Damn dealer alignment issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boxxed, Nov 13, 2010.
  1. Nov 13, 2010 at 3:08 PM
    boxxed
    boxxed [OP] Well-Known Member
    Denver, CO
    Off Road
    Leer Cap Kenwood DNX 9140 Boyo back up cam HD Raido Sirius Weather Tech Mats Memphis Audio, Valentine One radar,Tinted windows,Wet Okole's, Bed mat.
    I have an 09 dbl cab and about 4 months ago I had the leafspring tsb done on my truck. Ever since then I seem to have an alignment issue. I have takin it back and couple times to try and fix the fact it pulls to the left.
    Well the last time I went there this what I get.
    BEFORE MEASURMENTS:
    LEFT SIDE RIGHT SIDE
    CAMBER IS .3 .3
    CASTER IS 1.6 1.9
    AND THE TOE IS .23 .00
    After the measurements:
    CAMBER .3 .4
    CASTER 1.6 1.9
    TOE .03 .02
    Ther dealer tells me its now in specs but the truck stills pulls to the left. Its almost like I have to fight it. It does it even if Iam on the right side of the road crown, it slowly start to move to the left.
    Also there is a slight vibration in the wheel and in the gas peddle. It seems to go away if it step on the gas more or slightly turn my wheel. But it still seems wrong.
    I just wish I knew more about the alignment issue because they want me to think it is ok.
    Any thoughts would be great.
  2. Nov 13, 2010 at 3:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    That alignment is in spec. Personally, THe Camber could be closer to 0*, but thats just me.
  3. Nov 13, 2010 at 3:23 PM
    boxxed
    Denver, CO
    Off Road
    On both sides? and would that stop the truck from wanting to go left?
    BTW I will be moving to Colorado pretty soon and will be getting new tires.
  4. Nov 13, 2010 at 3:24 PM
    pinktaco808
    pinktaco808 Hot Steppa
  5. Nov 13, 2010 at 3:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It shouldnt be pulling to one side or the other with those specs. Something else has to be wrong.
  6. Nov 13, 2010 at 3:36 PM
    monte1985
    monte1985 Well-Known Member
    Stan
    Lancaster NY
    09 Tacoma Dbl Cab 4.0 S/C
    Supercharger, Magnaflow Exhaust. Audio System . Gauges TRD CAI
    Have you recently rotated the tires? Some tires will give you a pull to one side or the other . You could try crossing the front tires and if it then pulls right its a tires causing it and you might want to put it in the rear . Also you will have a pull to the side that has the less caster .
  7. Nov 13, 2010 at 3:36 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    for you vibe issue you can try axle shims or a carrier bearing drop
  8. Nov 13, 2010 at 3:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    He's not lifted, so I wouldnt go that route yet.....
    OP....Another thing to consider, being as they did the TSB for the springs, the tech may have not gotten the axel as straight as it should have been.
  9. Nov 13, 2010 at 4:02 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    do you have the reading/# for the rear
  10. Nov 13, 2010 at 5:11 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I've had problems with my steering lately, and part of it was exactly as you describe, only I was getting a pull to the right.
    I took it in for an alignment at a Toyota dealership. No effect. A couple weeks later, I didn't trust Toyota's alignment, so I went to a local tire place. They said it was just barely out of spec, they adjusted it, no effect. I went to a private shop trying to figure out what else it could be. The private shop couldn't find anything wrong, but said they thought my alignment was still out, and recommended a place.
    I took it there. The guy did an alignment the old fashion way, no computers. I stood right there in the shop talking to the guy the whole time. Now the pull is gone. The steering still feels loose to me, but the pull is gone.
  11. Nov 13, 2010 at 5:29 PM
    jivewalker
    jivewalker me gusta pechos firmes
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS
    make sure you don't have a brake dragging, etc.
  12. Nov 13, 2010 at 5:43 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    For me atleast, the dealer always does the best alignment and thats with the lift and two different dealers.
  13. Nov 13, 2010 at 6:10 PM
    boxxed
    Denver, CO
    Off Road
    No I dont. I didnt know to ask.
  14. Nov 13, 2010 at 6:13 PM
    boxxed
    Denver, CO
    Off Road
    I was thinking about that. I know of a good place around here that does it the old fashin way as you describe.
  15. Nov 13, 2010 at 6:14 PM
    boxxed
    Denver, CO
    Off Road
    Ya see thats the bummer for me. I dont know what it exactly entails to replace the springs..
    Correct, I am not lifted...yet....
  16. Nov 13, 2010 at 6:17 PM
    boxxed
    Denver, CO
    Off Road
    I will try that before I take it back. I have rotated but I switched the left front with the left rear. I did notice that the front left tire was more worn on the outer part of the tire.
  17. Nov 13, 2010 at 7:23 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Are your roads flat.. think you said it pulls left. Cars are aligned to pull left due to crowned roads. Get on a flat one and you might feel a left pull if you're alignment was aggressively crowned.
  18. Nov 14, 2010 at 1:14 PM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    Anyone who does an alignment for road crown is a complete moron. How would they ever know how much crown is on a road. Even if they got it to work just right on that one road, every other road the truck would pull.
    As for "old fashioned" alignments, I can only say this. Pyramids were built using nothing but string and levels, and they turned out perfect, so I would say it works great on cars. ;)
    I would check all your tires for even wear, pressure, and possibly get them balanced. Having the rear axle not straight on its own will not cause a pull. It will only cause your truck to "dog track". It looks like the only thing they adjusted was toe. Which funnily enough also will not cause a pull.
  19. Nov 14, 2010 at 4:42 PM
    boxxed
    Denver, CO
    Off Road
    Thanks,
    I figured I would switch the front 2 tires around. Right now the rear left which uesed to be on the front is worn on the outter side.
    See how it drives, if not then one more trip to the dealer. If that fails I'll go with the string and level method..
  20. Nov 14, 2010 at 8:12 PM
    Taco11
    Seattle WA
    Depending on how badly your tires are worn unevenly, you might have to get new tires and THEN get it re aligned to cure the issue. If the tire wear is severe enough it has a rather large effect on the measurements for the alignment.
