Dasaita Head Unit for 2nd Gen Tacoma
Discussion in 'Audio & Video' started by mcgrath.travism, Jul 18, 2019.
  1. Jan 21, 2022 at 1:32 AM
    #1121
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    jpereira2 likes this.
  2. Jan 21, 2022 at 1:43 AM
    #1122
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Ringer on the HU? Not sure never really noticed it.
    theolee[QUOTED] likes this.
  3. Jan 21, 2022 at 1:47 AM
    #1123
    theolee
    Theo
    SAN DIEGO
    Really?! Man you're lucky. When I have a incoming call through Bluetooth, the highest pitch screaming tridactyl ringtone comes blaring out of the speakers. I've tried everything I can to stop it but unfortunately had zero luck. I thought all of us who bought around the same time had this issue lol. :D:facepalm:
    kamakazie_1 and jpereira2 like this.
  4. Jan 26, 2022 at 11:51 AM
    #1124
    kamakazie_1
    kamakazie_1 Well-Known Member
    RJ
    Mims, Florida
    2012 White Tacoma DCSB TRD OR 4X4
    Factory Roof Racks Installed, Vent Visors, Meso dome and maps, Stubby Ant., 265/70-16 Discovery RTX, Dasaita 9" Android HU, RedLine Hood Supports, MBRP Cat Back Stainless Exhaust
    I had it too Theo, I ended up not using my phone in the truck anymore, I got a set of AfterShokz that I use all day anyway, suppressed how I lived without them so long.. I've still not been able to get my unit to update the IMG file...
    RJ
  5. Jan 26, 2022 at 11:59 AM
    #1125
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Had my unit get weird yesterday. It would not shut down.
    I pressed the rst button (which wow thats a tiny hole) and nothing.
    I had to pull the 20a fuse in the fuse box under the hood to finally kill it.
  6. Jan 26, 2022 at 8:50 PM
    #1126
    theolee
    Theo
    SAN DIEGO
    Hey RJ, hope all is well!
    At least you found a way around it! Just don't use Bluetooth lol. I decided to live with racing to answer a call before the ringtone goes off.
    That's a bummer! Loading that IMG file up can be tricky.
    kamakazie_1[QUOTED] likes this.
  7. Jan 26, 2022 at 8:57 PM
    #1127
    theolee
    Theo
    SAN DIEGO
    When you made contact with the restart button did you hear a click? The restart button should be held down for 5 sec or so before it reboots.
    This also happeneds to me on a 100° days. I also try to reboot every now and then to clear up any cache files slowing it down.
  8. Jan 26, 2022 at 9:13 PM
    #1128
    ZColorado
    13 DCSB OR 6MT
    I did feel it click. I did try and hold it down as well. I may have done it less then 5 seconds though.
    I was also unable to run carplay due to an error as well.
    All was fixed after the reboot though.
  9. Jan 27, 2022 at 7:46 AM
    #1129
    kamakazie_1
    RJ
    Mims, Florida
    Yea, the head just makes folders on the thumb drive and sits there, if never seems to see the IMG to update with... I tried a ton of different ways,, Still running the original that came on it..
    RJ
  10. Mar 29, 2022 at 10:10 AM
    #1130
    Drupiano
    Drupiano Member
    Drew
    2008 Black Tacoma V6 SR5
    Hey all, I just bought this unit for my 2008 AC non-JBL, no steering wheel control, no CANBUS. It was very easy to install, easily paired with CarPlay, but I am having trouble with the reverse camera. I installed the aftermarket Pop-Lock/ Tailgater latch and camera, everything is connected and the image shows up when I click on the "F-CAM" button in the main menu and press "reverse cam" option and throw the truck into REVERSE... the image is great. But for some reason it will not automatically pop-up with the reverse image when I throw it in "reverse" like I would like it to. Is this a factory settings issue? Does anyone have any insight? Thank you in advance
  11. Apr 1, 2022 at 11:43 AM
    #1131
    theolee
    Theo
    SAN DIEGO
    If I remember correctly, there should be a trigger wire labeled brake. I'm not a 100% sure where it needs to be tapped into on a 08 but thats thats how you get that feature to work.
  12. Apr 1, 2022 at 1:13 PM
    #1132
    Drupiano
    Drupiano Member
    Drew
    Thanks for the response Theo, I see the instructions in the back on the owners manual for that process. I was hoping I was done with the work, but apparently not! I guess we need that secondary wire to trigger it, the yellow RCA cable from camera is only video signal which makes sense. Thanks!
  13. Apr 29, 2022 at 4:34 PM
    #1133
    theolee
    Theo
    SAN DIEGO
    Anyone give this a try? Super convenient!
    nudavinci64 likes this.
  14. Apr 30, 2022 at 12:25 AM
    #1134
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    No but I did stream the NFL draft while waiting in line with me to catch a ferry home after work. My buddy from work though it was pretty sweet.
  15. Apr 30, 2022 at 5:15 AM
    #1135
    barnstormer399
    barnstormer399 Well-Known Member
    2007 DCSB
    How are you all connecting to the internet? What cell service, and are you using phone as hotspot, or does your Dasaita have it's own sim and plan?
    Asking because per the speedtest app I'm getting only 30Mbps down on the HU, while the app on the tmobile phone (galaxy s21 5g) shows 300+ down when testing at the exact same time. I suspect it's tmo throttling the hotspot. Tried switching the hotspot to 5ghz, but I guess the Dasaita only does 2.4.
    Edit: I'm on the malaysk rom if that matters
  16. Apr 30, 2022 at 7:14 AM
    #1136
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    If your ‘08 is anything like my ‘06, in the drivers side kickpanel, there’s a connector with a thicker red/white wire. That’s your reverse trigger. It’s, I think, the largest connector back there.
  17. Apr 30, 2022 at 9:36 AM
    #1137
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    I was sitting in a Ferry line at Friday Harbor Wa. There was coffee shop that had free WiFi. I’ve connected to my home Wifi. I only use 3 outta the 4 phones on my phone plan. I wonder if I could stuff a SIM card in the Dasitia.
    kamakazie_1 and theolee like this.
  18. Jun 15, 2022 at 10:45 PM
    #1138
    Breakr007
    Breakr007 Well-Known Member
    Can I ask how you got the camera anytime mod working? Can you offer some hints on the wiring?
  19. Jun 17, 2022 at 10:42 AM
    #1139
    nudavinci64
    Robert
    id have to search for it. there are a couple good camera anytime threads on TW. In short you wire in a switch that taps into the power then reverse signal and the camera so you can turn it on/off or switch to only back up. on a 2nd gen its wiring near the fuse box from what I recall. If I find it ill post it.
    theolee likes this.
  20. Jun 17, 2022 at 11:15 AM
    #1140
    DaleRS
    DaleRS Well-Known Member
    Dale
    Cleveland, Ohio
    2015 Black DCSB SR5 w/ Snugtop
    Spent a few hours last night doing some trial and error to get my factory bracket to mount to the Dasaita! Was a PITA but finally got it snug and it’s totally secure now after being in the truck for over a year.
    used 8-32 machine screws that were a 1/4inch in length to secure it.
    theolee and kamakazie_1 like this.
