dammit, drained some transmission fluid what now
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fiftyxp, Mar 24, 2019.
  1. Mar 24, 2019 at 7:14 AM
    fiftyxp
    fiftyxp [OP] Well-Known Member
    2017 trd offroad 4x4
    was doing an oil change and wasnt paying attention.
    drained for a couple of seconds before i plugged it back up asap, after being in shock that it was red..
    isnt marking low or anything.
    no harm no foul?
  2. Mar 24, 2019 at 7:16 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Drained for just a few seconds, dont worry about it.
  3. Mar 24, 2019 at 7:16 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Here is Toyota's automatic trans fluid adjustment procedure. It is easier than it looks in the document. It's good info to have.
  4. Mar 24, 2019 at 7:17 AM
    fiftyxp
    Yea not long saw red on my gloves and thought about it and was like this isn't right fuckkkkk go back
  5. Mar 24, 2019 at 8:05 AM
    fiftyxp
    Thanks.
    Hobbs[QUOTED] likes this.
  6. Mar 24, 2019 at 8:08 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    There has to be something we can do as a community to help prevent this from happening. Not bashing on you OP, just saying its too common of a mistake that could be fatal to the truck.
    JNG and Modesto Tacoma like this.
  7. Mar 24, 2019 at 8:27 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    If you Don't know what your doing don't do it. Not a shot at anyone.
    cwdog, Skydvrr, BSFord and 3 others like this.
  8. Mar 24, 2019 at 8:28 AM
    fiftyxp
    Well my son was "helping". So I was worried about what he was doing more than what I was. Luckily didnt drain it all out as I have read it has happened to others before.
    Saw red was like wtf... put the bolt back in.
    El Duderino likes this.
  9. Mar 24, 2019 at 8:30 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    When I changed my oil I kept looking at the engine oil pan plug and kept questioning myself because I did not want this happening. Super easy mistake to be made if you’re not paying attention. Good thing you realized your error quickly and corrected it!
    Dishsoap and fiftyxp[OP] like this.
  10. Mar 24, 2019 at 8:32 AM
    fiftyxp
    Checking under yea it's easy. The oil pan is hidden more than the transmission one. The transmission bolt also came out super easy which I thought was strange.
  11. Mar 24, 2019 at 8:33 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Any of the aftermarket skid plates help this lol.
    You can't even get to the transmission drain without removing skids.
    Vs most have a cut out for oil pan
  12. Mar 24, 2019 at 8:36 AM
    Raeburn
    Raeburn Well-Known Member
    2017 ORDCSB
    Did the same thing when I changed mine last Thursday, kept checking to make sure it was in fact the oil pan, and let a little drip on my finger to confirm before draining! The oil drain plug is a little hidden and the trans plug is plain sight so I could see how it could get pulled by mistake.
    I would say it would be okay if only a small amount drained out, but I'd probably do a level check just to be safe.
    fiftyxp[OP] likes this.
  13. Mar 24, 2019 at 8:40 AM
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    I did this as well first time I oil changed. Recognized it immediately and put the plug back in, measured what drained and replaced. Been all good since.
  14. Mar 24, 2019 at 8:45 AM
    fiftyxp
    How much did you replace? I can't imagine I even lost a quart.
  15. Mar 24, 2019 at 8:47 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Use a paint pen or your wifes nail polish and mark the plugs. Helps you later and helps the jiffy lube guy not fuck it up.
  16. Mar 24, 2019 at 8:55 AM
    Hobbs
    Yep…
    Education would be a great start!
  17. Mar 24, 2019 at 8:56 AM
    fiftyxp
    I kinda like to just take shots in the dark to be honest
  18. Mar 24, 2019 at 9:08 AM
    Hobbs
    Yep…
    It's your truck! Have at it! :thumbsup:
  19. Mar 24, 2019 at 9:10 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You’re gonna have to add more fluid and do the proper fluid level check.
    OnHartung'sRoad likes this.
  20. Mar 24, 2019 at 9:15 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Jiffy Lube = not even once
