Dang TPMS light!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bpayne97, Jan 29, 2014.
  1. Jan 29, 2014 at 9:44 AM
    bpayne97
    bpayne97 [OP] Well-Known Member
    McAllen, TX
    06 TRD OR 4x4 Debadged
    URD SS Kit and TRD shift knob, rearview mirror bracket, Fox 2.0 coilovers and smooth bodies
    I bought an 06 DCSB two weeks ago. When it showed up the TPMS light was on. Dealer said it was the weather but then I had a flat. Tires were pretty lame so I put on some cooper ATP 265/75r16's and replaced all 5 sensors. Light was off for a day or 2 then came back in. Had discount reset it yesterday and I'll be dang if it didn't come back on this morning! I went from an 03 4runner to this Tacoma and I sure miss the 4runner NOT having the TPMS system. Hope they can get it right because I am loving the taco other than that! Ok, I'm done, carry on!
  2. Jan 29, 2014 at 9:48 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
  3. Jan 29, 2014 at 9:50 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Check tire pressure manually to make sure there is no small/slow leaks. I see you also put a sensor in your spare so check that too. If pressure is good than maybe sensors still aren't calibrated correctly.
  4. Jan 29, 2014 at 9:58 AM
    bpayne97
    McAllen, TX
    Thanks Delmarva!
  5. Jan 29, 2014 at 10:57 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I am definitely not a fan of them. I can feel when I have a low tire. You can thank the idiots that rode around on under inflated tires in Explorers for TPMS. My light was coming on in cold weather. It turns out the idiots at the dealer did not know that the PSI spec for BFG ATs is 46 not 32. I have a sticker on my door jamb but sure they even know how to read. Next time in my oil change and rotation I made the service writer note it.
