DASAITA ANDROID 9.0 UNIT WITH APPLE CARPLAY WIRELESS AND OEM AUDIO PLUS
Discussion in 'Audio & Video' started by svermilyea, Jul 23, 2019.
  1. Aug 21, 2019 at 7:57 PM
    #121
    IMC87
    IMC87 Well-Known Member
    Richard
    Los Angeles, CA
    '18 TRD Off-Road quicksand
    Just installed mine, I'll play with it more tomorrow but so far I like it, downsides so far to me are..
    - need to have data on the unit to be online (duh) and I dont pay for hotspot data
    - oem usb cable came with my kit, but unfortunately the oem usb that this unit connects to isnt a fast charging port, I'll have to rely on my cigarette lighter adapter for fast charge
    Unless you guys know of fixes for these?
  2. Aug 21, 2019 at 8:28 PM
    #122
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    You can replace the 12 volt/cigarette lighter piece with a quick charging dual USB port very easily, the power supplied to it charges my phone really quickly.
    This is regardless of whether or not someone is installing a new head unit. There may be a more elegant way using HU integrated USB ports but replacing the cig lighter has worked well for me and it's super easy.
    IMC87[QUOTED] likes this.
  3. Aug 21, 2019 at 9:18 PM
    #123
    TacomaBlu
    TacomaBlu Well-Known Member
    2017 TRD Sport
    6in Procomp 35in Toyo M/T 18x9 Mamba M13
    Does this support XM?
  4. Aug 22, 2019 at 3:10 AM
    #124
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
  5. Aug 22, 2019 at 11:01 AM
    #125
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Finally came! Waiting on my donner bezel
    DoubleD.17BlazingBlue likes this.
  6. Aug 22, 2019 at 11:09 AM
    #126
    DoubleD.17BlazingBlue Well-Known Member
    Derek
    2017 Blazing Blue SR5
    Yes via XM app, needs the CarPlay dongle to achieve this also but that’s how I get it on mine
  7. Aug 22, 2019 at 11:13 AM
    #127
    boulderoffroader
    boulderoffroader Well-Known Member
    Colorado
    2018 TRD Pro
    Read in the XDA forum about volume issues between phone calls and music. Have you seen that?
  8. Aug 22, 2019 at 11:17 AM
    #128
    Derek
    I do feel like I have to turn up calls up a bit but that’s easy to do on the wheel
  9. Aug 22, 2019 at 11:17 AM
    #129
    boulderoffroader
    Colorado
    2018 TRD Pro
    As long as you remember to turn it back down. Heh.
  10. Aug 22, 2019 at 11:23 AM
    #130
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I have the same issue, im hoping IOS13 fixes it.
  11. Aug 22, 2019 at 6:10 PM
    #131
    Derek
    It’s really not that significant a difference
  12. Aug 22, 2019 at 6:14 PM
    #132
    Derek
    Measurements, now these are approximate: top and left and right are 1/16” from where the trim piece is on the bezel and where the trim bends towards the air vents respectively. The bottom is 1/8” so it’s not perfectly centered. Hoope this helps you get it in the correct orientation the dash. Good luck
  13. Aug 22, 2019 at 6:31 PM
    #133
    Taco_Coma
    South NJ
    2018 DCSB SR5
    Thanks buddy, so there's a little more space on the bottom
  14. Aug 22, 2019 at 7:51 PM
    #134
    boulderoffroader
    Colorado
    2018 TRD Pro
    That's good to hear. I just placed my order via ebay. Took the same route you did and got virtually the same price. Here's hoping my install goes as well.
  15. Aug 24, 2019 at 11:20 AM
    #135
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    I have a regular OR with the non JBL head unit. Do I need the bezel adapter? Also will my front camera mod still work?
  16. Aug 24, 2019 at 11:24 AM
    #136
    delonix
    delonix Well-Known Member
    Delonix
    PR
    Tacoma TRD Sport 2018
    Your bezel will work. I don't have the dasaita head unit. If it has two video inputs (most do) it will.
  17. Aug 24, 2019 at 12:38 PM
    #137
    Yota_Ivan
    Yota_Ivan Geaux Tigers!
    Arlington, TX
    2006 Tacoma DCLB 4x4 TRD Sport
    A little bit of this, a little bit of that...
    Any cyber-security concerns with these "connected" appliances? I know I won't be doing any bank or sensitive transactions through the HU, but it does connect to our phones. (Just sayin')...
    Regards,
    Paranoid Lunatic from Texas :D
  18. Aug 24, 2019 at 1:02 PM
    #138
    delonix
    Delonix
    PR
    Just don't use it for banking or any sensitive stuff. There are lots of connections to China for sure.
    Taco_Coma likes this.
  19. Aug 24, 2019 at 2:19 PM
    #139
    Yota_Ivan
    Arlington, TX
    I only said in-jest, but a concern for sure. Android has its security vulnerabilities and i'm willing to bet these Chinese company's programmers have the know-how to exploit them.
    Without a doubt, no sensitive activities of any kind.
  20. Aug 25, 2019 at 4:36 PM
    #140
    Taco_Coma
    South NJ
    2018 DCSB SR5
    The plugs on the back, which ones do y'all have plugged in? going to install sometime this week
