damaged starter
Discussion in 'Technical Chat' started by memery, Apr 21, 2009.
  1. Apr 21, 2009 at 10:38 AM
    memery
    memery [OP] Member
    Birmingham, Al
    4wd w/3" lift
    Turned the key on my 97 2wd Tacoma yesterday and the 8yr old aftermarket starter made a loud grinding sound and was barely turning the motor over. Some of the teeth were damaged so I was able to get a warranty replacement. Got the new one last night and got the same results when i tryed to crank it. I'm guessing the flywheel is damaged. I've done a clutch before (not this truck, it has the original w/180k) but not a flywheel. Any words of advice?
  2. Apr 21, 2009 at 10:58 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    If you've done the clutch then the flywheel should be a cinch. I replaced my whole flywheel because Toyota wanted $145 just for the teeth versus the one I bought from Napa for $75, which included the whole flywheel and teeth. If you just replace the teeth, they unbolt from the flywheel.
  3. Apr 21, 2009 at 2:30 PM
    memery
    memery [OP] Member
    Birmingham, Al
    4wd w/3" lift
    Thanks much, i'll let you know how it goes.
