Dakota lithium 135AH lipo4 Dual Purpose Battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrSomis805, Jul 24, 2023.
  1. Jul 26, 2023 at 1:08 PM
    MrSomis805
    MrSomis805 [OP] Member
    Andrew
    2018 Cavalry Blue Tacoma TRD Pro 3.5L
    Mine was all rusted out when I bought it. Definitely going to put some rust prevention paint stuff on there after cleaning it up a bit but I have an aluminum bumper and badlands winch. Trying to save weight wherever I can
  2. Jul 26, 2023 at 9:24 PM
    OrangeCrash
    OrangeCrash Well-Known Member
    Kingman, Az
    I already have dual batteries but if I didn't this would be the way I'd go. It'd save me about 60lbs and be much less complicated. I'd still run a fuse block and dedicated wiring for the fridge.
    roundrocktom likes this.
  3. Oct 11, 2023 at 8:10 AM
    silverarrow
    silverarrow Active Member
    Vermont
    2020 TRD Off-Road
    OME Heavy Duty Lift
    Did you end up swapping to the Dakota Lithium battery? I'm on the fence between the 27F and a dakota lithium that has more power to avoid a dual battery set up.
  4. Oct 21, 2023 at 2:20 PM
    flat_tire
    flat_tire Well-Known Member
    Independence, KY 41051
    2016 Tacoma TRD Off-road ACLB blue, 2018 Tacoma TRD Sport DCSB white, 2020 supercharged Tacoma Limited DCSB magnetic grey metallic, 1993 AMGE HMMWV, 1993 Ford Mustang GT 5.0 supercharged
    2020 Tacoma: Icon stage 9, Magnuson supercharger, URD full exhaust, solar 2018 Tacoma; OME 2in suspension 2016 Tacoma: Falcon front and rear rate adjustable suspension, rear airbag lift
    I've been on the fence about buying one of these for about 3-years. I just can't justify the cost but prices seem to be creeping down year by year
    $599 60Ah group 24F battery size equivalent 16lb
    https://dakotalithium.com/product/d...r-starter-deep-cycle-lifepo4-battery-1000cca/
    $1189 135Ah group 24F battery size equivalent 27lb
    https://dakotalithium.com/product/d...ar-truck-battery-plus-deep-cycle-performance/
    My current setup is an Interstate 24F AGM in the stock battery location and 2 mini 100Ah (19lb ea) lifepo4 batteries in the bed both equipped with heaters and temp monitoring.
    https://www.amazon.com/Litime-4000-15000-Upgraded-Lifespan-Trolling/dp/B0C2HFJQP9
    GilbertOz likes this.
