Danger of no zirc fittings on 3rd Gen u-joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shackley, Jul 9, 2017.
  1. Jul 9, 2017 at 3:55 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Higher speed would make it even more unimpressive lol.
  2. Jul 9, 2017 at 4:22 PM
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    This!
    Except the every two years part. A buddy of mine robbed an (original) non greasable U-joint off an old junked van and put them in his early Bronco. It lasted years and he went through at least a couple of greasable axle joints during that time.
  3. Jul 9, 2017 at 4:24 PM
    Launch21v
    Launch21v Well-Known Member
    Fontana, CA
    16 TRD sport dclb 4x4 tech pack w/jbl white
    Must have been a mistake. Take it back to the dealer and ask them to install your zerks.
    :boink:
  4. Jul 9, 2017 at 4:33 PM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    I doubt I'll keep my truck long enough to give a shit about this subject. Sure, I say I'm going to keep it for 20 years, but who the fuck am I kiddin.
    Sub'd for the inevitable good ol fashion TW slap fight.
    Nfarrall likes this.
  5. Jul 9, 2017 at 4:37 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Both of these.
  6. Jul 9, 2017 at 4:41 PM
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    2016 Barcelona Red Tacoma TRDOR
    See build thread
    I dont want my truck to Grenade! ERMERGERD!!!!!!!
  7. Jul 9, 2017 at 5:05 PM
    rjacobs
    rjacobs Well-Known Member
    The only reason I say every 2 years(could say 3, or whatever) is for the OP who is so concerned about his u-joints failing. Change em out every couple years for new, the cost will be under $100 for the whole truck, and they wont be ridiculously stuck in the yokes. Every 2 years would be ~20-25k miles for most people...
    Or press em out yearly, clean and grease the caps/needle bearings, toss em back in.
    Again, I would rather have non-greasable joints as they are stronger, even if they require more frequent replacement for "peace of mine".
  8. Jul 9, 2017 at 5:58 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Actually there is probably a greater "danger" of having serviceable u-joints that never get serviced...see ignorant owners and service techs.
    Lt. Dangle, bshammer0 and hiPSI like this.
  9. Jul 9, 2017 at 6:28 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    I like the pole vaulting myth.
    Myth busters did it.
    Anton338 and BarcelonaTom67 like this.
  10. Jul 10, 2017 at 7:29 AM
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    The First production run on the 2016 Tacoma's last half of 2015, all the 4X4 trucks then had grease Zerks. I have a 2016 bought in Oct 2015 and it has all the grease Zerks.
  11. Jul 10, 2017 at 8:38 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Only the 2 up front in my Baja 8/16 build, but I can definitely tell you that purging them every 1500-2000k miles of heavy driving I do keeps the clunking at bay...
    shakerhood likes this.
  12. Jul 10, 2017 at 8:43 AM
    Willbird
    Willbird Well-Known Member
    Bill
    Magnetic Gray Metallic 2017 SR5 Double Cab
    The last time I had a U joint fail was in 1985...and it was a 1972 car :)
  13. Jul 10, 2017 at 9:45 AM
    mmwada
    mmwada Active Member
    The way I see it, having grease fittings for u-joints doesn't guarantee proper lubrication. The only sure way is to disassemble and grease. When using a fitting to lubricate, the grease will follow the path of least resistance. There are 4 bearing areas that needs lubrication. The only way to possibly know that these 4 bearings have been lubricated is to continue pumping grease into the fitting until grease starts coming out of the seals for all 4 bearings. Even this might not be a certainty. Once you weaken, break or damage the seal, the grease can no longer stay in the u-joint or contaminants can enter the bearing area. Now, you will get into the debate on... are grease fittings necessary for suspension components?
  14. Jul 13, 2017 at 8:20 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Is this what you zerk off to?
    jkm25 likes this.
  15. Jul 14, 2017 at 7:48 AM
    #35
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    I know it's an entirely different truck...
    But, my 2001 Dodge 2500 4x4 Cummins diesel truck also had non-greasable u-joints in all the drive shafts. I didn't have any one of the u-joints go out until between 90K - 100K miles. I noticed it when the rear drive shaft started making a very noticeable clunk when I let the clutch out when starting out from a stopped position, and it would make a loud clunk-clunk-clunk... for the first several seconds of rolling until I got up a little speed. Nothing fell off on the ground, and it was only that one u-joint that was damaged (I had ALL the u-joints replaced when I took it in to my mechanic).
    Chastaco likes this.
  16. Jul 14, 2017 at 7:57 AM
    #36
    su.b.rat
    su.b.rat broken truck
    for the end user this is kinda the point with a non-zerk setup, right? for 'yota the point is to save a few bucks. but there's no big problem. and you can upgrade the shit outta your hardware however you like.
  17. Jul 14, 2017 at 1:59 PM
    #37
    rjacobs
    For the end user that understands such things, yes. ME, I choose non greasable whenever I can, but I dont go in water or mud if I can avoid it, if I did I might choose greasable so I could flush them, and just understand they were slightly weaker.
    For Toyota, the price difference is negligible if anything, HOWEVER every manufacturer is going to non-servicable/lifetime this and that because 98% of people are lazy and dont perform regular maintenance. Like BMW claims lifetime transmission fill, ZF states 100k miles, most BMW guys go 50k max...
    su.b.rat[QUOTED] likes this.
  18. Jul 14, 2017 at 2:01 PM
    #38
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    she sure knows how to handle a pole :D:D
    mbarbay likes this.
  19. Jul 14, 2017 at 2:11 PM
    #39
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Been there done that. No pogo or pole vault. Drive shaft came off at the tcase while I was doing 65ish in my old 83 pu. I just pulled over to the shoulder, grabbed my wrench and took the drive shaft the rest of the way, locked the hubs and continued on my way in fwd. Only Carnage that did happen was the driveshaft punched a hole through the floor board.
  20. Jul 14, 2017 at 2:15 PM
    #40
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Many manufacturers (aftermarket) are dropping greaseable (zerk) ujoints completely. Last couple of times I replaced u-joints it was tough to find greaseable ones.
    I don't know why everyone is making such a big deal about this. If it bothers you that much change them out for greaseable ones. If you don't know how then get your wife to do it.
