Damn you KO2s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dr. Emmett Brown, Jan 11, 2019.
  1. Jan 11, 2019 at 9:38 AM
    #41
    Dr. Emmett Brown
    Dr. Emmett Brown [OP] Well-Known Member
    One of my buddies works for the samsclub I bought the tires from and he said bring it in and he'll try balancing them for me and if he can't he will warranty them for me!
  2. Jan 11, 2019 at 9:58 AM
    #42
    trdsilver
    trdsilver Well-Known Member
    So Cal
    2016 TRD Sport 4x4
    OVTune, King 2.5", Total Chaos UCA's, Icon RXT Leaf, Icon Rear Bumps, Pelfreybuilt Silders, JL Audio, Cali-Raised LED, Toyo RT 285-70-17
    I was in the same boat as you bud. I could NOT get my vibrations to go away. I had my KO2's balanced a half dozen times from multiple shops. I had my alignment redone as well. Nothing helped. The only thing that fixed it was getting different tires. Best of luck.
  3. Jan 11, 2019 at 10:06 AM
    #43
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    i would try getting the roadforce balanced if you haven’t yet. i had
    severe issues...roadforcing them fixed it. still smooth as glass.
    if that doesn’t work- your tires are probably warped from bad storage, or a bad belt.
  4. Jan 11, 2019 at 10:31 AM
    #44
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    My suggestion is to read reviews on everything including tires before you buy,pretty simple thought.
  5. Jan 11, 2019 at 11:32 AM
    #45
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    So whats the problem with KO2’s i’ve been using them for year and zero issues. Are they the greatest no, but they do everything well.
    Flash1034 and DavesTaco68 like this.
  6. Jan 11, 2019 at 11:53 AM
    #46
    Dr. Emmett Brown
    I guess simple people have simple thoughts. Thanks though.
    dre5491 likes this.
  7. Jan 11, 2019 at 11:53 AM
    #47
    Dr. Emmett Brown
    I'm pretty sure they Road forced them originally.
  8. Jan 11, 2019 at 12:02 PM
    #48
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    I ran LT265/70R18 KO2s for about 10,000 miles and they wore down extremely fast and there were chunks of polyester missing from the sidewall when I swapped them for the Exo Grapplers. They went from 18/32nd's tread depth to between 8-5/32nd thickness and didn't really have great traction on wet roads and were not exceptional off-road either. A garbage tire that I'm not interested in running again...
    dre5491 likes this.
  9. Jan 11, 2019 at 12:13 PM
    #49
    BigAirGar
    BigAirGar Well-Known Member
    Ont Canada
    2016 TRD Sport DCLB AT
    Liv Free Rock Hrd
    SAME here - going to try Toyo OC AT2's next. 4th rebalance in 30,000kms and 90% hwy.... disappointing!
  10. Jan 11, 2019 at 12:19 PM
    #50
    unavailableTaco
    unavailableTaco Well-Known Member
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    I think quality control of a lot of tires has something to be desired. In the past 10 years I have always replaced my Tacoma tires within a 2-3 weeks of purchasing new, with Michelin LT LTX's. And I'll be damned out of every set(5) there was one that would never balance and made the truck pull a little. Is it too much to ask to get 4 out of 4 good ones. Geez.
  11. Jan 11, 2019 at 12:22 PM
    #51
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I've had the least issue with Michelin LTXs surprisingly. I have had a set on my Tacoma before it became a wheeling rig and I currently have a set on my Land Cruiser. Thats a good tire. But the immense weight of the cruiser probably helps cause I'd never know if one was a a tiny bit out of whack.
  12. Jan 11, 2019 at 12:44 PM
    #52
    airmac_11
    airmac_11 Well-Known Member
    2019 Cement DCSB Premium/ Tech TRD 4x4 Sport
    Wow. Was looking forward to swap out my stock Open Country tires for KO2s but now not so much. Ummmmm.
  13. Jan 11, 2019 at 1:08 PM
    #53
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    DCSB 12 slightly lifted Tacoma
    Ripped off all four mudflaps. Scratches all down both sides 6112’s up front on 3rd notch 5100’s in back with Toytech 1” block Skids & sliders from SOS Concepts I got rid of the 1” block and put on Wheelers 1 1/2” progressive AAL. SPC UCA. Be sure your standing on the drivers side when reading the instructions! I swapped sides so many times that I can swap UCA’s in 15 minutes. I put in the 3/4” spacer to eliminate the Taco Lean, and just got my 4th alignment. Traded the OEM rims for 17” Sport rims and a bora bora 1” spacer. I got my Firestone 285/70/17 MT2’s. Pelfreybilt gas tank skid and hi-lift jack should be here Friday. Looking at bumpers, but I think they will wait for next year. So far I’m happy with my build. I’ve done it all myself, leading to a lot of cussing and frustration, but it’s all mine.
    So sometimes people will come to TW to get what it’s touted to provide,, useful information. If a person is able to just dismiss a jackass, kudos to them because I’m not. Unfortunately jackasses and assholes pop up on damn near every feed on this forum and ruin it. I’ll get blocked or kicked off TW for my opinion, I’ll never know because this is the last time I’ll be here, and that’s sad only because mother fuckers like you get to keep spewing your stupid shit, I only hope you see this before it’s deleted.
    I don’t know if this will help you or not, but your comment just discounted every legitimate thing that anyone had to say, good or bad, to the point that this feed is worthless.
    Enjoy your Toyota’s y’all.
    I fucking love mine.
    gotblika and Flash1034 like this.
  14. Jan 11, 2019 at 1:15 PM
    #54
    unavailableTaco
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    I agree with what you said. The post you have responded to here I did not even see. Dr. EB spouted something inconsequential so I did not notice it. How ironic that someone with so much to say has nothing of value to speak about.
  15. Jan 11, 2019 at 1:18 PM
    #55
    airmac_11
    Unfortunate for everyone involved. Hope you reconsider and move beyond what was said. Any consolation - Nice Truck.
  16. Jan 11, 2019 at 1:22 PM
    #56
    ChronicTaco
    ChronicTaco Well-Known Member
    British Columbia
    Canadian Special
    I guess I got a good set, I have had good luck with my Ko2s so far, they have around 16 000 miles and no issues.
    Would be willing to try another tire as well but 3 ply sidewalls and the three peak mountain symbol are my requirements for a tire, and as far as I know the Ko2 is the only tire that has both.
    Flash1034 likes this.
  17. Jan 11, 2019 at 1:40 PM
    #57
    Dr. Emmett Brown
    I dismissed his sarcasm with my ow sarcasm .. what are you trying to say?
  18. Jan 11, 2019 at 1:48 PM
    #58
    Dr. Emmett Brown
    No blue dot or punch on rims. What is the purpose of those two things you mentioned? Are those points of reference for mechanics?
  19. Jan 11, 2019 at 2:09 PM
    #59
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    I apologize to everyone, especially @Dr. Emmett Brown
    I misunderstood his comment.
    Dr. Emmett Brown[OP] likes this.
  20. Jan 11, 2019 at 2:10 PM
    #60
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
