Dark Anthracite Wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dippitydoo69, Jan 30, 2023.
  1. Jan 30, 2023 at 7:52 AM
    dippitydoo69
    dippitydoo69 [OP] Member
    Wheel Help (no, not that question)
    Hey all, I’m looking to get the OEM Dark Anthracite wheels, PT94635160, to replace my 2023 SR steel wheels when I get it.
    I’m quite new to this all so I tried to do my research but just can’t find a definitive answer
    I know I’ll need different lugs and TPMS - center caps as well if they’re not already included in the wheel set. Do I need anything involving a valve stem?
    Can anyone link the OEM 20 degree TPMS sensor used for alloy wheels and silver lug nuts?
    Am I going to need anything else besides these things I mentioned?
    TIA!
  2. Jan 30, 2023 at 7:57 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I think you answered your own question? The TPMS sensor is part of the valve stem. So if you get new ones, they should be the ones that work with the alloys.
    I believe Toyota wheels come with the correct center caps. No need to buy them separate.
    You will need the new TPMS sensor to be programmed. That is a normal part of the mounting service though. If you are keeping your steelies as a second set, write down both set of sensor IDs so that they can be programmed easier later.
  3. Jan 30, 2023 at 8:00 AM
    dippitydoo69
    Okay thank you for your response. So I need 20 degree TPMS will go with the alloy, I am not sure how to differentiate them when looking online? Same thing with lug nuts?
  4. Jan 30, 2023 at 8:19 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good question.
    What I usually do is check the Toyota site. There's a parts section under the Owners page. Find the TPMS part numbers that go with alloys and then google those to find a good price.
    I believe the Toyota alloys all use the same flat seat lug. It has a taper on it that can be used with a steelie in an emergency. These came up in a search and look similar, but the head is a bit longer than I had:
    https://parts.toyotaofgrandrapids.com/oem-parts/toyota-wheel-nut-9008494002
  5. Jan 30, 2023 at 9:10 AM
    dippitydoo69
    Thanks for your help
    tonered likes this.
  6. Jan 30, 2023 at 9:18 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
  7. Jul 1, 2024 at 6:53 AM
    TicoTaco23
    TicoTaco23 Member
    Rob
    East Texas
    2023 DCSB 4X4 stock
    + 1 Hula dancer in from the coast
    I'm new to this also, and looking for the same outlook. So will the silver lugs from the steelies work on the new Toyota alloys?
  8. Jul 1, 2024 at 11:44 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    No.
