Damage from deer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jes2618, Mar 26, 2013.
  1. Mar 27, 2013 at 4:16 AM
    Hot2na
    Hot2na Well-Known Member
    For all you deer people : Do those deer horns work that they sell in walmart ?????
  2. Mar 27, 2013 at 5:14 AM
    DunhamAll
    DunhamAll Well-Known Member
    Jordan
    Baltimore, MD
    '12 Access cab, MT, TRD OR
    Rear diff. breather, BHLM, Wet Okoles.
    Sorry, you're so anti hunting; but I think you're a little misunderstood by all of it.
    Those "rack hungry hunters" also serve a purpose in that the male runs around getting all those does pregnant. Removing an adult male from the population early in the rut can potentially stop 7+ new offspring next season. On the other hand killing 1 doe only takes 1 potential new offspring out of the mix. Remove the mature males and you control population better. But yes, to an extent, you are correct, over populated areas need the doe population thinned as well however there are many areas in this country that Doe hunting is illegal. This concept and others supporting laws surrounding the restriction of Doe hunts. Also, I am not, nor do I support hunting solely for trophy, but getting a true trophy buck is a harder hunt as that guy is a survivor. For the most part its about the hunt, not the trophy to get a 8 point + buck.
    Back on topic:
    Hey OP. Do you know what color code was used for the black on your valence and grill? Did the shop anticipate any issues with the paint sticking to those plastic areas? That looks really slick and I want to get mine done now.
  3. Mar 27, 2013 at 6:01 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Pm'd ya.
