Damaged spare tire
Discussion in 'Wheels & Tires' started by nermalgod, Jan 29, 2009.
  1. Jan 29, 2009 at 11:27 AM
    nermalgod
    nermalgod [OP] Well-Known Member
    Bend, OR
    Offroad boat hauler
    Not going to brag.
    I have had a slow leak in one of my tires for a couple weeks. It's been slow enough that I could hit it with a few pounds of air every couple of days and it would be fine. Today I was going to deal with it. I have a local shop that will patch tires super cheap if they are off the vehicle, so I was going to put on my spare. After dropping it from its stowed position, I discovered that the sidewalls have damage from where the tire touches the frame. I would guess about 3/16" or an 1/4" of material is gone. I put the spare back and filled my leaky tire with more air. A slow leak is better than an explosive blowout.
    Anyone else have issues with spare be damaged? I've had this truck for about 10 months now and am one month out of warranty. Any chance I can get the dealer to replace the tire? It's the first time I dropped the spare since buying the truck and it was quite a surprise.
  2. Jan 29, 2009 at 11:45 AM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    yes, go back to the dealer and let them now. Tell them that you desperately needed the spare tire and it appeared to be damaged. let them feel your pain.
  3. Jan 29, 2009 at 11:47 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Are you sure the material is gone, look close. I just dropped mine (getting rid of it) and it has those marks. BUT it is where the metal pushed against the rubber. It will come (pop) back out after time.
  4. Jan 25, 2011 at 7:56 PM
    kjtaco
    kjtaco New Member
    Alabama
    08 Prerunner TRD 4.0L
    Just dropped the spare on my 08 Tacoma TRD which has less than 10K miles on it. I also immeidately thought it was damaged as there is 1/8 inch deep dips which look like abrasions on 8 contact spots on the side wall. Maybe it is just pushed in and will pop back out...we'll see. If not its sill under warranty and we'll see what the dealership will do.
