Damp smell in cabin after rain?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by R490, May 16, 2018.
  1. May 16, 2018 at 8:30 AM
    R490
    R490 [OP] Well-Known Member
    Upgrayedd
    VA/PA
    Got a mildew smell going on in the cab of my truck after it rains. I can't tell where it's coming from and the carpet isn't damp.
    Any thoughts?
  2. May 16, 2018 at 8:32 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    I had this happen on my first gen ext cab n found my windo seal was old and no longer sealed. Since youve got a double cab id check your door seals. If not there you can spray water on the windows etc n check leaks
    R490[OP] likes this.
  3. May 16, 2018 at 10:31 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Check your carpet on the passenger side close to the firewall next time it rains. This happens in my 2012
  4. May 16, 2018 at 10:31 AM
    R490
    Upgrayedd
    VA/PA
    Clarification: This is not related to rear seat stain mod.
  5. May 16, 2018 at 10:32 AM
    Bebop
    Nick
    Understood.
  6. May 16, 2018 at 10:34 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    cabin filter after a hard rain might be damp causing the odor
  7. May 16, 2018 at 10:53 AM
    R490
    Upgrayedd
    VA/PA
    Possibly, the carpet isn't wet at all so I'm beginning to think it's related to something else.
  8. May 16, 2018 at 10:56 AM
    scocar
    scocar hypotenoper
    Also just check for decaying organic debris under the back of the hood/on the fresh air intake grill. It can get packed into the upper back corners behind the hood hinges. Once soaked, hmmmmmmmm, aroma.
    ChadsPride and knottyrope like this.
  9. May 16, 2018 at 11:27 AM
    EnonEye
    EnonEye Well-Known Member
    David
    O-H-I-O
    Silver '06 DCSB TRDPreRunner Off-Road/ Tow package
    Change cabin filter, place decent air deodorant in cabin and have a nice day
  10. May 16, 2018 at 11:32 AM
    Taco crazy
    Taco crazy Well-Known Member
    Chattanooga TN
    '97 Tacoma std cab V-6
    Locked front and rear, bumpers, sliders, cage etc..33" Cooper STT PRO's. Mild suspension lift.
    Be sure the evaporator drain is not clogged, allowing water in the passenger side floorboard.
  11. May 16, 2018 at 11:32 AM
    Aerose91
    Aerose91 Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    Take out the cabin air filter and with the fan on full blast, spray lysol into the intake vent under the hood. Lysol kills mold/mildew and doing this will not only work it through your whole vent system but also atomize it throughout the whole cabin. Do it with the vents set to floor and dash. Also, turn the AC on and hit it then, too. This will pull the lysol over the AC compressor where mold can build up.
    I know this doesn't solve your problem of finding the cause but killing any mold before it proliferates will really help in the long run
  12. May 16, 2018 at 11:33 AM
    R490
    Upgrayedd
    VA/PA
    The air doesn't smell bad though, the smell goes away when the air con is running.
  13. May 16, 2018 at 11:58 AM
    gmartin284
    gmartin284 Well-Known Member
    Gage
    2008 Tacoma 4x4 double cab
    I have the same issue. If it rains super hard I can notice a small damp spot in carpet on the rear pass side near the rear corner but other than that no wet carpet or noticeable leaks. I've heard it could be a bad seal on the cab itself on the backside resulting in needing to remove the bed to re-seal it.
  14. May 16, 2018 at 12:04 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Could be 3rd brake light seal if that has been messed with............
  15. May 16, 2018 at 12:10 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I tried the lysol thing, didnt really help. But I did end up smelling that lysol stink for weeks.
