Damn trailers
Discussion in 'Towing' started by luke83, Mar 28, 2012.
  1. Mar 28, 2012 at 9:28 PM
    luke83
    luke83 [OP] Member
    07 sr5
    hahaha soooon hahaha
    So I beefed up the rear springs to be 3/4 ton. Simple $300 upgrade. I own a floor cleaning company (I'm polish so go figure). 07 double cab trd off road with the towing package. K&n system along with flow master series 40. I pull a duel axle 7x12 v-nose trailer and I'm getting only 12mpg highway. How can I get this truck to burn 14mpg or more? Also I heard that the towing package has a transmission cooling system. Is that true? I ended up in a ditch almost killing two state cops feet away due to a icy bridge close to Indianapolis. My truck was sliding sideways at 65mph down with a semi right behind me. My original trailer was trashed. So I got this one with the braking system. I feel more comfortable with the trailer packed with all my equipment. I need to figure out how to increase mpg without getting the almighty tundra. If I have to I will. But I have faith in my taco. On the side note, I heard that the new Tacoma looks like garbage. Is it true?
  2. Mar 28, 2012 at 11:38 PM
    1980 Well-Known Member
    The Dust Bowl
    I haul a utility trailer with my Tacoma and get a lot better than 14 mpg but I probably never have more than a half ton of stuff on it at any one time. If you tow anything real then 14 mpg is probably what you are going to get, no matter what you use. My sister has a Ford 250 turbo diesel that tows like a beast but it gets about 14 mpg all of the time. My brother has a Tundra that isn't quite the tower as the 250 but handles his 22 ft boat with no problems; it doesn't get the greatest mileage though -- maybe 18 at best and 14-15 when towing.
  3. Mar 28, 2012 at 11:47 PM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    the tundras window sticker says 10 to 13 mpg,i have a buddy who has one and he said he maxed out at 14 empty.
  4. Mar 29, 2012 at 4:42 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I say congrats on squeaking 13 while dragging that loaded V-Nose.
    I towed an enclosed snowmobile clamshell trailer 5 yrs many miles with a stock 2006 Tacoma V6 DC 4x4 and never saw better than 11.
    It basically is a big box back there, lots of drag not like an open trailer whatsoever.
    Also I did trade for a 2011 tundra and my mileage is very comparable to my tacoma ownership with my towing numbers better fwiw. Much easier to tow.
  5. Mar 29, 2012 at 4:59 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes it has a trans cooler and an oil cooler and no you'll most likely never do better then 12-14 towing a 7X12 loaded trailer. Only thing that will help is slowing down. Nothing does well towing talked to a guy the other day with an Eco Boost 150 he's getting 9 MPG towing.
  6. Mar 29, 2012 at 5:15 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you want better MPG while towing, get a diesel. The Tundra won't do any better with an enclosed trailer in tow. Also, what K&N system do you have, is it just a drop in filter or a 'cold air intake' system? If you have the whole cold air intake, go back to stock with a good drop in filter. That K&N is hurting more than helping.
  7. Mar 29, 2012 at 5:17 AM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    Along with slowing down there are a couple of other things you can do to increase mileage.
    Accelerate slowly. this will increase mileage and also extend the life of the trucks drivetrain. I'm not saying drive like a granny but an even acceleration up to cruising speed will help.
    Have a look in your trailer for anything you can remove to decrease weight. You can probably find some stuff or equipment that you will never use and is just taking up space and adding weight.
  8. Mar 29, 2012 at 5:41 AM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    yea 10-13mpg towing is good.
    before we got 2 98 superduties we used gas trucks for delv. trailers.
    2 chevy 454's and one ford 460. and you could go up fancy gap va. and watch the fuel hand go down.
    same load with the superduty, did not even break a sweat.
    when it comes to towing there is no substitution for for the low end power.
    but you have to balance here also, is it worth the 5-6 thousand dollars for a diesel over standard truck. do you drive so much that it will pay for its self, and a diesel has more expensive up keep.
