DASAITA ANDROID 9.0 UNIT WITH APPLE CARPLAY WIRELESS AND OEM AUDIO PLUS
Discussion in 'Audio & Video' started by svermilyea, Jul 23, 2019.
  1. Nov 3, 2019 at 9:25 AM
    #641
    Fatmonk8
    Fatmonk8 Did anyone ever tell you you're my hero?
    Paul
    Delco, PA
    2019 SR5 Barcelona Red Taco 3.5 V6
    So the radio I bought does not come with the correct harness?
  2. Nov 3, 2019 at 9:29 AM
    #642
    tjswope
    tjswope Well-Known Member
    Tom
    Chester County, PA
    2019 cement off road double cab MT
    A bunch of smalls
    Not sure what you bought, but you will need a special canbus that doesn’t come with the unit when purchased from their Ebay store. Where’d you buy it from?
  3. Nov 3, 2019 at 9:34 AM
    #643
    Fatmonk8
    Paul
    Delco, PA
    Ebay, just bought the extra harness
  4. Nov 3, 2019 at 10:02 AM
    #644
    Silverhammer
    Silverhammer Well-Known Member
    2017 Black Tacoma TRD Sport
    As far as I know, the harness that comes with the HU is for the non-JBL OEM system. Thus, you should not need an additional harness.
  5. Nov 3, 2019 at 10:12 AM
    #645
    Fatmonk8
    Paul
    Delco, PA
    Even if I'm using the factory camera?
    This is what it says on the eBay post
    "If your car is equiped with the original JBL amplifier and factory camera then you will need to purchase an additional "
  6. Nov 3, 2019 at 10:13 AM
    #646
    tjswope
    Tom
    Chester County, PA
    A bunch of smalls
    That was not the case with what I ordered. Backup camera and steering wheel controls won’t work without the jbl harness, at least when you buy from Ebay. I’m not sure what you get if you buy from Amazon.
  7. Nov 3, 2019 at 10:16 AM
    #647
    Fatmonk8
    Paul
    Delco, PA
    and you didn't have JBL in your truck?
  8. Nov 3, 2019 at 10:20 AM
    #648
    tjswope
    Tom
    Chester County, PA
    A bunch of smalls
    Right, I did not.
  9. Nov 3, 2019 at 10:21 AM
    #649
    Fatmonk8
    Paul
    Delco, PA
    ok, well either way, Ill have both harnesses so if one does not work ill have the other already.
  10. Nov 3, 2019 at 10:50 AM
    #650
    BoomBapClap
    BoomBapClap Well-Known Member
    good idea, it’s close enough right now it’s only my ocd that’s getting in the way.
    My unit is grounded to the passenger side ground point which is why I am surprised I’m getting static. Don’t really know what else might fix it.
  11. Nov 3, 2019 at 11:49 AM
    #651
    tjswope
    Tom
    Chester County, PA
    A bunch of smalls
    Good luck with the install. I’m just in Chester county if you have any questions.
    Fatmonk8[QUOTED] likes this.
  12. Nov 4, 2019 at 10:25 AM
    #652
    jcloutie80
    jcloutie80 New Member
    Installed the px5 headunit this weekend. Only issue I have is not being able to use the stock radio once CarPlay is initiated...
    Does anyone else have this issue?
  13. Nov 4, 2019 at 11:13 AM
    #653
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Hey all,
    I finally finished my install this weekend. Some quick things: Front camera works great. My unit came with an app called FCAM. Opening that shows the front cam view, and then there's a button on the screen to cycle through front and back. Wiring was simple. Other than the ground, everything connects to the headunit and is labeled as such. I also found a setting that after you shift out of reverse it'll switch over to the front cam for the amount of time chosen by the user.
    I ordered the 3d printed brackets. They work perfectly. BUT, be careful how strong you get them. One of my ears snapped off while tightening the mounting bolts. I believe that was at 33% "strength." If you order them printed from Thingverse you'll see what I mean. I'm not worried about it because I can weld the two halves back together or epoxy. Lastly, the cost of the brackets can reach to nutty levels for what they are. Play around with the choices to try and keep the price low.
    I do have one dumb question: is there a way to remove the OEM apps off the screens? There's a bunch of garbage on there that I could do without.
    Claudiomartinof likes this.
  14. Nov 4, 2019 at 12:40 PM
    #654
    QuicksandYoda
    QuicksandYoda Well-Known Member
    Shane
    '19 quicksand 4x4 OR
    If I'm not mistaken, the only way to delete OEM apps, like any Android phone, is to root it. But I could be wrong bc I haven't taken that step and uploaded a rooted ROM yet. Really don't want to end up with a bricked HU lol
  15. Nov 4, 2019 at 12:43 PM
    #655
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Yeah. That would be bad. I had hoped that given the country of origin it was already rooted. Ah well. Thanks.
    QuicksandYoda[QUOTED] likes this.
  16. Nov 5, 2019 at 6:28 AM
    #656
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Another dumb question: Now that I have a USB passthrough that works. Has anyone been able to play music or pass data through USB? My phone comes up in the notification window, but tapping it does nothing. I could also have it connected to the wrong USB.... I didn't connect the singular USB input plug to the back of the radio, just the double. And the phone is connected to one of those.
  17. Nov 5, 2019 at 9:31 AM
    #657
    tjswope
    Tom
    Chester County, PA
    A bunch of smalls
    Works for me through CarPlay. Haven’t tried it without CarPlay. Did you get the adapter that you need to plug in to factory USB ports?
  18. Nov 5, 2019 at 9:54 AM
    #658
    Charles135
    Charles135 Well-Known Member
    LA-Orange county
    19 cement trd
    How much did you get your brackets printed for?
    I believe only the single usb allows the CarPlay and iPod playback
    *other two can playback from a usb drive
  19. Nov 5, 2019 at 10:08 AM
    #659
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    The passthrough is the Amazon one I posted a bit back. It's a direct plug in. The headunit OS is picking it up as connected. It should be treated as a drive. At least that's kind of how it works on PC. In the notification tab it says to tap on it for options. I do that and nothing happens. I even tried the file manager and the phone wasn't available. Maybe I should try the single USB plug and see what happens. I'll post back if that works.
    The brackets were $50 printed and shipped. It's expensive, but I had already messed up one install kit, and another one would be $40. Soooooo. I felt it was worth the money to save time and frustration. Alternatively, you MIGHT be able to get the build file and shop around for printers. Thingverse has three different printers, so maybe one of them would be cheaper.
  20. Nov 5, 2019 at 10:25 AM
    #660
    Fatmonk8
    Paul
    Delco, PA
    When you plug a Android Phone in it defaults to charging, on your phone change it to file transfer, should show up as a "drive" after that. You might have to do that every time you plug in the phone.
