Damn. Check engine light on.
Discussion in '1st Gen. Tacomas (1995-2004)' started by XwesleysnipesX, Nov 3, 2011.
  1. Nov 3, 2011 at 7:55 AM
    XwesleysnipesX
    XwesleysnipesX [OP] Well-Known Member
    Eric
    Batesville, Indiana
    1996 2.4L 2x4 (sold). 2002 2.7L sr5 4x4 (sold)
    Just bought the truck a week ago. And the stinking check engine light came on this morning. Ill scan it when I get home tonight. Runs fine. So who knows. Just venting really. :censored:
  2. Nov 3, 2011 at 9:14 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    probably nothing to be worried about if the truck runs fine.
  3. Nov 3, 2011 at 9:27 AM
    XwesleysnipesX
    Eric
    Batesville, Indiana
    Yeah. But im super anal with my vehicles. So i will have to fix it. oh well. Its just money right! Cant take it with you when you die. :D
  4. Nov 3, 2011 at 9:30 AM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    My money its on 02 sensor!
  5. Nov 3, 2011 at 9:44 AM
    99PreRunner.
    99PreRunner. ^ I no longer have a Tacoma
    Alex
    Mobile, AL
    2008 GMC 3500 Duramax 4x4 - CCLB
    Disconnect the positive on your battery for 30 seconds. Then connect it back and see if your light goes off and stays off.
  6. Nov 3, 2011 at 9:57 AM
    XwesleysnipesX
    Eric
    Batesville, Indiana
    I thought about that. But I have a scanner at the house. Once I get off work Ill scan it then clear it. Thanks though.
  7. Nov 3, 2011 at 12:55 PM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    I bought my Tacoma a few months ago and right after I got it home the CEL came on! I knew then the dude had reset it before I came to look at it. At least I know now it has a new o2 sensor that I installed, and that's its an OEM sensor.
  8. Nov 3, 2011 at 1:01 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Whoever had it before probly reset it before selling to you. Reseting will only prolong the inevitable return of the cel
  9. Nov 3, 2011 at 1:04 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  10. Nov 3, 2011 at 1:07 PM
    XwesleysnipesX
    Eric
    Batesville, Indiana
    That was my first thought. But the day after I bought the truck my work had me go to Chambersburg PA. And that was a 1000mi round trip. I have probably put on 1600mi since i bought it last week. So you think it would have come on then. Oh well. I expected to fix things here and there. It does have 124k on her. No biggie. I just hope its not a cat going out. I had that problem with my 96 taco. And tried to go the cheap route and went aftermarket. Then the light came back on. Went with a oem cat and it never came back on. With the same code anyway. Oh well.
  11. Nov 3, 2011 at 1:09 PM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Cooper Discoverer ATP 285/50, Bilstein 5100's all around, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, Clazzio seat covers, BHLM with removed turn lens, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Check the fuel cap. Open it, close it, and make sure it clicks 2 or 3 times.
  12. Nov 3, 2011 at 1:10 PM
    XwesleysnipesX
    Eric
    Batesville, Indiana
    Will do. Thanks for the input.
  13. Nov 3, 2011 at 1:15 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Sub'd for what it is!
  14. Nov 3, 2011 at 1:22 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    My system too lean code takes about 1-2 weeks to come back on. And that's after 1000+ miles. my 02 sensors would take about a week to come back on..
  15. Nov 3, 2011 at 1:23 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    That is never usually the problem for our 1st gens
  16. Nov 3, 2011 at 2:18 PM
    dand
    dand You can't see me
    Dan
    SE VA
    TRD Tundra DC 4x4 Blue Ribbon M.
    Planning stage
    MAF
  17. Nov 3, 2011 at 6:03 PM
    XwesleysnipesX
    Eric
    Batesville, Indiana
    Well i just got home from work. The code is a PO446.
    My gas cap is tight. My guess is a charcoal canister. Thoughts?
  18. Nov 3, 2011 at 6:24 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    P0446 - Evaporative Emission Control System Vent Control Circuit Malfunction
    What does that mean?
    Evap vent valve has only one purpose. It closes in order to seal the vent so the EVAP system can pressurize and ensure there are no leaks. Evap vent valve is usually supplied Batt. voltage with key on. The ECM's driver controls the ground, and when grounded, activates the valve (closing it). If the ECM detects a short to ground, and open,or a short to battery voltage on the control circuit, P0446 will set. Code also may refer to ECM detecting that EVAP system is unable to achieve or maintain vacuum during test.
    Symptoms
    There will be no obvious symptoms to driver, other than MIL illumination.
    Causes
    A code P0446 could mean one or more of the following has happened:
    Faulty vent valve
    Open, short or excessive resistance on Vent valve control circuit
    Blockage of vent valve
    Bad PCM
    Possible Solutions
    With a P0446 OBD-II trouble code, here are some things to try:
    Replace Vent valve
    Repair open, short, or resistance problem in control circuit
    Repair open, or short, or resistance problem in power circuit
    Replace PCM
  19. Nov 3, 2011 at 6:27 PM
    XwesleysnipesX
    Eric
    Batesville, Indiana
    Thanks for the info.:cheers:
