Damage your truck by mudding
Discussion in 'Off-Roading & Trails' started by acmair, Jun 18, 2010.
  1. Jun 18, 2010 at 12:13 PM
    acmair
    acmair [OP] Well-Known Member
    Andrew
    '10 BSP PreRunner Dbl Cab Short Bed SR5
    Is it possible to damage your truck by mudding? As in, the internal components, or anything like that, or does it just get dirty?
    Also, does leaving the dirt cause any damage?
    Sorry for the noob question
  2. Jun 18, 2010 at 12:14 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
  3. Jun 18, 2010 at 12:17 PM
    Brunes
    Brunes abides.
    Rotorhead
    Depending on the type of mud- It can leak back down thru vents and breather valves. It can also expose problems (like frayed wires, loose connections, etc) faster as water/mud leaks into them.
    As far as mud damaging the paint- Yup. Depends on the type of mud, how well you wax/care for your truck before hand, and lots of other variables.
  4. Jun 18, 2010 at 12:19 PM
    Mondwa
    Mondwa Well-Known Member
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    remote start, Allpro bumper, Slimchubby HID, MetalMiller custom Emblem
    yes if water gets to high you can hydro lock your engine,
    also i am sure if you leave mud on any of bushings and steering componets could dry rot
  5. Jun 18, 2010 at 12:23 PM
    fsbrain03
    fsbrain03 Well-Known Member
    I've got some jacked up pulley's right now
  6. Jun 18, 2010 at 12:27 PM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    I always say no
    to mud that is. Unless its a few small puddles or so. Mud pits are not my cup of tea. Trail rides with obstacles like mud "puddles" rocks and tree are a normal ride around here.
  7. Jun 18, 2010 at 2:05 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    it will eat seals, bearings, and alternators very quickly
  8. Jun 18, 2010 at 2:14 PM
    jrws6
    jrws6 Well-Known Member
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    Possible, Yes
    Likely, Yes
    Getting it "dirty" is the least damaging thing it does to your truck.
    Worth it?
    Thats up to you.
  9. Aug 22, 2013 at 10:27 PM
    Jackal1392
    Jackal1392 Member
    Taylor
    Florida
    07 Base Tacoma, 2.7l
    I fried my alternator when mudding once.
  10. Aug 27, 2013 at 7:29 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    33's,armor,crawler,dents, ect
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    They say a picture is worth 1000 words. Mud can fuck shit up if you bury yourself up to your frame religiously. If play in the mud once and awhile and clean the undercarriage especially your output seals/pulleys/bearings mud will have minimal time to tear apart everything...
    This is the outside of the ADD shaft on my old front diff. It had about a half inch of play.
    This is the inside end of that long connector shaft housing. Mud worked it way down and smoked this as well.
    Why was my frame 2x to heavy;)
  11. Aug 27, 2013 at 7:38 PM
    BigBoi
    BigBoi Well-Known Member
    Jacob
    St George, SC
    '00 SR5 V6 5spd ext. cab
    Just don't be an idiot doing it. Cut doughnuts in a muddy field if you're scared.
  12. Aug 27, 2013 at 7:40 PM
    169.254.255.201 Well-Known Member
    Interwebs
    :confused::confused: what is that, and what is inside it? (I know this is a mudding thread but that doesn't look like mud at all.
  13. Aug 27, 2013 at 7:41 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    Looks like his frame filled with mud.
  14. Aug 27, 2013 at 7:44 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Compact mud the funny texture is from the torch getting it warm.
  15. Aug 27, 2013 at 7:45 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Nougat. Like a 3 Musketeers bar. :)
    Looks to me like accumulated impacted dirt.
  16. Aug 27, 2013 at 7:46 PM
    TailDrag
    TailDrag Well-Known Member
    Wut.
  17. Aug 27, 2013 at 8:06 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    ^the way you can tell it was in the frame before the cut the area where the torch chopped it apart is clean. Had it impacted the ground enough to fill the frame it would be dirty
  18. Sep 11, 2013 at 6:00 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    Mud caused me to have to replace one of my idler pulleys. Apparently they aren't sealed so muddy water can get in em and make them whine... and fail.
    Some types, like super fine silt can get all up in gaskets and such. I tend to avoid super silty areas.
    When I do get it muddy, I try to pressure wash it within a week or so. Paint, undercarriage, engine bay, everything but the interior.
    Mudding can cause you to hit unseen/buried obsticals... or slide into them. Depending on where you are at....
    As with any off roading, if you are going to do it, be prepared to break shit eventually!
  19. Sep 11, 2013 at 10:03 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    I've read that pressure washing can backfire on you because it pushes dirt deep down into seals where it wouldn't have gone.
  20. Sep 11, 2013 at 11:49 PM
    chipnoreo
    Anna
    Alaska
    Ram Eco Diesel
    Probably does have some adverse affects. Gotta get the mud off somehow though and when a garden hose isnt cutting its.
