Damaged wires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Drake0730, Jan 5, 2023.
  1. Jan 5, 2023 at 10:47 PM
    Drake0730
    Drake0730 [OP] Sir Drake Edwards
    Edward
    2020 SR5 Tacoma
    Hey everyone I'm Drake and new on here, and I definitely need some help and or some advice. So I'll do my best to mak
    it quick. So long story short I had this genius idea. By the way I have a 2020 SR5 Tacoma I've been planning on installing a new sound system. So from everything I looked into said for me to basically take a wire coat hanger and put it through the Boot on driver side to pull the wires through. Well I made a poor decision and decided to take the end of the hangar and heated one end thinking it would go through a lot easier and it would be much faster. Well It went like I hoped except I pushed to hard it went straight through and straight into the wiring harness damaging a bunch of wires. And now the truck won't start. I turn over the Key and the Stereo comes on but nothing else the gas gauge, speedometer, etc everything is out. What I noticed was the Ignition isn't reading the key has been turned over because I'm sure everyone is aware when you turn off the ignition and Leave the key in the ignition and open the driver's door it beeps. Well it's doing that when the key is turned on as well. I checked all the fuses, I believe I Fixed any of the wires that we're damaged and still nothing . What did I do and how do I fix it. please help.
  2. Jan 5, 2023 at 10:48 PM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    Have it towed to the dealer, contact your insurance and file a claim. Not going to harp on you, but what were you thinking lol.
  3. Jan 5, 2023 at 10:51 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    No input on fixing the damage, but I would suggest using a Plastic Zip Tie the next time you try to run wires, its rigid enough and will not damage any wires.
  4. Jan 5, 2023 at 10:57 PM
    Drake0730
    Edward
    2020 SR5 Tacoma
    Ya, definitely one of my Best Choices. Lol fml.
  5. Jan 5, 2023 at 11:02 PM
    Martian__
    Martian__ Well-Known Member
    Southern California
    Unless you’re well versed in wiring repairs. Leave it to the professionals at this point. Some of those wires can only have so much resistance and improper wiring repairs will cause even more problems. At this point Toyota will only replace the harness to avoid liabilities. You can either pay out of pocket for the repair or go through your insurance. Replacing that harness will require a lot of labor.
  6. Jan 5, 2023 at 11:09 PM
    Drake0730
    Edward
    2020 SR5 Tacoma
    Lol Ya, problem is I hate just letting it go and have someone else fix My F up. I just can't. I feel I'll figure it out at some point now the cost isn't what I'm worried about. It's the value of what I've gained by it. because now I've learned from my experiences and mistakes and gained more knowledge..
  7. Jan 5, 2023 at 11:13 PM
    Drake0730
    Edward
    2020 SR5 Tacoma
    Thanks everyone, Look forward to Learning much more from TW. But on that note I'm taking my ass to bed . Good night fellas
  8. Jan 5, 2023 at 11:29 PM
    erok81
    erok81 Well-Known Member
    Imposter
    If this was me I’d probably try and fix it myself. It’s not like you’ve cut a bunch of wires. All you did it melt off the insulation on a few and now they are shorting together.
    Other than trying to start it have you looked the damage? Might be a bit difficult to see but I’d try that first. Otherwise this is going be in the 1000’s from the dealer. :spending:
    Drake0730[OP] likes this.
  9. Jan 6, 2023 at 5:27 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Probably blew out BCM, and more. So many electronics that could of fried with shorting wires. Take it in, you we never figure out what is all wrong.
    SR-71A likes this.
  10. Jan 6, 2023 at 5:47 AM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    I didn’t read any of your post…
  11. Jan 6, 2023 at 4:51 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip: Sorry this has to be your first post.
    A trip to the dealer, new wiring harness and an insurance claim is probably the best way to go. These trucks have incredibly sensitive electrical systems, it is easy to frost expensive parts.
    Props to you for owning it on your first post, so many folks open with a bunch of questions and many posts later say "well I did do...." :smack:
    Chew likes this.
  12. Jan 6, 2023 at 5:14 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    For some reason everyone goes in where the wires run in. When I ran my power wire I removed the blank rubber grommet behind the master cylinder . Once you remove it it’s like a nipple . Then you can drill out the nipple and run the wire through it and this way your not near the harness
    JPTx, Chew and na8rboy like this.
  13. Jan 6, 2023 at 5:14 PM
    mhornco
    mhornco Well-Known Member
    I guess if it was me. Of course I have absolutely without a doubt ever done anything stupid to my truck. I would see what you melted. Separate all the wires and tape over the melted pieces. Especially if you did not break a wire. If you fried something it is already fried. I am a f it up myself fix it myself type. If you’re going for insurance to cover it why not try something first. Especially if you can get to the harness and see what you did
    erok81 likes this.
  14. Jan 6, 2023 at 5:19 PM
    eurowner
    eurowner Duke Sky
    Scoty
  15. Jan 6, 2023 at 5:43 PM
    Drake0730
    Edward
    2020 SR5 Tacoma
    Right on thanks everyone this is my first time on any forums this is pretty badass being able to chat with some fellas (& ladies if there is any) brain storming some ideas giving advice. So I got under the dash found the wires that were damaged. There was 2 wires that seemed to have to have the most damage a purple and a white these 2 wires were braided or twisted together The insulation was melted now idk if that was because of them coming in to contact or my brilliant idea of using a hot rod to go through everything. Does anyone know what those wires are? I separated them and taped them. There was a blue 1 that I nicked a red 1 and a green 1 those 3 are thicker gauge wire but they didn't seem to have came into contact with anything else. Someone said the AM1 fuse my truck doesn't have an AM1 inside the cab fuse panel the AM1 spot is crossed out and there is a AM2 under the hood which is a square 30 amp fuse but it seems to be fine. I Read in another forums a guy kinda did the same thing I did but installing a light bar. Am I able to put pics and links in my posts. Sorry computers Internet all this technology. I'm a freaking cave man what ever happened to just buying a damn Chilton's Manual
    eurowner and erok81 like this.
  16. Jan 6, 2023 at 5:46 PM
    erok81
    Imposter
    If you click the butting labeled Upload a File that will allow you to upload your pic. Then just post like normal and it’ll show up.
  17. Jan 6, 2023 at 6:08 PM
    Drake0730
    Edward
    2020 SR5 Tacoma
    Thanks again anyone have any idea about the wires, I have trouble reading schematics that will take me forever to read. I don't mind learning but I don't exactly have the time at the moment
