Damage Advice NEEDED!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Willdixon92, Dec 9, 2017.
  1. Dec 9, 2017 at 10:26 AM
    Willdixon92
    Willdixon92 [OP] New Member
    2017 Taco TRD Sport
    3 Inch Spacer up front, Add a leaf in the rear, Baja MTZ P3s (33inch) XD820 Grenades 17"
    Had a bit an issue this morning that ended up not being nearly as bad as it should have been, a guy driving a small old Toyota Carolla nailed me after blowing a red, (T-bone) in my '17 taco, when i got out, my truck was fine because he directly hit my wheel, I have XD Grenade's stanced out so no damage was done to the body of my truck (luckily) but I did a full 180 spin and my his car is likely written off.
    I am wondering unseeable what damage might have occurred, frame looks good so far, thinking damage to the axle and diff may be possible what are your thoughts.
    Facts:
    Rear, Driver side wheel impacted around 40km/hr
    Spun 180 degrees
    No bed still looks lined up on accurately to the cab
    Earliest I can get it in to my mech is Tuesday so let me know what you all think,
    Thanks,
    W
  2. Dec 9, 2017 at 10:33 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Go over that thing with a fine toothed comb. "There doesn't appear to be damage" just won't cut it with newer vehicles. They're made to "squish" on impact.
    G.
    InfernoTonka likes this.
  3. Dec 9, 2017 at 10:35 AM
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    Pictures?
    Plain Jane Taco likes this.
  4. Dec 9, 2017 at 10:39 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Have someone with machines (not by eye) check the frame. Is it still square?
  5. Dec 9, 2017 at 10:39 AM
    Willdixon92
    2017 Taco TRD Sport
    Yeah, I will have my mech check the axel run out and have a peak at the diff and the frame.
    Thanks man, hoping for the best
  6. Dec 9, 2017 at 11:53 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Good luck, definitely make sure they do a detailed inspection of your truck.
  7. Dec 9, 2017 at 11:57 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Would definitely want to take some measurements via a 4 wheel alignment rack. After checking if its in spec, check to see the distance the wheel is in relation to fenders top, left and right and also offset from the body. As a former BMW tech in the northeast, we had a lot of pothole impacts that caused suspension damage and witha simple “1,2,3 or 4” finger measurement and cross referencing with the other side could tell you right away if there’s something bent.
    shakerhood likes this.
  8. Dec 9, 2017 at 12:00 PM
    eon_blue
    Azusa, CA
    Umm, if he hit you hard enough to make your truck do a 180 and total his car, it would be a miracle if no damage occurred to your truck (even if you don't see it). At the very least I'd bet your front suspension on that side got compromised somehow (ball joints, tie rod, cv axle, lower and/or upper control arm, steering, etc.). Not to mention possibly a tweaked frame. I'd get that checked over real carefully.
    over60, HutchJ and shakerhood like this.
  9. Dec 9, 2017 at 12:04 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Double check the axle tube for cracks where it is welded to the flange for the brakes. If it is cracked it will be wet with oil. It could also be bent without being cracked. Just my .02
  10. Dec 9, 2017 at 12:21 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Something absorbed the force. Wouldn't drive it fast or at all til looked at. Interesting to see if any vibes at 60 after inspection.
  11. Dec 9, 2017 at 12:25 PM
    weefek
    weefek Well-Known Member
    J
    2017 OR ACLB
    I'd put money on the frame is bent. It can be hard to spot
  12. Dec 9, 2017 at 12:30 PM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
  13. Dec 9, 2017 at 12:32 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Insurance will replace items that may have taken the force if you push them. I had a car rear end one of my motorbikes, enough that when i got off the bike, it stood upright as the bumper of the car had caved in around the rear wheel. no visable damage to the bike except tire, but I made the insurance replace the wheel, tire, wheel bearings and swingarm bearings.
    From what you describe, I would never trust that wheel again even if everything else comes up undamaged.
  14. Dec 9, 2017 at 12:34 PM
    KrypticZer0
    KrypticZer0 Well-Known Member
    Western Idaho
    2007 TRD Sport LB 4x4
    :worthless:
    X2
    Braves95[QUOTED] likes this.
  15. Dec 9, 2017 at 1:02 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Good chance your whole drivetrain is off alignment, something similar happened to me in an f250 back in 1980 and the rear leaf spring actually sheared right off and it didn’t drop until the next day...have it checked thoroughly
