Damage while 4 wheeling
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dj318, Apr 28, 2013.
  1. Apr 28, 2013 at 7:20 PM
    Dj318
    Dj318 [OP] Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    What all have you worn out? Just wondering lol
  2. Apr 28, 2013 at 7:32 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    check my build thread. you will actually see what all ive worn out.
  3. Apr 28, 2013 at 8:06 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Hey you had em swapped quick and it was HOT. I was impressed!
  4. Apr 28, 2013 at 8:07 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I've replaced pretty much every every suspension component at least once, including multiple CVs and LCA bushings. I have busted two rear shocks on the trail before and of course had my share of blown tires. Considering how I've wheeled this thing it's amazing things haven't been 10 times worse.
    I can think of two times something happened that just stopped me in my tracks. First was after I had the truck a year or so and the trucked died and black smoke came from under the hood. Well my battery had moved and snapped the ground wire... which led the the other engine ground wire burning up. An easy trail fix and I immediately created a much stronger custom battery tie down support.
    The other time I was on a steep, twisted incline and the truck died. After fiddlefucking around for 30 minutes I realized my exhaust pipe had been bent up quite a bit (from a previous trip) and the O2 sensor was making contact with the metal above it when the truck was articulated a certain way, blowing a fuse. I just borrow a fuse from something else to get home. For a little while I put some material between the O2 and metal above it and carried spare fuses. Eventually I bent the pipe back down a bit and haven't had a problem since.
  5. Apr 28, 2013 at 8:15 PM
    Madjik_Man
    Colorado Front Range
    Nothing but one big shot to my passenger rocker panel.
    Still rocking the same suspension that it rolled off the factory floor with... 165,000 miles later.
  6. Apr 28, 2013 at 8:18 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Iyts the rear axle not being square. Called dog tailing.
  7. Apr 28, 2013 at 8:20 PM
    Madjik_Man
    The rear looks off but his front passenger wheel/tire looks like it's about to snap off.
  8. Apr 29, 2013 at 10:07 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    All the posts about scratches and body damage is not answering the original question. None of that is actual breakage or mechanical failure. I think the OP is asking what are the most likely things to break and require on-trail repairs to get moving again.
    I haven't personally broken anything yet, but the most common things to break are:
    1) CV's
    2) driveshafts (usually from contact with rocks, not actual Ujoint failure)
    3) lower ball joints
    4) Tie rods
  9. Apr 29, 2013 at 10:11 AM
    KevbekTacoma
    KevbekTacoma To Be Continued...........
    Kev
    SoCal
    '12, 4X4, DCSB, MT
    KING 2.5 RR (Front/Rear), TC UCA, DAKARS, MTR W/ KEVLAR, SCS SR8, TUBE BUMPERS, SLIDERS, MF CAT BACK, LIGHTS.
    I flooded my front end. Needed a new alternator, new starter, new airbag sensors, and replaced flooded fuses. 100% my fault it happened though.
  10. Apr 29, 2013 at 10:29 AM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    I would generally agree, especially with the first two. If you're not dumb on the trail, things normally don't just spontaneously fail. Something like a ball joint or tie rod end shouldn't just break unless you've completely failed to detect a "failing" part beforehand (pay attention to the vehicle) or you've accidentally hit a small boulder at 20mph or something. And in that case of negligence, nearly anything can happen to most any part.
    Most things you can kinda tell when they're going bad. The only thing I've ever worried about in the back of my head when in the middle of crap-road and nowhere, 20 miles from the nearest sign of civilization, was a fuel pump going out because that is something that can just stop you dead in the water without warning... which is why I replaced mine at 200,000 miles "just in case."
    I am not one of these paranoids who carry a shit-ton of parts with me wherever I go. Pay attention to the vehicle's needs and stay within reasonable limits... and as a last resort some duct tape, bailing wire, and ingenuity should get you back to home/shop ;)
  11. Apr 29, 2013 at 5:52 PM
    Drewski
    Drewski Well-Known Member
    People's Republic of Chicago
    '99 Prerunner SR5 Xtracab 4 cyl auto
  12. Apr 30, 2013 at 7:28 AM
    Box Rocket
    Adam
    Syracuse, Utah
    Doesn't change the fact that tie-rods and ball joints are common failures. Yes they typically fail because of neglect and can be avoided but the fact of the matter is many people don't stay on top of the maintenance of those items and they are on the list for failure prone items.
  13. Apr 30, 2013 at 8:05 AM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    My comment was food for thought for the OP and not meant to change any of your "facts." But I'd still disagree that tie-rods and ball joints are common failures... for a 4x4 Tacoma. Of all the parts on a truck those are some of the most likely to fail, but it is definitely not a common occurrence for those to break on a trail.
  14. Apr 30, 2013 at 8:08 AM
    sk8rjess
    sk8rjess IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
  15. Apr 30, 2013 at 9:15 AM
    #35
    Box Rocket
    Adam
    Syracuse, Utah
    "common" is relative. I don't mean to say it happens all the time, but other than driveshafts, and CV's, what else do you typically hear about as mechanical failures? So while it may not be "common" as in "often" but there aren't many other things that go wrong on a more frequent basis. That's part of what makes the trucks so cool. Pretty darn reliable if you stay on top of maintenance.
  16. Apr 30, 2013 at 2:29 PM
    #36
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    When you say matnience how in depth do you mean? And how often do you do it?
    Sorry I'm sorta new to all this :/
  17. Apr 30, 2013 at 3:23 PM
    #37
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    100% agree.
    DJ, for me it means knowing your vehicle and what the parts are, what those parts do, and how they wear. Consider the type of driving they have been through and how old they are. Use your senses... visually inspect stuff periodically, listen for strange noises, and learn the feel of things to tell if something is "different." There's no magic formula, it's a combination of common sense and experience. Like I mentioned, most things don't just spontaneously fail, there are indicators. Everyone's different, but I try to stay proactive and take care of things before they get serious. I can't afford to take chances for the types of wheeling I do (very remote, sometime alone) and I like the piece of mind.
    If you want more info on maintenance, look up the 30k, 60k, 90k recommendations and other user-generated recommendations on the TW forum.
  18. Apr 30, 2013 at 3:36 PM
    #38
    taylorf16
    taylorf16 Well-Known Member
    Noah
    Salt Lake City, UT
    02 Double Cab 5-speed SAS
    Solid Axle 5-speed Chevy 63s 3 in lift front leafs Grey wire mod
    Got my 2nd gen stuck in the snow... got pissed bounced it off redline in 2nd gear for about 2 minutes, slid sideways into a tree, dented the bed and broke the tail light..
    My 1st gen double cab hasn't really beed offroad too bad.. Probably more that I don't know as far as hitting things.. I rallied the piss out of it through mud and rocks, in attempts to soften the front leafs... ended up breaking a weld.. so the trucks can take quite a bit offroad.. I think the most damage will be weight capacity overload, and stupid little adjustments and maintenance items.
  19. Apr 30, 2013 at 4:51 PM
    #39
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    Thanks Chris, the only problem is my truck has a body lift, shot shocks and leaf spring, and a loud flow master exhaust making it kinda hard to hear/feel much, she has 163000 miles on her and the previous owner I know didn't take care of it, wish I had known this previous to purchase.. Got a good deal though and dad jumped on it for my graduation present.
    The previous owner blew a alternator fuse, couldn't get the fuse box apart I guess so he tore the plastic off the fuse and wrapped regular wire around the two open blades! Talk about a fire hazard?!?
  20. Apr 30, 2013 at 4:58 PM
    #40
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    2 front diffs
    1 rear diff (and bent the axle when it broke, its now leaking)
    Gas tank gauge doesnt work, and tank is about half the size it used to be.
    But I would say the truck is very durable, I was driving like a complete jackass when I broke the diffs.
