"Darting" in 4WD?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LabradorBoy, Jan 26, 2014.
  1. Jan 26, 2014 at 3:34 AM
    LabradorBoy
    LabradorBoy [OP] Well-Known Member
    Canada
    09 DCab TRD Sport
    Hello, I have a 2009 Tacoma TRD Sport 4wd, DCSB with the M/T. Great truck, have put 105k trouble free km's on it and I plan on running it a lot longer. I have a disturbing problem with my truck that I can't seem to figure out.
    I live in NE Canada where right not it's -30*C regularly and we have 3ft of snow on the ground; roads are patchy asphalt and ice as we do not use salt here due to the cold temps. Roads are in this winter state for about 5-6 months of the year. I have owned and driven this truck and several other trucks during my time here; my truck didn't do this until recently.
    The problem is a front end "darting" that appears to be affecting either my steering or my drivetrain, or both. Essentially, on patchy surfaces, if one front tire grabs different traction (be it more or less), it will grab and pull my truck a few inches in either direction, which is scary when you're doing 50-60km/h on an icy road. It could be slop in my steering, but I checked my tie rod ends and freeplay at the wheels and it seems quite tight.
    Has anybody here experienced the same thing? Is this a problem that others have had? Looking for a few leads as the nearest Toyota dealership is 1200km away (!) and although there is a great mom & pop shop here who does most of my work, I like to bring them what I can in diagnostic assistance.
    Appreciate any help TW can offer.
  2. Jan 26, 2014 at 3:57 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Whoa that's pretty crazy... can't help you but free bump for ya.
  3. Jan 26, 2014 at 6:01 AM
    vstrom
    vstrom Well-Known Member
    I live in Northern Mb and experience the same type of winter.
    If I were you I'd try the same drive in 2wd and see if the problem persists. If it doesn't then you can assume the problem is in the front two tires.
    You've had this truck for awhile and it's never done this, so something changed.. do you have access to a garage or hangar? Let it defrost completely and then try it again. Whenever I have some weird problem in the dead of winter I find this usually helps.
    Are you getting any lights or beeps when this happens? Maybe clean the tire speed sensors?
  4. Jan 26, 2014 at 6:12 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I assume you're in 4wd. Could you be experiencing "torque steer"? Did you recently get new tires (better traction)?
  5. Jan 26, 2014 at 6:33 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I was gonna say the same thing. I had a real bad problem with darting when I had different size tires on the front.
    The one thing that sucks about 4 x 4's, you gotta by four tires=$$$$=:(
  6. Jan 26, 2014 at 6:36 AM
    LabradorBoy
    Canada
    09 DCab TRD Sport
    Yes, only when in 4wd. The truck is perfect in 2wd, but then driving on icy roads becomes another sort of challenge.
    Same tires for the past two Winters, BFG A/T's in excellent condition. It does feel a bit like torque steer, but it's not only when on I'm on the gas, she'll do it when driving at a constant speed too.
  7. Jan 26, 2014 at 6:42 AM
    LabradorBoy
    Canada
    09 DCab TRD Sport
    Appreciate the insight. The problem exists in 4wd only and it happens when driving in a straight line. I do have access to heated space and I will give that a shot on Monday at work to see if it's just the cold that is triggering it. I have the TPMS light on (that's a normal Winter occurrence for me, not significant) and I have been watching for the traction control light to flicker when it happens but I have not seen anything flicker when this is happening.
    The issue to me does appear to be sensor based as well, almost like my tires are erratically receiving power from the front diff, which is weird. I will try to haul the wheel speed sensors in the next few days and clean them up.
  8. Jan 26, 2014 at 7:00 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Thinking this has to do with the wheel alignment.
  9. Jan 26, 2014 at 7:43 AM
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    put new bf all terrains on my truck, and it does the same thing when i hit a patch or a bump... figured it was just better traction..maybe time for an alignment.
  10. Jan 26, 2014 at 7:48 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    TPMS light ON? Uneven tire pressure could cause that issue I would suspect.
  11. Jan 26, 2014 at 8:02 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I think it's just the bite of your new tires. Drive on an evenly iced or snowy road in 4wd and if your truck doesn't dart around, then you'll know it's just the new tires grabbing on a patchy surface.
  12. Jan 26, 2014 at 8:07 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    ^^ Easing off the throttle on patchy ice would be a good idea, too.
  13. Jan 26, 2014 at 8:32 AM
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
    If he eases off the throttle on patchy ice up there he will eventually come to a standstill! :)
  14. Jan 26, 2014 at 3:54 PM
    LabradorBoy
    Canada
    09 DCab TRD Sport
    I do not have uneven tire pressure folks. Varying temps, i.e. -30*C one day, +1*C the next means that I get a fair bit of expansion and contraction going on.
    This is not a tire pressure issue.
  15. Jan 26, 2014 at 3:54 PM
    LabradorBoy
    Canada
    09 DCab TRD Sport
    Not new tires. 2yrs now.... didn't do it last Winter, does it this Winter...
  16. Jan 26, 2014 at 3:55 PM
    LabradorBoy
    Canada
    09 DCab TRD Sport
    Why thank you! I'm in Goose Bay and you're in Newfoundland, clearly you understand my conditions...
  17. Jan 26, 2014 at 3:58 PM
    LabradorBoy
    Canada
    09 DCab TRD Sport
    I'm going to try to get a wheel alignment this week to see if that helps any. I think I have a loose tie rod end somewhere in the steering and the slop doesn't show up until one of my front tires gets a chance to bite.
    I will update this thread as I progress.
  18. Jan 26, 2014 at 4:03 PM
    GreatCanadian
    Newfoundland
    SR5 4X4 V6
    Yes I certainly do. I've been there a number of times. Worked in Labrador for a winter as well. If people haven't experienced northeast winters they couldn't possibly understand. They can be brutal.
  19. Jan 26, 2014 at 4:53 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Hey op, do you have an abs killswitch mod?? does this problem occur at all when braking or just slowing down??
    ABS in 4wd is more scary than helpful if you ask me, especially in ice and snow and when offroading, since it increases our stopping distance.
  20. Feb 1, 2014 at 6:11 AM
    LabradorBoy
    Canada
    09 DCab TRD Sport
    I have no such mod performed, truck s stock. The problem occurs all the time, speeding up, constant speed, slowing down. It's as though 4wd is cutting in and out as I drive.
    Truck goes in Wednesday for a check up. Hope it's nothing serious in the diff.
