DASAITA ANDROID 9.0 UNIT WITH APPLE CARPLAY WIRELESS AND OEM AUDIO PLUS
Discussion in 'Audio & Video' started by svermilyea, Jul 23, 2019.
  1. Apr 29, 2020 at 4:14 AM
    #1081
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Not if you have bad cell service. The headunit uses the SiriusXM app to play satellite radio.
  2. Apr 29, 2020 at 8:01 AM
    #1082
    svermilyea
    svermilyea [OP] Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    The Anytime Front/Rear camera kit comes with the controller and the harness that connects to the vehicle harness before the head unit. Numerous people have claimed it only works with factory Entune head units. This is not true. It works just fine with the Android 9 PX5 and PX6 based head units.
    The front camera plugs into the supplied harness for the Anytime Camera mod. The rear (factory) camera plugs into the pass through harness for the Anytime Camera mod and then those two harnesses plug into the Android headunit harness. The only thing left is to power the anytime camera mod. My vehicle did not have the third factory harness (this is for a JBL system), but the only thing the third harness is doing is supplying 12V power. You can either build a jumper or tap the power/ground from that harness over to the headunit harness and it works as advertised. If pics are necessary, I post some.
  3. Apr 29, 2020 at 8:10 AM
    #1083
    svermilyea
    Scott
    East Tennessee
    Yes. You can add an aftermarket XM receiver to the Joying or Dasita head units to the Aux in connectors on the back of the head unit harness. You can not use the factory XM tuner, there is no place to plug it into the supplied android harness.
  4. Apr 29, 2020 at 8:58 AM
    #1084
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Which anytime setup are you referring to? I did have one of the setups which worked with it entune but seems the Android HU is missing a plug. I was curious if your mentioning the same one. If so it’s good to know about the 3rd plug. I have to dig up the one I gave.
  5. Apr 29, 2020 at 9:49 AM
    #1085
    svermilyea
    Scott
    East Tennessee
    ssalty likes this.
  6. Apr 29, 2020 at 3:57 PM
    #1086
    Atlfan13579
    Atlfan13579 Well-Known Member
    Mammoth Lakes
    2017 White TRD Off Road 4x4
    Trd Pro Rims Trd Exhaust Trd Air filter Trd Skid plate 265-75-16
    Do you have a video or write up with that info?
  7. Apr 29, 2020 at 4:46 PM
    #1087
    svermilyea
    Scott
    East Tennessee
    Look at the diagram in the previous post (#1085). There are three plug and play jumpers that come with the controller in the picture. They plug directly into the vehicle harness. the middle (smallest) harness can be used if you have a JBL harness in your vehicle (your original headunit was a JBL Entune unit). If not, cut the smallest harness off where the red and black 12v power wires join into the jumper and connect them to 12V power and ground. I used the 12V power and ground on the Dasita headunit harness. I will grab a picture or tomorrow when I have better light.
    Atlfan13579[QUOTED] likes this.
  8. Apr 29, 2020 at 4:50 PM
    #1088
    Atlfan13579
    Mammoth Lakes
    OK I don't have the jbl
  9. May 6, 2020 at 12:22 PM
    #1089
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    Anyone else’s mpg reading go up after the swap?
  10. May 8, 2020 at 4:04 PM
    #1090
    QuicksandYoda
    QuicksandYoda Well-Known Member
    Shane
    '19 quicksand 4x4 OR
    Have had this unit awhile. Just upgraded speakers and installed an amp and sub. Is there a setting in the unit to make it switch over to powering up the amp?
    Figured out. No power to the remote wire. Going to switch it over to the front camera power tomorrow. Is there still something I need to switch in the HU settings? Or am I good?
  11. May 8, 2020 at 6:54 PM
    #1091
    svermilyea
    Scott
    East Tennessee
  12. May 8, 2020 at 7:01 PM
    #1092
    svermilyea
    Scott
    East Tennessee
    Here is the actual harness. Note the blue wire labeled amp
  13. May 9, 2020 at 10:57 AM
    #1093
    QuicksandYoda
    Shane
    Got my amp powered. Used the front camera wire seeing as I have the anytime backup camera system. My wire was gray and said AMP. I'm still not getting any volume from the HU. Is there a setting or something to get it to use the RCA cables instead? What am I missing here? Lol FYI first time I've ever done this. So please be nice lol
  14. May 9, 2020 at 11:13 AM
    #1094
    svermilyea
    Scott
    East Tennessee
    I believe you are using an aftermarket amp. Can you show me how you have that wired?
  15. May 9, 2020 at 2:47 PM
    #1095
    QuicksandYoda
    Shane
    Thanks for the response. I got it figured out. Everything works now
  16. May 11, 2020 at 1:24 PM
    #1096
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Anyone need a JBL bezel to install one of these and willing to trade me their original Bezel?
  17. May 11, 2020 at 4:20 PM
    #1097
    Fatmonk8
    Fatmonk8 Did anyone ever tell you you're my hero?
    Paul
    Delco, PA
    2019 SR5 Barcelona Red Taco 3.5 V6
    Anyone figured out a good way to run a hotspot in your car for the radio?
    I'm using my phone to tether, but I'm pretty sure I'm getting throttled and I have been having problems with connectivity lately.
    Iv been looking at special router that can use a sim card but they are kinda pricey and I'm not sure it's really what I'm looking for.
  18. May 11, 2020 at 4:28 PM
    #1098
    svermilyea
    Scott
    East Tennessee
    I am running an ATT hotspot in my truck. Plugs into the OBDII port for power.
    https://www.att.com/buy/connected-devices-and-more/harman-harman-spark-black.html
  19. May 11, 2020 at 4:29 PM
    #1099
    Fatmonk8
    Paul
    Delco, PA
  20. May 11, 2020 at 4:31 PM
    #1100
    svermilyea
    Scott
    East Tennessee
    I have all the extraneous crap turned off on the service. I just use the hotspot, without tethering my phone.
