Dakota universal interface, 33s and the abs system
Discussion in '1st Gen. Tacomas (1995-2004)' started by AppMtnTaco, Feb 11, 2015.
  1. Feb 11, 2015 at 8:26 PM
    AppMtnTaco
    AppMtnTaco [OP] No Colon, Still Rollin’
    Nick
    Littleton, Co
    Black 2003 SR5 4X4
    3in Lift with Toytec/Bilstein Coilovers, AllPro 3 inch rear leafs and ToyTec shackles. Trail Gear front tube bumper and sliders. Satoshi Grille with custom Hella light mount. Custom bedrack with Yakima Basket. Future mods- Going long travel!!!!!!!
    I'm going to 255/85-16s from 265/75-16s on my 03 v6 and have read about the issues that causes with the speedo and tach... I found a write up on installing a Dakota Digital Interface to correct the problems with them. The issue with that is the install was on a truck without ABS an mine has it... Will that cause issues and if so are they livable issues (I.e. I don't want my ABS to go out and cause me to slam into a bus full of nuns or something). Anybody got any experience with this on an ABS equipped
  2. Feb 11, 2015 at 8:53 PM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    I got the same size tires and abs, no problems. I just put a different speedo gear in. Use this equation to figure out what size you need: Old wheel diameter x old Speedo gear teeth, divide by new wheel diameter = teeth on new gear (each tooth accounts for about a 3% change).
    Speed sensor gear part numbers:
    AT
    30 tooth 33403-39365 3.4/2.7
    32t 33403-39425
    33t 33403-39415
    MT
    28t 33403-39585
    30t 33403-39365
    31t 33403-39345
    32t 33403-39425
    33t 33403-39415
  3. Feb 11, 2015 at 9:04 PM
    BamaToy1997
    Bill
    Navarre, FL
    It all depends on the vehicle. The ABS system uses the vehicle speed sensors to check for ABS operation, not the sensor in the transmission. So even if you were to correct the speedometer, it wouldn't affect the ABS system.
  4. Feb 11, 2015 at 10:19 PM
    AppMtnTaco
    Nick
    Littleton, Co
    Black 2003 SR5 4X4
    So it may be different from 03 tacoma to 03 tacoma? The Dakota site says that it could interfere with the control algorithms..... I guess I'm asking will it be safe to use it?
  5. Feb 11, 2015 at 10:24 PM
    AppMtnTaco
    Nick
    Littleton, Co
    Black 2003 SR5 4X4
    Is that a dealer part? How do I get to the spedo gear? Does that fix the odometer too? The tire accounts for a 8% increase, will a gear with 3 more teeth (to get me to 9%, making up for the 8% increase) fit the stock location?
  6. Feb 12, 2015 at 2:04 PM
    Jiveydude
    Micah
    OH
    04Taco
    Yes, those are dealer part numbers. It is on the right rear of the transfer case, one bolt and an o-ring. Odometer is fixed too. I think I went two less teeth if I remember right (less teeth for bigger tires) I also had a different tooth count to start with (stock 4.30 gears). I'll see if I can find the article that explained it to me and post it up for you.
  7. Feb 12, 2015 at 5:01 PM
    AppMtnTaco
    Nick
    Littleton, Co
    Black 2003 SR5 4X4
    So with my new 33s I would have to multiply the old tire 31 inches by (say I pull that gear and its a 28T). 31x28 and divide by 33?
  8. Feb 12, 2015 at 5:16 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
  9. Feb 12, 2015 at 5:28 PM
    043RZ
    043RZ Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Mines an 04 with abs and i have had no problems with it interfering and abs still works. I think all manufactures have to put that disclaimer on there product, beings we live in a sue happy world they don't want to be held accountable for someone hooking this up wrong. Also the DD unit can be used in more ways then just Speedo recalibration.
  10. Feb 12, 2015 at 5:43 PM
    Jiveydude
    Micah
    OH
    04Taco
    Yes, more than likely the one you have is a 30T so the 28T would work.
    Also, here is the page that helped me understand the gearing a little better (sorry it's for jeeps).
  11. Feb 12, 2015 at 6:45 PM
    BamaToy1997
    Bill
    Navarre, FL
    It can be. For instance speedometer signal input is different for a manual truck than it is with an automatic. I keep getting them mixed up, but on one model the speedometer data is actually taken from the wheel speed sensors, not the transmission speedometer sensor. (On that vehicle the speedometer sensor on the transmission/transfer case is only used for transmission diagnostics) While the other one does use the speedometer sensor for the speedometer reading.
  12. Feb 13, 2015 at 1:43 PM
    AppMtnTaco
    Nick
    Littleton, Co
    Black 2003 SR5 4X4
    Just pulled the gear its a 30 tooth, I counted 30 teeth and it had 30 stamped on it. What's my next move? Just order the 28, pop it in and tada!!!??
  13. Feb 13, 2015 at 1:53 PM
    Jiveydude
    Micah
    OH
    04Taco
    Yep, easy peasy.
  14. Feb 13, 2015 at 5:03 PM
    AppMtnTaco
    Nick
    Littleton, Co
    Black 2003 SR5 4X4
    Thanks man I will remember your assistance and advice when the time comes for me to take over!
  15. Feb 13, 2015 at 5:33 PM
    Jiveydude
    Micah
    OH
    04Taco
    Haha. Yes, keep me off the kill list :cheers:
  16. Feb 13, 2015 at 6:01 PM
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
    So after following along here , for the most part .... I mean I haven't studied, and analyzed all the technical data .... I'm Wondering what the best way to go here is ?
    I have 33's and 4:56 gears.
    I'm way out ( so I believe) on the speed-O-Meter , and Odometer.
    A friend explained gears to me in the best explanation I heard so far.
    With stock 3:73 your drive shaft spins 3:73 times for every 1 rotation of the wheel. With 4:56 gears , the drive shaft spins 4:56 times for every wheel rotation. Makes perfect sense to me.
    Anyway... I checked out the Dakota Digital unit and like it.
    I'm considering buying it , but would like to hear more feedback ... That makes sence before I do.
    Currently I have an Ultra-Gauge , but I'm not so happy with it. It's nice and works for what it is , but it doesn't correct the odometer , nor the speedometer.
  17. Feb 14, 2015 at 11:01 AM
    AppMtnTaco
    Nick
    Littleton, Co
    Black 2003 SR5 4X4
    I think you can get yours recalibrated at the dealership if it's an 05+. I was only considering the Dakota unit because mine is and older analog speedo. I think your newer is digital. I would holla at the dealership.
  18. Feb 14, 2015 at 2:11 PM
    AppMtnTaco
    Nick
    Littleton, Co
    Black 2003 SR5 4X4
    Or have you alread went that route?
  19. Feb 14, 2015 at 2:52 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    my experience speedo recalibration processor.
  20. Feb 14, 2015 at 3:42 PM
    Explor
    FUN
    I have asked the dealer where I bought the truck if a re-program was available , and was told Nope ... Not possible .
    I cannot believe that it's impossible . I think it's more of a corporate policy , that boils down to money $ , warranty , liability , which after boiling those ingredients , all that's left is Money .... Not to be made by Toyota.
    Just my thinking.
