Damn you KO2s
Discussion in '3rd Gen. Tacomas (2016+)' started by Dr. Emmett Brown, Jan 11, 2019.
  1. Jan 11, 2019 at 7:36 AM
    Pot_Lickr
    Pot_Lickr Well-Known Member
    2017 Access Cab TRD Off Road
    Look on your tires... The K02's..
    Unless its been scrubbed off, there should be a random blue dot on the tire...
    Put that dot on the punch mark on your wheel...
    If you can't find the punch mark, put the dot closest to the valve stem..
    It is ok if the blue dot is on the inside of the wheel and not right next to the valve stem.. As long as its lined up with the valve stem you'll be good..
    Ask your shop to use the blue dot... Thats what its for..
    medicfung likes this.
  2. Jan 11, 2019 at 8:36 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Greg
    Las Vegas
    2017 Pro/2015 Tacoma
    Lifted
    Lots of warnings about the tires ,yet guys just keep on buying them.
    dre5491 and PrimerTaco like this.
  3. Jan 11, 2019 at 8:41 AM
    Dr. Emmett Brown
    Dr. Emmett Brown [OP] Well-Known Member
    So your suggestion is to go back in time and un buy them?
  4. Jan 11, 2019 at 8:44 AM
    ColoradoTJ
    ColoradoTJ Professional Cat Herder Moderator
    Colorado
    Summit White 3500
    Don’t leave Marty behind this time Doc.
  5. Jan 11, 2019 at 8:45 AM
    Dr. Emmett Brown
    I'll make sure I put a damn leash on him this time
    ColoradoTJ likes this.
  6. Jan 11, 2019 at 8:46 AM
    Big tall dave
    Big tall dave Active Member
    Chicago, IL
    2018 Tacoma TRD OR DCLB
    TRD skid plate, Rek Gen mud flaps, Rugged Cover 2 hard tonneau....so far
  7. Jan 11, 2019 at 8:52 AM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Santa Rosa
    2014 Double cab
    Mostly whatever sweet stuff I can find at Vatozone
    Those tires have a manufacturers warranty. Takes them back and tell them they are bad tires and swap for a different brand. Any reputable shop would have no problem doing this.
    I know @T4RFTMFW had issues with a set of coopers and did this.
  8. Jan 11, 2019 at 8:52 AM
    ColoradoTJ
    Colorado
    Summit White 3500
    I tried this on my current truck and it was horrible. I had to dismount the tires, have the glass beads vacuumed out, mounted again and rebalanced.
    I still have a vibration. Not sure if the beads are all out or I have a bad tire.
  9. Jan 11, 2019 at 8:53 AM
    Dr. Emmett Brown
    Pretty sure samsclub (where I bought them from but did not have them mounted) said I voided the manufactures warranty by not having them install them
  10. Jan 11, 2019 at 8:54 AM
    T4RFTMFW
    T4RFTMFW 10% OFF
    Close.
    I had issues with Hankook Dynapro tires, went through 6 before saying fuck it and going with Cooper Discoverers and had no more issues.
    Tire shop refunded me in full and never charged me a dime, took all tires back under manufacturer defect.
    tacomgee and ColoradoTJ like this.
  11. Jan 11, 2019 at 8:56 AM
    ColoradoTJ
    Colorado
    Summit White 3500
    Road force balancing solves a lot of issues with truck tires and the dreaded vibes.
    I can’t run the KO2s on my truck due to tire life expectations plus would rival a fresh pizza at a college party.
    wolfman00 and JaCado like this.
  12. Jan 11, 2019 at 8:57 AM
    ColoradoTJ
    Colorado
    Summit White 3500
    I call bullshit on their part.
    Big tall dave and JaCado like this.
  13. Jan 11, 2019 at 9:01 AM
    Big tall dave
    Chicago, IL
    From previous experience i’d say you’ve prob got a bad tire or didn’t put enough beads inside the tires. I’ve found that some really heavy tires require double the suggested weight on the bead manufacturers application chart
  14. Jan 11, 2019 at 9:03 AM
    jeffmansion
    jeffmansion Well-Known Member
    Jeff Mansion,New Hampshire
    16UTILITY4x4MT
    AFE Pro Dry Air Filter, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 265/75/16 Falken Wildpeak AT3W's, 1/2'' Headstrong Offroad lift, 1'' heavy metal rear lift. RokBloks XL mud flaps, Westin bedmat.
    Never once had had to balance my Wildpeak AT3Ws
    PrimerTaco likes this.
  15. Jan 11, 2019 at 9:04 AM
    #35
    PrimerTaco
    PrimerTaco Well-Known Member
    Taco #7, 2019 TRD OR DCSB 4WD Cement
    Tech/Prem packages, Bedmat, Tint, Staying Stock
    I love the look of KO2's but after having a set on my 16 and 17, never again, they were a pain in the ass to balance in the first place even with wheel phasing and road force and then would still come unbalanced. Between that and the shitty snow handling / weight, there are better options.
    dre5491 likes this.
  16. Jan 11, 2019 at 9:13 AM
    #36
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    If they try to say that, ask for the contact information for their attorneys. Bring up the Magnuson-Moss Warranty Act.
  17. Jan 11, 2019 at 9:14 AM
    #37
    ColoradoTJ
    Colorado
    Summit White 3500
    I was up to 16oz per tire with the beads.
    Funny, with road force balancing I hardly have any weight, but have a vibaratiin ~75 mph. Good excuse to go 80 right?
    I agree, I must have a bad tire or it could be from having the tires siped.
  18. Jan 11, 2019 at 9:15 AM
    #38
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    2005 black sand pearl TRD OR
    stickers and sticker accessory's
    cause they are trash tires
  19. Jan 11, 2019 at 9:16 AM
    #39
    gla49
    gla49 Member
    Greg
    17 TRD Quicksand 4d
    They are great tires. Listen to the complaints on this forum about the Tacoma, but it is a great truck too. Goodrich has a warranty and if a tire is defective they will be happy to replace it. When I bought my last set of KO2's I asked about the balancing issues I had been reading about. I was told that they (the tire store) sell thousands of them and almost never have issues. If they do, Goodrich stands behind them and will replace. I have 265 75 16's and they roll perfectly at all speeds.
  20. Jan 11, 2019 at 9:19 AM
    #40
    PrimerTaco
    Weird I must of just had a bad set on two seperate vehicles from two different suppliers / tire installers in two different states. But what are the odds its not the tire...
    SoCali_Guy likes this.
