Damn you clock spring!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zbouncer, Jul 14, 2011.
  1. Jul 14, 2011 at 7:52 AM
    zbouncer
    zbouncer [OP] Well-Known Member
    SA,TX
    05 PreRunner
    2" Revtek lift 285-75-16 BFG MT
    Here is the deal, just bought my 05 prerunner 2.7 2wd 2weeks ago...and it has the infamous airbag light and the horn does not work. From all of the searching it looks like the clock spring is the problem. Apparently this is a dealer item only? My question to you guys is has anyone fixed their current clock spring? Maybe by soldering some wires,using some bubble-gum, plastidip or something :confused:
  2. Jul 14, 2011 at 8:03 AM
    zbouncer
    SA,TX
    05 PreRunner
    Bump...not even sure what "bump" means but I have seen it on some other threads and people will "bump" back or move up the thread, so "BUMP!" =-P
  3. Jul 14, 2011 at 8:07 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    check ebay, you can probably find one off a x-runner for when people swap out the steering wheels.
  4. Jul 14, 2011 at 8:18 AM
    theredofshaw
    theredofshaw Well-Known Member
    Reno/Sparks, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    you'll fit in well around here...plasti-dip seems to be the answer to everything :D
  5. Jul 14, 2011 at 8:25 AM
    zbouncer
    SA,TX
    05 PreRunner
    Ebay is def option #2, but I really want to fix it myself with some guidance from the experts on TW...and yes I will literally use plastidip on the housing of the clock-spring to protect it from any damage! ;)
  6. Jul 14, 2011 at 8:30 AM
    zbouncer
    SA,TX
    05 PreRunner
    Bump???
  7. Jul 14, 2011 at 8:37 AM
    Recoil
    Recoil Newby
    Indy
    05 Prerunner D-Cab
    It's not a difficult job. Go get a factory service manual or download one. There are aftermarket clock springs. Take your time and you will be fine. I have an airbag light as well and the code I pulled is my clock spring. I plan to do a write up with pics when I change it.
  8. Jul 14, 2011 at 8:38 AM
    07SpeedwaySport
    07SpeedwaySport Senior MoFo'ing Member
    Fairfax, VA
    06 DCSB TRD OR--now silver
    tint.
    check with the dealer. Might still be under warranty. It is a safety issue.
    My uncle came over with similiar issues on his old Dodge Caravan and we found out that it was covered under a recall. With 180k on the odometer, the dealer fixed it free.
  9. Jul 14, 2011 at 8:42 AM
    zbouncer
    SA,TX
    05 PreRunner
    Tried the friendly guy and the assh#le method at ever dealer and it is not covered under warranty :(
    I would love to get a link to an aftermarket one that is very budget friendly :D
    Most electronics can be fixed to some extent...if I dissect this little bastard can you guys be able to see if its just a loose wire, broken trace, etc :confused:
  10. Jul 14, 2011 at 9:07 AM
    zbouncer
    SA,TX
    05 PreRunner
    Bumpity bump bump???
  11. Jul 14, 2011 at 10:05 AM
    zbouncer
    SA,TX
    05 PreRunner
    Didn't find anything using the filters or search function :(
  12. Jul 14, 2011 at 10:08 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    my light has been on for about two years now... probably going to stay that way
  13. Jul 14, 2011 at 10:11 AM
    zbouncer
    SA,TX
    05 PreRunner
    I dont care much about the light as I do the function of the airbag and horn. I need a horn to pass inspection and honk at assh#les that cant drive and an airbag when those assh#les hit me after I honked several times at them! :eek:
  14. Jul 14, 2011 at 12:14 PM
    zbouncer
    SA,TX
    05 PreRunner
    bumper...
  15. Jul 14, 2011 at 12:21 PM
    zbouncer
    SA,TX
    05 PreRunner
    Apparently this is my only choice :eek:, at least I can save some $ by installing it myself :D
  16. Jul 14, 2011 at 12:40 PM
    zbouncer
    SA,TX
    05 PreRunner
    Hopefully I can search a DIY on how to install :cool:
  17. Jul 14, 2011 at 12:46 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    toyotapartscheap.com usually has the best deals on our parts.
  18. Jul 14, 2011 at 1:02 PM
    zbouncer
    SA,TX
    05 PreRunner
  19. Jul 14, 2011 at 1:17 PM
    zbouncer
    SA,TX
    05 PreRunner
    $221.19 is better than dealer price, but still a good chunk of change. I might just go aftermarket with an airhorn system!
    http://www.youtube.com/watch?v=4u7n3rn022k&NR=1
  20. Jul 20, 2011 at 6:10 AM
    no mods
    no mods Well-Known Member
    cincinnati
    Some stickers
    Any luck fixing them or are they junk and require new part?
