Dangling Harness question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by erazon, Jun 6, 2011.
  1. Jun 6, 2011 at 9:07 PM
    erazon
    erazon [OP] Active Member
    Seatle
    06 Tacoma CrewCab
    While installing a new radio this weekend, i found a dangling harness when i removed the cover under right-center air vent (this is the left cover opposite to where the 4wd switch). See photos below.
    Does anyone what this harness is for? I was planning to put LED lights under the dash. Is this something that can give me a 12V supply?
  2. Jun 6, 2011 at 9:16 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    yellow usually means airbag system, its prob a shut off wire that they may use for some trucks?
  3. Jun 6, 2011 at 9:21 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Don't know. I have a trd with all the options and I don't think I have any switches there. As for power, go to walmart and buy a five dollar light bulb power tester and check it out. If it lights up all the time you've got a hot line. If it lights up with ignition on but not off it's a ACC line. If nothing, it's nothing. I'd guess it has power though one way or another.
  4. Jun 6, 2011 at 9:26 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Don't some models have a switch in that area to turn off the passenger air bag?
    edit: here's a picture of the switch...
  5. Jun 6, 2011 at 9:31 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2005 4x4 DC TRD Off Road
    11 Color Matched Grille, Pro comp 7089s, 265/70/17 Wrangler Duratracs, Black Running Boards, Tinted Windows, Bed mat, Weathertech Floorliners
    I am guessing air bag shut off for access cabs.. Since you have a DC, it is not needed.
  6. Jun 6, 2011 at 9:31 PM
    pudge151
    Sean
    Connecticut
    thats what i was thinking
    and im almost certain that yellow wire wrap is airbag code
  7. Jun 6, 2011 at 10:00 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Makes sense. I have a DC.
  8. Jun 7, 2011 at 6:23 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    As stated above it's for the airbag switch if you have an access cab. Any mass produced vehicle or equipment with different configurations will share the same wiring harnesses but all connections may not be used.
