DASAITA ANDROID 9.0 UNIT WITH APPLE CARPLAY WIRELESS AND OEM AUDIO PLUS
Discussion in 'Audio & Video' started by svermilyea, Jul 23, 2019.
  1. Nov 10, 2020 at 3:03 AM
    #1361
    khite100
    khite100 Member
    Kevin
    Marietta, GA
    2019 Cement Taco TRD Sport
    VF tuner/ OV 2.0, lift, 33's, bumper, winch, led lights
    So here we go. I have the solution that will allow you to connect to the Dasaita Hotspot and allow your phone to use mobile data. Finally, it works as it supposed to. This solution is for the PX6 with Android 10, MCU 3.65, and zlink.
    1. Connect your iPhone to the Bluetooth
    2. Connect your iPhone to the Wi-Fi Hotspot on the head unit.
    3. Go to settings on the iPhone, then Carplay sections, and be sure that it connects to the head unit. Mine was called CAR-LINK, once connecting it changes to something like zjinnova-D310C
    4. Go to SETTINGS and select Wi-Fi then select the blue INFO icon to the right of the name of your head unit hotspot connection.
    5. Make note of both the IP address and the Subnet Mask address
    6. Select the STATIC option and enter only the IP and Subnet Mask addresses from Step 5 -- (Leave everything else blank)
    Boom, everything works as it should. I will inform Dasiata. This should be the first thing they tell you to try.
    Plkyone[QUOTED] likes this.
  2. Nov 10, 2020 at 9:41 AM
    #1362
    Dwood
    Dwood Well-Known Member
    Dave
    Minneapolis, MN
    2012 Silver DCLB TRD Sport
    35% Tint all around - Meso Dual Bright Dome - GY6.35 reverse bulb hack - Bedlinered Wheels - Tailgate dampener - dashcam hardwire - max liner mats - stubby antenna
    Any 2012+ owners able to assist? Cam isn’t working and steering wheel controls can’t be configured.
    Waiting to hear back from the vendor, but they don’t usually respond until late night.
  3. Nov 24, 2020 at 10:30 AM
    #1363
    Gnarman
    Gnarman Well-Known Member
    Southwest
    2016 dbcb trd off road quicksand lb
    ARB Shell, BP51, 255/85/16 ST MAXX, SCS Ray 10 Matte Bronze, Caliraised led 32 inch/side shooter/amber pods, floor mats, start x remote start, auxbeam 8 gang switch panel, diode dynamics hid lows, Australian Shepherd
  4. Nov 24, 2020 at 1:12 PM
    #1364
    svermilyea
    svermilyea [OP] Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    Yes. It will connect to your PX5 or PX6 head unit.
  5. Nov 24, 2020 at 5:07 PM
    #1365
    erikarthur
    erikarthur Well-Known Member
    Erik
    WI
    Seems like folks are pretty happy with the Dasaita unit. Is that correct? I'm looking for a new headunit with carplay support and I have the JVC stereo so this should fit well in the bezel. I think a JVC or Pioneer is going to be more expensive once you get the wiring and control packs from somewhere like Crutchfield. Thanks
  6. Nov 24, 2020 at 8:57 PM
    #1366
    Gnarman
    Southwest
    Thank you did you leave it plugged in/did it drain your battery at all?
  7. Nov 24, 2020 at 9:22 PM
    #1367
    Dwood
    Dave
    Minneapolis, MN
    Mine gets left in, no draining issues
  8. Nov 25, 2020 at 3:28 AM
    #1368
    khite100
    khite100 Member
    Kevin
    Marietta, GA
    I did not have good luck with the Veepeak. I sent it back. I ended up with the OBDLink MX.
    nudavinci64 likes this.
  9. Nov 25, 2020 at 9:11 AM
    #1369
    Gnarman
    Southwest
    how do you like it?
  10. Dec 5, 2020 at 6:01 AM
    #1370
    erikarthur
    Erik
    WI
  11. Dec 5, 2020 at 1:00 PM
    #1371
    svermilyea
    Scott
    East Tennessee
    you head unit you have chosen will give you built in Carplay via the zLink program. You will need an android compatible bluetooth OBD2 reader. You will link the reader to the headset and all your car info will work, and you can run a program like Torq to get gauges and speedo, as well as TPMS.
    erikarthur likes this.
  12. Dec 6, 2020 at 6:41 AM
    #1372
    Uthmoelleri
    Uthmoelleri Think for yourself, question authority.
    2019 QS DCSB 4WD
    Does this hu have optical out? I've searched but can't find anything saying it for sure does nor can I see a toslink or spdif from any of the pics but I do need glasses really bad!
    Also, from anyone that has gone from a manufacturer like Sony, Kenwood, Alpine etc to this or vice versa how does the sound quality compare? My worry about sound quality is the only reason I haven't bought one of these yet...
    Can anyone speak to the differences with this hu and the Joying besides the Joying having a volume knob and a stupid brand name?
    Thanks!
  13. Dec 27, 2020 at 3:06 PM
    #1373
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Folks that have the PX6: I swapped my px5 out and hooked up the 6. Most everything works, but I'm fairly certain I'm having canbus issues. Steering wheel controls don't work, won't switch over to the camera in reverse, and I'm not getting any sound. I know the camera is working because I can use it through the FCAM app. I have OEM+ stuff and it's getting power, so I don't think the remote signal is coming through. Sooo it probably is the canbus module. I want to make sure everything is wired correctly as it's a little different than the 5. I'm also pretty sure I have the settings correct on the head unit. Any pointers from folks that have some this?
  14. Dec 27, 2020 at 3:13 PM
    #1374
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    So not sure if its the same on the dasaita units as it is on the joying ones, but in the car select page I had to choose this to get any of those things to work on mine.
  15. Dec 27, 2020 at 3:20 PM
    #1375
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    It's a little different, but I have a similar screen. I found a video where dude installs the same unit, but no luck. I'll see if I can emulate this on mine. Thanks.
  16. Dec 27, 2020 at 3:58 PM
    #1376
    erikarthur
    Erik
    WI
    I bought a PX6 and it worked for a day or so before the core board went out but the steering wheel controls and backup camera worked. Now I'm back to Entune and waiting for a replacement board from China.
  17. Dec 27, 2020 at 4:01 PM
    #1377
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Yikes. I tried the above and still nothing.
  18. Dec 27, 2020 at 4:26 PM
    #1378
    TheTacoAbides
    TheTacoAbides Well-Known Member
    Randy
    2013 Black Tacoma SR5
    Rough country 3" lift and level. Tuff AT 20" rims. Nitto Terra Grappler G2.
    I got the PX6, MTCE Android 10 flavor for my 2013 non-JBL. I was able to get CARPLAY to work after much of the same suggestions offered by Iris. The one thing that I had not done was enable Siri on my phone. That seemed to break the ice. There are a lot of moving parts so I'm sure Siri is just one piece fo the puzzle.
    However after getting wireless carplay working and living with it for a week, I decided to go back to the native Android interface (plus Agama). I had an annoying oscillating static that was occurring. It was very faint and easily drowned out when driving. However when I was stopped and in between songs it was noticeable. I thought it might be related to the canbus adapter so I now have that out of the circuit. But what cured it was turning off carplay and turning my iPhone in to a wifi hotspot for the unit. To me, it's a much smoother interaction with all the native Android apps plus the static is now gone. Hard to quantify but I think that Spotify sounds cleaner as well. Mulling over the idea of getting a data only 4g USB dongle.
    I did like how immediately the carplay would reconnect when I started the car. Trying to get the native wifi hotspot to work automagically is frustrating. I did find that if I scrolled up the home lock screen, long pressed the bluetooth icon - it would give me the option to make the personal hotspot discoverable without going through the dance in the settings option.
    I plan to add the canbus adapter back in to the equation in a week. I'll be able to confirm if it contributed to the static. Currently the SWC works without it in place, but I think I'm gonna need it when I add Torque in the future.
    Still have stock speakers in place. The next step is changing out the speakers and adding in a small sub. I wanted to get used to the head unit first before adding in too many more variables. So far I really like it. There's a bit of the Android learning curve to overcome but I see a lot of potential.
  19. Dec 27, 2020 at 6:19 PM
    #1379
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    On the Dasaita you need to go to the canbus and select RAV4 or Camry I believe. Once I did that camera and controls worked. I ordered the wrong harness at first and with that one controls worked without changing to another car but no camera.
    for internet that was mentioned I read that you can set a static IP so that your unit connects right away but haven’t tried it. I’ll post if I can find it again.
  20. Dec 27, 2020 at 6:35 PM
    #1380
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    The more I look, the more I think my canbus module is bad.
