dash board coming undone?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lentsnh, Nov 29, 2008.
  1. Nov 29, 2008 at 10:12 PM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    i noticed today as i was cleaning my filthy truck, i noticed that my bottom half of my dashboard (where the fuse box is) is coming undone from the top half. does any one know how to fix this?
  2. Nov 29, 2008 at 10:14 PM
    cheehab
    cheehab I bleed Black and Gold
    Adam
    Winter Park, CO
    2015 Tundra TRD Pro CrewMax
    That sounds terrible! Any chance it's still under warranty???
  3. Nov 29, 2008 at 10:17 PM
    Lentsnh
    its not. its a year over. ha
  4. Nov 29, 2008 at 10:18 PM
    Lentsnh
    where the drivers door and the drivers side of the dash board meet, is where is coming undone
  5. Nov 30, 2008 at 6:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I think that part just pushes into place. Have you tried that?
  6. Nov 30, 2008 at 6:52 AM
    TheKneeBiter
    TheKneeBiter Active Member
    This was a big problem back when the 2005 came out. Mine never did it but I read a ton of complaints on it back then over at TOYOTANATION.COM. If you do some searching you might find the threads. Some fixed it and some had it done under warranty.
  7. Nov 30, 2008 at 3:26 PM
    Lentsnh
    theres plastic clips to clip the bottom half of the dash in. Their not broken its like its too big on that side. but yes i did try that. ill get pictures up here soon.
  8. Nov 30, 2008 at 3:27 PM
    Lentsnh
    really? what about the 06's
  9. Nov 30, 2008 at 3:29 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Warranty or not, if you never took it apart, i would absolutely take it in to the dealer and say 'what this?'
    I can't imagine them not taking care of it.
  10. Nov 30, 2008 at 3:35 PM
    Lentsnh
    there was an owner before me but i dont know if he was the tear apart type.
  11. Nov 30, 2008 at 3:39 PM
    WNYTACOMA
    Clarence, New York
    I'd roll the dice with it.
    Go in as though you are confident they will button it up for you. A lot of times, your approach goes a long way in getting the desired results.
    In other words, go in as though you expected it to be taken care of.
  12. Nov 30, 2008 at 3:42 PM
    Lentsnh
    ok yeah i understand what you mean. i think i will follow-up on that
  13. Nov 30, 2008 at 3:45 PM
    WNYTACOMA
    Clarence, New York
    Good luck.
  14. Nov 30, 2008 at 3:47 PM
    Lentsnh
    thank you. what if its not covered in the warranty? how much would it be?
  15. Nov 30, 2008 at 3:54 PM
    WNYTACOMA
    Clarence, New York
    How much can clips be, even from Toyota? I can't imagine more than a few bucks.
    If they give you a hard time at all, i would act shocked and go with the 'you've got to be kidding me' routine.
    Only grudingly and after all the dramatics were exhausted (wide eyed, dramatic *sigh*, etc) would i say something along the line of 'well, if you guys don't stand behind this', what do i need to do to fix the thing myself?"
    If it goes that far, they will pull it up on the screen and i can't imagine it would be over $10.00-15.00 depending on the # of clips, if i understood the discription of the issue.
    Seriously, for something seemingly so cheap and easy for them to address, i can't imagine them not taking care of it. 06' truck?
  16. Nov 30, 2008 at 4:12 PM
    TheKneeBiter
    Dash Gap TSB
    BO022-06 Addresses the left side of the dash seperating. Replaces the clip in the upper left corner with a redesigned one part number 90468-04177
  17. Nov 30, 2008 at 4:36 PM
    Lentsnh
  18. Nov 30, 2008 at 4:38 PM
    Lentsnh
    hope what i posted helps
  19. Nov 30, 2008 at 4:40 PM
    TheKneeBiter
    either have the tsb done or buy the clips listed and fix it. not a huge problem.
  20. Nov 30, 2008 at 4:52 PM
    Lentsnh
    so it is the clips?
