DASAITA ANDROID 9.0 UNIT WITH APPLE CARPLAY WIRELESS AND OEM AUDIO PLUS
Discussion in 'Audio & Video' started by svermilyea, Jul 23, 2019.
  1. Apr 8, 2021 at 4:59 AM
    #1421
    svermilyea
    svermilyea [OP] Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    Yes, you retain all the settings you had in your stock head unit.
    patdeezy likes this.
  2. Apr 19, 2021 at 11:22 AM
    #1422
    FamouzStarz
    FamouzStarz The illest taco
    21 TRD PRO
    ICON Build and then some
    not sure about the head unit doing those functions but I have used Carista app with the bt dongle to change all those settings, 7day trial is 10$ which is basically enough time to tweak settings. Of course if you want to go back after the fact you would need to use another email address to get another trial period.
  3. Apr 20, 2021 at 8:51 PM
    #1423
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    I have a 2017 Tacoma TRD Pro, no JBL. I like to get the Dasaita Android 10.0 PX6 10 inch head unit. One with 1280x720 resolution.
    I can’t find that unit on Amazon that’s compatible with 2016-2019 Tacoma, only ones I found are the older 9 inch models. Anyone have a link to the newer px6 10 inch that’s plug and play for 2017 Tacoma?
  4. Apr 21, 2021 at 7:26 AM
    #1424
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    Curious to see if the 10.0 would fit stock location w/o modification... 9" H/U looks like it fits perfectly
  5. Apr 23, 2021 at 2:20 PM
    #1425
    h2ohhh
    h2ohhh New Member
    Anyone installed this on a 2021?? Seems like the harness doesn’t match....
  6. Apr 23, 2021 at 2:29 PM
    #1426
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    I have the JBL package, but i'm about to gut and replace the entire sound system. Will I still need the CANbus option with this deck for the steering wheel controls?
  7. Apr 23, 2021 at 6:06 PM
    #1427
    svermilyea
    Scott
    East Tennessee
    Most of these units have a canbus adapter to retain steering wheel controls. Be sure to get the unit for your model year. I have used both the PX5 and PX6 units from Dasitia and they provided all required connectors with exception of my GPS antenna adapter (they provided a stand alone GPS antenna) to use the factory antenna.
  8. Apr 24, 2021 at 11:39 AM
    #1428
    patdeezy
    souLcaL
    Sorry I’m new to all this android based H/U stuff. Is PX5/PX6 basically the operating software for these units?
    Thanks
  9. Apr 24, 2021 at 2:14 PM
    #1429
    svermilyea
    Scott
    East Tennessee
    PX5/PX6 refers to the underlying chipset that Android runs on. The PX6 has the carplay interface built in and uses a default android application to support the hardware. The PX6 also contains a digital signal processor which will yield better sound quality for audio playback with finer sound controls to optimize the sound the way you prefer.
    Dasitia refers to their head units by the chipset.
  10. Apr 24, 2021 at 3:05 PM
    #1430
    patdeezy
    souLcaL
    Appreciate the explanation :thumbsup:
  11. Apr 26, 2021 at 11:12 AM
    #1431
    LC7
    Far Nor Cal
    Thanks for the reply, but i'm still unclear on this. Is the CANbus adapter for anything besides the steering wheel controls? I won't have any JBL system components downstream of the head unit when I install the Dasaita, so I want to make sure I get the correct configuration.
  12. Apr 26, 2021 at 1:21 PM
    #1432
    svermilyea
    Scott
    East Tennessee
    Assuming that you have a 2011 Taco, you will need this Dasita MAX 6 unit: https://www.amazon.com/Dasaita-Andr...aita+max+6+tacoma&qid=1619467404&sr=8-10&th=1
    This unit comes complete with everything you will need to connect to your factory harness.
    The 2011 TACOs uses a canbus, so the Dasita unit comes with the canbus adapter. This adapter retains your steering wheel controls, as well as allowing the head unit to display and modify factory settings originally controlled in your factory head unit. I am not familiar with your model, so I don't know what setting is will allow you to see. In the gen 3s, it allowed things light tire pressure monitoring, door monitoring, lighting settings etc.
    LC7 likes this.
  13. May 2, 2021 at 11:00 AM
    #1433
    barnstormer399
    barnstormer399 Well-Known Member
    2007 DCSB
    Is anyone running hal9k on a new px6? Looking for a better UI so agama might be fine, but it seems as though there are more/better features in a whole new rom? But I'm seeing both references to it working on px6, as well as complaints that the developer hasn't updated for px6 yet.
    I'm on Android 10, mcu_ha_v3.62_1
  14. May 2, 2021 at 11:39 AM
    #1434
    DaMaDo
    DaMaDo Well-Known Member
    Northern AL
    2018 White TRD Pro
    That's what I use and it fixed multiple issues for me and improved the sound. Love the mod - probably wouldn't have kept the HU without it.
  15. May 2, 2021 at 11:57 AM
    #1435
    barnstormer399
    2007 DCSB
    What mcu are you on? Did you do the mod installer 2 method or something else?
  16. May 2, 2021 at 12:02 PM
    #1436
    DaMaDo
    Northern AL
    2018 White TRD Pro
    Mine's the RK3399 PX6.
    I installed it per the XDA forum page instructions:
    Update from Android 9:
    The installation is similar to a regular firmware update
    1. Copy the firmware file update.zip to a USB flash drive / SD memory card formatted in FAT32
    2. Insert a USB flash drive / SD memory card into the device
    3. In the window that appears, click "Install"
    4. After installation, the device will automatically restart one more time to complete the installation of Magisk.
    I then paid for it and it auto updated
  17. May 2, 2021 at 12:36 PM
    #1437
    barnstormer399
    2007 DCSB
    Sorry to.belabor this, but that's the thread I already saw that ends in people.complaining about there not being an update for Android 10. To confirm, you're saying you flashed his over top of the stock 10 rom, or did you already have 9?
    Out of the box mine does Android auto wirelessly, which I think is a new thing. I'm guessing I would lose that if it goes to 9?
  18. May 2, 2021 at 12:51 PM
    #1438
    DaMaDo
    Northern AL
    2018 White TRD Pro
    I had 9.0 before installing. Malaysk seems to have one for 10.0
  19. May 31, 2021 at 12:17 PM
    #1439
    TSmoove
    TSmoove Well-Known Member
    Trevor
    Atlanta, GA
    2017 Tacoma
    Dasaita 9" Android 10.0 Bluetooth Head Unit for Toyota Tacoma Corolla Sienna 2016 2017 2018 Touch Screen Car Radio Carplay 4G Ram 64G ROM Support Android Auto GPS Navigation WiFi RDS 2 Din https://www.amazon.com/dp/B082XHCBJ2/ref=cm_sw_r_cp_api_glt_fabc_TVQ0E4N4CC6K6N0A61XN?_encoding=UTF8
    Does this come with everything I need or are there any other adapters recommended?
  20. May 31, 2021 at 3:44 PM
    #1440
    svermilyea
    Scott
    East Tennessee
    The only adapter you may want is: https://www.discountcarstereo.com/sumi-sma.html
    This will allow you to use your factory GPS antenna.
    jmneill and TSmoove[QUOTED] like this.
