Dangerous problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by dc5dc2, May 20, 2010.
  1. May 20, 2010 at 10:30 PM
    dc5dc2
    dc5dc2 [OP] Member
    Alfredo
    95020
    03 Tacoma SR5 TRD
    This is my first post and i have searched the forum for answers but cant find any, I have a 97 Toyota Tacoma 4x4 Stick Shift and i been having problems with my clutch, it gets stuck and along with the clucth getting stuck and the transmission locks up(it wont switch gears not even to neutral) the only way to get it unstuck while on the road is to pump the clutch pedal but when in traffic, so i wont cause an accident, I hold the brake causing the truck to shut off. sometimes i get to the stop light and it wont come off first gear its horrible, u have people honking and screaming causing chaos(over dramatization) and i cant help it, my thoughts are that if it has a throw out bearing maybe its getting stuck somehow or maybe their is air in the clutch line but if their was air wouldn't the pedal stay down. Please help any info will be greatly appreciated, thanks.
  2. May 20, 2010 at 10:31 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    Sounds like air in your clutch. Have you bled it yet?
  3. May 20, 2010 at 10:44 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sounds like maybe your clutch master cylinder (or slave, mounted on the bell housing, if they still do it this way ) is worn out around the pistons inside the cylinder keeping it from building & HOLDING hydraulic pressure, i.e; its building pressure but losing it at the same time, ya got fluid &/or air leaking around both sides of the piston, not sure what kind of check valve is inside, could be a one-way or just a straight anti-reversing valve, but if no real fluid leak is present thats where I'd start, you could probably bleed it & gain a little bit back but I'm thinking one or both clutch cylinders are history or soon to be.......Good Luck....:cool:
  4. May 20, 2010 at 10:59 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    used to happen to mine. replace master/slave cylinder, then bleed line. all fixed
  5. May 21, 2010 at 2:17 AM
    dc5dc2
    dc5dc2 [OP] Member
    Alfredo
    95020
    03 Tacoma SR5 TRD
    il check it out in the morning n replace it see if that was the problem, thanks everyone, hopefully thats the problem.
  6. May 21, 2010 at 2:35 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Your Welcome........:D:cool:
  7. May 22, 2010 at 4:35 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    X2
  8. May 23, 2010 at 7:42 PM
    dc5dc2
    dc5dc2 [OP] Member
    Alfredo
    95020
    03 Tacoma SR5 TRD
    sorry guys i havnt had time to post up wats up, k i bled the line and problem still consists so im changing out the slave cylinder, i ordered it cuz they didnt have any in stock, wont be here til wed., any advise on wat i should do or shouldnt cuz i was thinkin shouldnt be to much of a problem to replace just put new one on n bleed it and new fluid, if it doesnt fix it wat else could it be. thanks for any and all advise
  9. May 23, 2010 at 7:46 PM
    dylandercole
    Dylan
    youll be fine. have plenty of towels on hand, it gets a little messy.
  10. May 23, 2010 at 7:50 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    canton Ga
    06 reg cab sr5
    General lee horn mod, Bilstein 5100's and maxtrac 4 inch lift spindles. omd spring rebuild w/ s10 springs kenwood h/u and cb, warn trans4mer brush guard level 8 tracker wheels and cooper s/t 33's
    That happened to me in a jeep commanche before I filled up the clutch master cylider resivior to drive it back home and to school for a few days before i could change out the slave cylinder.
  11. May 26, 2010 at 8:52 PM
    dc5dc2
    dc5dc2 [OP] Member
    Alfredo
    95020
    03 Tacoma SR5 TRD
    problem still persists even after slave cylinder replacement and bleeding the line, what else could it be guys, please HELP
  12. May 26, 2010 at 9:21 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well if you changed it & all is good (building,holding pressure) I'm starting to think maybe 1 (or more) "fingers" on the pressure plate could be bent or broken causing this intermittant binding (where the fingers all meet against the throw out bearing, something else to consider anyway.....:confused::eek::confused:
  13. May 26, 2010 at 11:45 PM
    dc5dc2
    dc5dc2 [OP] Member
    Alfredo
    95020
    03 Tacoma SR5 TRD
    thanks for the advise, i was wondering if there was anything else it could be b4 i start taking the transmission apart.:notsure:
  14. May 27, 2010 at 12:32 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    I'm with Doug on this one. You should probably pull the tranny and figure out what exactly is going on in there. Replace the TO Bearing and depending on the wear that is present, it might make sense to just replace the whole assembly. Friction Disk, Pressure Plate, and TO Bearing.
    Take some pictures of what you find if you do decide to pull it apart. I have a really good feeling that your throwout bearing has started the self destruct process.
  15. May 27, 2010 at 10:23 AM
    dc5dc2
    dc5dc2 [OP] Member
    Alfredo
    95020
    03 Tacoma SR5 TRD
    Thanks everyone will try to put up some pics but need to get all the parts first, il let u know once i begin. oh, does anyone know of a link where it shows someone who has removed the transmission, the way im thinking is that i may have to remove the sub-frame. Thanks for everything.
  16. May 31, 2010 at 12:36 AM
    dc5dc2
    dc5dc2 [OP] Member
    Alfredo
    95020
    03 Tacoma SR5 TRD
    fixed the problem, cant believe i did not notice this when bleeding the line, yes it ended up being the master cylinder(the one running from the clutch line), replace it and now problems are gone, thanks everyone for your help and advise.
  17. May 31, 2010 at 11:24 AM
    dylandercole
    Dylan
