries seem to be better in every way. Larger capacity, discharges to lower percentage, recharges faster, less weight. Why are you all using the northstar/x2 agm excluding the price difference. I just really don't want to have to find a place to put a house battery with the limited space in my build. More power in a smaller package. Be honest, am I missing something?
  17. Jul 24, 2023 at 6:20 PM
    GilbertOz
    GilbertOz Driver
    CA
    LiFePo lithium replacement batteries really are superior in almost every way. One drawback if you live in a very cold climate is that they don't like being charged at below-freezing temperatures. Apparently Dakota Lithium has started incorporating special internal heating units within the batteries to try to address this issue.
  18. Jul 24, 2023 at 6:35 PM
    MrSomis805
    Andrew
    Exactly my point. I found the company after reading an article about doing this a while back. Now I'm just searching for specifics and anyone with experience on this really cool new system. I know there will be haters but saying my shit will blow up and catch on fire was just ignorant, lol
  19. Jul 24, 2023 at 6:44 PM
    MrSomis805
    Andrew
    I also want to add that I am not in any way condemning agm batteries or the way anyone else chooses to outfit their rig.im hoping this battery will be enough to keep me powered up off grid but if I ever find I need more power, I'll just add another lithium to the system. I like to be prepared and would prefer to have more than I need than not enough
  20. Jul 25, 2023 at 4:36 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    No not really, I just wanted to make sure you knew a potential other option that would have a similar function as a dual purpose start/house battery in 1. The weight difference will be a great thing. The standard batteries that come in these trucks can tear the sheet metal if you offroad alot.
